Is TMS320C5515 suitable for interfacing 320 X 240 TFT LCD displays with controllers.
If no is there any other DSP in 5000 series? Please let me know ASAP.
Chandru
Chandru
What is the interface of TFT LCD? Please check C5515 LCD interface http://focus.ti.com/lit/ug/sprufp3/sprufp3.pdf.
Hyun
Hi
Thanks for your reply.
It will be a 18/24 bit parallel RGB and SPI interface. I have attached my preferred LCD datasheet.
Also I had a look in the document http://focus.ti.com/lit/ug/sprufp3/sprufp3.pdf and I found the Raster controller is not supported for TFT LCDs
Chandru
Did you mean that 5515 will not support the TFT LCD on parallel bus interface and supports only on SPI ?
Please clarify.
Chandru
C5515 does not support synchronous (Hsync, Vsync and pixel clock) parallel LCD interface.
Hyun
I have one more last query.
DO you have any application note on using SPI of 5515 for interfacing TFT LCD?
Till now I have used only 18/24 bit parallel interface for TFT LCD
Chandru
Please refer http://focus.ti.com/lit/ug/sprufo3/sprufo3.pdf SPI user guide and CSL SPI example.
Hyun
