I am using dsk5416,CCSv3.1 and DSP/BIOS 4.80.188.
when i run timer1_useBios example it shows that the string become symols.
can you explane what should i change to see the exact result.
Thank you,
You ask a generic question how do you debug string/symbol with CCS
The CCS that you use is very old. A few years ago TI moved to a new version of CCS, and the current version is CCSv6 (you can download an evaluation version from the Web). CCS is an IDE - integrated development environment.
CCSv6 is based on Eclipse open standard, that is, the interface of the IDE is a standard interface. There are many documents and training on the web how to use Eclipse and CCSv6. In addition, CCS itself has a help tab. You have enough sources to answer your question
Ran
