DLPDLCR4710EVM-G2: DLPDLCR4710EVM-G2: Projection angle
Part Number: DLPDLCR4710EVM-G2
At present, the DLPDLCR4710EVM-G2 projects with a elevation angle. To achieve parallel projection, how to adjust it?
We thank you and appreciate any help provided.
  • Socstain,
    In order to achieve parallel projection, you will need to modify the optics in some form or another on the system. This may require custom lens, depending on your desired setup. Your best bet would be to see if any of the optical module manufacturers produce an optical engine which meets your specs. The risk there is that the DMD flex connections are not standard and therefore may not play nicely with the 4710EVM electronics.
    www.ti.com/.../buy-optical-engine.html
    I hope this helps.
    Philippe Dollo
