Other Parts Discussed in Thread: DLPC3430
Is color mode and fps/hz (firmware) set on the chip on the ribbon cable, or the DLPController chip on the PCB?
Reason I am asking is I want to know if I can use the Lightcrafter 2010 to update firmwares of optical engines which also uses the DLP2010 DMD but the board is not designed for monochrome operation mode by default
