I am having problems with the Spectrum Digital 5515EVM and the boot loader. I have used all of the available versions of the programmer for CC. They will program as indicated in the response. The memory can be also tested (NAND or NOR). I can run programs like LED.out on the board. I have never got the board to boot using LED.bin or any other .bin.
Is there a jumper or something physical on the EVM board that must be set correctly?
When using HEX55 I have assumed that -serial8 is the correct setting but some of the memory is 16 bit wide. How does this play out?
I have read all of the how to documents just nothing works. Any suggestions would be helpful.
