Hi all,
Im getting following "Bad block table not found for chip 0" error in dm355evm my board, due to this error im getting more "Bad eraseblock " found in my NAND flash.
i have changed the ecc type in board file from NAND_ECC_HW to NAND_ECC_HW_SYNDROME , then its not coming but it could not creating mtdX and mtdblockX device nodes in filesystem so that i couldnt mount yaffs2 fs in my board,
i have used NAND_ECC_SOFT also ,but the same error,
im using dvsdk3.10 software and kernel version is 2.6.32-rc2.
find the below log for ur ref.
if i use
ECC type = NAND_ECC_SOFT
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
DONE
Jumping to entry point at 0x81080000.
U-Boot 1.3.4 (Aug 23 2012 - 18:29:25)
I2C: ready
DRAM: 128 MB
NAND: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron NAND 512MiB 3,3V 8-bit)
Bad block table written to 0x1ffe0000, version 0x01
Bad block table written to 0x1ffc0000, version 0x01
No NAND device found!!!
512 MiB
In: serial
Out: serial
Err: serial
ARM Clock :- 216MHz
DDR Clock :- 171MHz
Hit any key to stop autoboot: 0
dm9000 i/o: 0x4014000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 00:00:70:ff:3e:4e
operating at 100M full duplex mode
TFTP from server 10.10.30.66; our IP address is 10.10.30.56
Filename 'uImage'.
Load address: 0x80700000
Loading: #################################################################
done
Bytes transferred = 2015716 (1ec1e4 hex)
## Booting kernel from Legacy Image at 80700000 ...
Image Name: Linux-2.6.32-rc2-davinci1-HHT_Ve
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2015652 Bytes = 1.9 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux......................................................................................
................................................. done, booting the kernel.
Linux version 2.6.32-rc2-davinci1-HHT_Ver3.0-hw2.3-with-Ether (root@titus-hht) (gcc version 4.3.3 (Source
ry G++ Lite 2009q1-203) ) #35 PREEMPT Fri Aug 31 16:53:47 IST 2012
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DM355 EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci dm355 variant 0x0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 29464
Kernel command line: console=ttyS0,115200n8 noinitrd rw ip=10.10.30.56 root=/dev/nfs nfsroot=10.10.30.66:
/home/titus/Desktop/DM355_PSP3.10/Filesystem/RFS, nolock mem=116M dm9000eth=mac:00:00:70:FF:3E:4E video=d
avincifb:vid0=off:vid1=off:osd0=320x240x16,2025K davinci_enc_mngr.ch0_output=LCD davinci_enc_mngr.ch0_mod
e=320x240
net/ipv4/ipconfig.c,ip_auto_config_setup,1494
net/ipv4/ipconfig.c,ic_proto_name,1455
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 116MB = 116MB total
Memory: 113136KB available (3832K code, 308K data, 200K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 107.31 BogoMIPS (lpj=536576)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 104 gpio irqs
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
DM355 IPIPE intialized in Single Shot mode
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
vpss vpss: dm355_vpss vpss probed
vpss vpss: dm355_vpss vpss probe success
ch0 default output "LCD", mode "320x240"
LogicPD encoder initialized
Switching to clocksource timer0_1
musb_hdrc: version 6.0, cppi-dma, host, debug=0
musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 221
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
davincifb davincifb.0: check_fb_var: calling convert_fb_var_to_osd, var->bits_per_pixel: 16
davincifb davincifb.0: convert_fb_var_to_osd: bits per pixel: 16
davincifb davincifb.0: davincifb_set_par: calling convert_fb_info_to_osd bpp: 16
davincifb davincifb.0: convert_fb_info_to_osd: var->bits_per_pixel: 16
Console: switching to colour frame buffer device 40x15
davincifb davincifb.0: dm_osd0_fb: 320x240x16@0,0 with framebuffer size 2025KB
davincifb davincifb.0: check_fb_var: calling convert_fb_var_to_osd, var->bits_per_pixel: 4
davincifb davincifb.0: convert_fb_var_to_osd: bits per pixel: 4
davincifb davincifb.0: davincifb_set_par: calling convert_fb_info_to_osd bpp: 4
davincifb davincifb.0: convert_fb_info_to_osd: var->bits_per_pixel: 4
davincifb davincifb.0: dm_osd1_fb: 320x240x4@0,0 with framebuffer size 300KB
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x1c20400 (irq = 41) is a 16550A
serial8250.0: ttyS2 at MMIO 0x1e06000 (irq = 14) is a 16550A
brd: module loaded
Scanning device for bad blocks
Bad eraseblock 1 at 0x000000020000
Bad eraseblock 2 at 0x000000040000
Bad eraseblock 3 at 0x000000060000
Bad eraseblock 4 at 0x000000080000
Bad eraseblock 5 at 0x0000000a0000
Bad eraseblock 6 at 0x0000000c0000
Bad eraseblock 7 at 0x0000000e0000
Bad eraseblock 8 at 0x000000100000
Bad eraseblock 9 at 0x000000120000
Bad eraseblock 10 at 0x000000140000
Bad eraseblock 11 at 0x000000160000
Bad eraseblock 12 at 0x000000180000
Bad eraseblock 13 at 0x0000001a0000
Bad eraseblock 14 at 0x0000001c0000
Bad eraseblock 15 at 0x0000001e0000
Bad eraseblock 16 at 0x000000200000
Bad eraseblock 17 at 0x000000220000
Bad eraseblock 18 at 0x000000240000
Bad eraseblock 19 at 0x000000260000
Bad eraseblock 20 at 0x000000280000
Bad eraseblock 21 at 0x0000002a0000
Bad eraseblock 22 at 0x0000002c0000
Bad eraseblock 23 at 0x0000002e0000
Bad eraseblock 24 at 0x000000300000
Bad eraseblock 25 at 0x000000320000
Bad eraseblock 26 at 0x000000340000
Bad eraseblock 27 at 0x000000360000
Bad eraseblock 28 at 0x000000380000
Bad eraseblock 29 at 0x0000003a0000
Bad eraseblock 30 at 0x0000003c0000
Bad eraseblock 32 at 0x000000400000
Bad eraseblock 33 at 0x000000420000
Bad eraseblock 34 at 0x000000440000
Bad eraseblock 35 at 0x000000460000
Bad eraseblock 36 at 0x000000480000
Bad eraseblock 37 at 0x0000004a0000
Bad eraseblock 38 at 0x0000004c0000
Bad eraseblock 39 at 0x0000004e0000
Bad eraseblock 40 at 0x000000500000
Bad eraseblock 41 at 0x000000520000
Bad eraseblock 42 at 0x000000540000
Bad eraseblock 43 at 0x000000560000
Bad eraseblock 44 at 0x000000580000
Bad eraseblock 45 at 0x0000005a0000
Bad eraseblock 46 at 0x0000005c0000
Bad eraseblock 47 at 0x0000005e0000
Bad eraseblock 48 at 0x000000600000
Bad eraseblock 49 at 0x000000620000
Bad eraseblock 50 at 0x000000640000
Bad eraseblock 51 at 0x000000660000
Bad eraseblock 52 at 0x000000680000
Bad eraseblock 53 at 0x0000006a0000
Bad eraseblock 54 at 0x0000006c0000
Bad eraseblock 55 at 0x0000006e0000
Bad eraseblock 56 at 0x000000700000
Bad eraseblock 57 at 0x000000720000
Bad eraseblock 58 at 0x000000740000
Bad eraseblock 59 at 0x000000760000
Bad eraseblock 60 at 0x000000780000
Bad eraseblock 61 at 0x0000007a0000
Bad eraseblock 62 at 0x0000007c0000
Bad eraseblock 63 at 0x0000007e0000
Bad eraseblock 64 at 0x000000800000
Bad eraseblock 65 at 0x000000820000
Bad eraseblock 66 at 0x000000840000
Bad eraseblock 67 at 0x000000860000
Bad eraseblock 68 at 0x000000880000
Bad eraseblock 69 at 0x0000008a0000
Bad eraseblock 70 at 0x0000008c0000
Bad eraseblock 71 at 0x0000008e0000
Bad eraseblock 72 at 0x000000900000
Bad eraseblock 73 at 0x000000920000
Bad eraseblock 74 at 0x000000940000
Bad eraseblock 75 at 0x000000960000
Bad eraseblock 76 at 0x000000980000
Bad eraseblock 77 at 0x0000009a0000
Bad eraseblock 78 at 0x0000009c0000
Bad eraseblock 79 at 0x0000009e0000
Bad eraseblock 80 at 0x000000a00000
Bad eraseblock 81 at 0x000000a20000
Bad eraseblock 82 at 0x000000a40000
Bad eraseblock 83 at 0x000000a60000
Bad eraseblock 84 at 0x000000a80000
Bad eraseblock 85 at 0x000000aa0000
Bad eraseblock 86 at 0x000000ac0000
Bad eraseblock 87 at 0x000000ae0000
usb 1-1: new high speed USB device using musb_hdrc and address 2
Creating 5 MTD partitions on "davinci_nand.0":
0x000000000000-0x0000003c0000 : "bootloader"
0x0000003c0000-0x000000400000 : "params"
0x000000400000-0x000000800000 : "kernel"
0x000000800000-0x000020000000 : "filesystem1"
0x000020000000-0x000020400000 : "filesystem2"
mtd: partition "filesystem2" is out of reach -- disabled
davinci_nand davinci_nand.0: controller rev. 2.3
spi_davinci spi_davinci.0: DaVinci SPI driver in EDMA mode
Using RX channel = 17 , TX channel = 16 and event queue = 1
spi_davinci spi_davinci.0: Controller at 0xfec66000
PINMUX0 = 7f55
PINMUX0 = 7b55
enable_tft_completed.
Inserting SPI module
PINMUX0 = 7b55
PINMUX0 = 7baa
SPI2 SPI2FMT0 value =173320
tft_open exit
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
dm9000 Ethernet Driver, V1.31
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
mac_addr[0]=0
mac_addr[1]=0
mac_addr[2]=70
mac_addr[3]=ff
mac_addr[4]=3e
mac_addr[5]=4e
eth0: dm9000a at c782e000,c7832002 IRQ 65 MAC: 00:00:70:ff:3e:4e (eeprom)
00:00:70:ff:3e:4e
console [netcon0] enabled
netconsole: network logging started
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
OMAP Keypad Driver
omap_kp_probe
input: omap-keypad as /devices/platform/omap-keypad.0/input/input0
register omap-keypad input device
gpio_request_irq 70 status 0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
watchdog watchdog: heartbeat 60 sec
davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
davinci_mmc davinci_mmc.1: Using DMA, 4-bit mode
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
XXXXX: init001:
XXXXX 086
XXXXX 093
XXXXX 079
XXXXX 051
XXXXX 065
XXXXX 058
XXXXX 072
XXXXX: probe 106 ret: 0
No device for DAI tlv320aic3x
usb 1-1.2: new high speed USB device using musb_hdrc and address 3
No device for DAI davinci-i2s
XXXXX: probe 101:
asoc: tlv320aic3x <-> davinci-i2s mapping ok
Failed to add route HPLOUT->Headphone Jack
XXXXX: probe 105 ret: 0
ALSA device list:
#0: DaVinci EVM (tlv320aic3x)
SPCR1=0x0
RCR1=0x0
XCR1=0x0
SRGR1=0x20000001
PCR1=0x0
DXR1=0x0
SPCR1=0x2000000
XCR1=0x140
PCR1=0xA00
SRGR1=0x101F0F07
SPCR1=0x2F30000
Resetting DAC....done
Configuring Audio DAC
SPI0 SPIFMT0 value =173320
SPI0 dv_open exit
before spi open
after init disp
TCP cubic registered
NET: Registered protocol family 17
rtc-isl1208 1-006f: setting system clock to 2012-08-31 16:49:28 UTC (1346431768)
mmc0: new high speed SD card at address 0002
mmcblk0: mmc0:0002 00000 1.86 GiB
mmcblk0: p1 p2
eth0: link down
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
usb 1-1.2: configuration #1 chosen from 1 choice
IP-Config: Guessing netmask 255.0.0.0
net/ipv4/ipconfig.c,ic_setup_routes,369
IP-Config: Complete:
device=eth0, addr=10.10.30.56, mask=255.0.0.0, gw=255.255.255.255,
host=10.10.30.56, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=10.10.30.66, rootpath=
Looking up port of RPC 100003/2 on 10.10.30.66
Looking up port of RPC 100005/1 on 10.10.30.66
VFS: Mounted root (nfs filesystem) on device 0:14.
Freeing init memory: 200K
INIT: version 2.86 booting
Starting udev
udev: starting version 141
udevd[533]: inotify_add_watch(3, (null), 10) failed: Bad address
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces... ifup: interface lo already configured
ifup: interface eth0 already configured
done.
bash-4.2#
if i use
ECC type = NAND_ECC_HW_SYNDROME
Note:
Here u cant see the NAND bad block issue or bad block table not found issue
DM35x initialization passed!
TI UBL Version: 1.50
BootMode = NAND
DONE
I2C: ready
DRAM: 128 MB
Bad block table found at page 262080, version 0x01
Bad block table found at page 262016, version 0x01
512 MiB
In: serial
Out: serial
Err: serial
ARM Clock :- 216MHz
DDR Clock :- 171MHz
DM355 EVM :>boot
Filename 'uImage'.
done
OK
Starting kernel ...
ry G++ Lite 2009q1-203) ) #34 PREEMPT Fri Aug 31 16:34:47 IST 2012
e=320x240
NR_IRQS:245
TCP reno registered
brd: module loaded
davinci_nand: probe of davinci_nand.0 failed with error -22
PINMUX0 = 7f55
PINMUX0 = 7b55
PINMUX0 = 7b55
PINMUX0 = 7baa
tft_open exit
mac_addr[0]=0
mac_addr[1]=0
mac_addr[2]=70
mac_addr[3]=ff
mac_addr[4]=3e
mac_addr[5]=4e
eth0: dm9000a at c7800000,c7804002 IRQ 65 MAC: 00:00:70:ff:3e:4e (eeprom)
00:00:70:ff:3e:4e
OMAP Keypad Driver
omap_kp_probe
XXXXX: init001:
XXXXX 086
XXXXX 093
XXXXX 079
XXXXX 051
XXXXX 065
XXXXX 058
XXXXX 072
XXXXX: probe 101:
ALSA device list:
SPCR1=0x0
RCR1=0x0
XCR1=0x0
SRGR1=0x20000001
PCR1=0x0
DXR1=0x0
SPCR1=0x2000000
XCR1=0x140
PCR1=0xA00
SRGR1=0x101F0F07
SPCR1=0x2F30000
SPI0 dv_open exit
before spi open
after init disp
rtc-isl1208 1-006f: setting system clock to 2012-08-31 16:42:41 UTC (1346431361)
mmcblk0: p1 p2
eth0: link down
Starting udev
udevd[518]: inotify_add_watch(3, (null), 10) failed: Bad address
Starting thttpd.
done.
bash-4.2#
bash-4.2#
bash-4.2#
bash-4.2#
bash-4.2#
bash-4.2# ls
Settings lib root
app linuxrc sbin
bin media srv
boot mnt sys
dev mod tmp
etc opt usr
flash_filesystem.tar options var
hhtx_app patch
home proc
bash-4.2#
bash-4.2#
bash-4.2# ls -al /dev/
drwxr-xr-x 10 root root 2300 Aug 31 16:42 .
drwxrwxr-x 20 1000 1000 4096 Aug 31 09:19 ..
drwxr-xr-x 6 root root 140 Aug 31 16:42 .udev
drwxr-xr-x 2 root root 120 Aug 31 16:42 block
drwxr-xr-x 3 root root 60 Aug 31 16:42 bus
drwxr-xr-x 2 root root 2080 Aug 31 16:42 char
crw------- 1 root root 5, 1 Aug 31 16:42 console
crw-rw---- 1 root root 10, 63 Aug 31 16:28 cpu_dma_latency
crw-rw---- 1 root root 253, 0 Aug 31 16:28 davinci_previewer
crw-rw---- 1 root root 252, 0 Aug 31 16:28 davinci_resizer
drwxr-xr-x 6 root root 120 Aug 31 16:42 disk
lrwxrwxrwx 1 root root 3 Aug 31 16:42 fb -> fb0
crw-rw---- 1 root video 29, 0 Aug 31 16:28 fb0
crw-rw---- 1 root video 29, 1 Aug 31 16:28 fb1
crw-rw-rw- 1 root root 1, 7 Aug 31 16:28 full
crw-rw---- 1 root root 250, 0 Aug 31 16:42 hht_int_han_new
crw-rw---- 1 root root 251, 0 Aug 31 16:42 hhtp_ctrl
crw-rw---- 1 root root 89, 1 Aug 31 16:28 i2c-1
prw------- 1 root root 0 Aug 31 16:28 initctl
crw-r----- 1 root kmem 1, 2 Aug 31 16:28 kmem
crw-rw---- 1 root root 1, 11 Aug 31 16:28 kmsg
srw-rw-rw- 1 root root 0 Aug 31 16:42 log
crw-r----- 1 root kmem 1, 1 Aug 31 16:28 mem
brw-rw---- 1 root floppy 179, 0 Aug 31 16:28 mmcblk0
brw-rw---- 1 root floppy 179, 1 Aug 31 16:28 mmcblk0p1
brw-rw---- 1 root floppy 179, 2 Aug 31 16:28 mmcblk0p2
crw-rw---- 1 root root 10, 62 Aug 31 16:28 network_latency
crw-rw---- 1 root root 10, 61 Aug 31 16:28 network_throughput
crw-rw-rw- 1 root root 1, 3 Aug 31 16:28 null
crw------- 1 root root 108, 0 Aug 31 16:28 ppp
crw-rw-rw- 1 root root 5, 2 Aug 31 16:28 ptmx
drwxr-xr-x 2 root root 40 Aug 31 16:28 pts
brw-rw---- 1 root disk 1, 0 Aug 31 16:28 ram0
crw-rw-rw- 1 root root 1, 8 Aug 31 16:28 random
lrwxrwxrwx 1 root root 4 Aug 31 16:42 rtc -> rtc0
crw-rw---- 1 root audio 254, 0 Aug 31 16:28 rtc0
drwxrwxrwt 2 root root 40 Aug 31 16:28 shm
drwxr-xr-x 2 root root 120 Aug 31 16:42 snd
crw-rw-rw- 1 root root 60, 1 Aug 31 16:42 spi
crw-rw-rw- 1 root root 5, 0 Aug 31 16:28 tty
crw--w---- 1 root root 4, 0 Aug 31 16:43 tty0
crw--w---- 1 root root 4, 1 Aug 31 16:28 tty1
crw--w---- 1 root root 4, 10 Aug 31 16:28 tty10
crw--w---- 1 root root 4, 11 Aug 31 16:28 tty11
crw--w---- 1 root root 4, 12 Aug 31 16:28 tty12
crw--w---- 1 root root 4, 13 Aug 31 16:28 tty13
crw--w---- 1 root root 4, 14 Aug 31 16:28 tty14
crw--w---- 1 root root 4, 15 Aug 31 16:28 tty15
crw--w---- 1 root root 4, 16 Aug 31 16:28 tty16
crw--w---- 1 root root 4, 17 Aug 31 16:28 tty17
crw--w---- 1 root root 4, 18 Aug 31 16:28 tty18
crw--w---- 1 root root 4, 19 Aug 31 16:28 tty19
crw--w---- 1 root root 4, 2 Aug 31 16:28 tty2
crw--w---- 1 root root 4, 20 Aug 31 16:28 tty20
crw--w---- 1 root root 4, 21 Aug 31 16:28 tty21
crw--w---- 1 root root 4, 22 Aug 31 16:28 tty22
crw--w---- 1 root root 4, 23 Aug 31 16:28 tty23
crw--w---- 1 root root 4, 24 Aug 31 16:28 tty24
crw--w---- 1 root root 4, 25 Aug 31 16:28 tty25
crw--w---- 1 root root 4, 26 Aug 31 16:28 tty26
crw--w---- 1 root root 4, 27 Aug 31 16:28 tty27
crw--w---- 1 root root 4, 28 Aug 31 16:28 tty28
crw--w---- 1 root root 4, 29 Aug 31 16:28 tty29
crw--w---- 1 root root 4, 3 Aug 31 16:28 tty3
crw--w---- 1 root root 4, 30 Aug 31 16:28 tty30
crw--w---- 1 root root 4, 31 Aug 31 16:28 tty31
crw--w---- 1 root root 4, 32 Aug 31 16:28 tty32
crw--w---- 1 root root 4, 33 Aug 31 16:28 tty33
crw--w---- 1 root root 4, 34 Aug 31 16:28 tty34
crw--w---- 1 root root 4, 35 Aug 31 16:28 tty35
crw--w---- 1 root root 4, 36 Aug 31 16:28 tty36
crw--w---- 1 root root 4, 37 Aug 31 16:28 tty37
crw--w---- 1 root root 4, 38 Aug 31 16:28 tty38
crw--w---- 1 root root 4, 39 Aug 31 16:28 tty39
crw--w---- 1 root root 4, 4 Aug 31 16:28 tty4
crw--w---- 1 root root 4, 40 Aug 31 16:28 tty40
crw--w---- 1 root root 4, 41 Aug 31 16:28 tty41
crw--w---- 1 root root 4, 42 Aug 31 16:28 tty42
crw--w---- 1 root root 4, 43 Aug 31 16:28 tty43
crw--w---- 1 root root 4, 44 Aug 31 16:28 tty44
crw--w---- 1 root root 4, 45 Aug 31 16:28 tty45
crw--w---- 1 root root 4, 46 Aug 31 16:28 tty46
crw--w---- 1 root root 4, 47 Aug 31 16:28 tty47
crw--w---- 1 root root 4, 48 Aug 31 16:28 tty48
crw--w---- 1 root root 4, 49 Aug 31 16:28 tty49
crw--w---- 1 root root 4, 5 Aug 31 16:28 tty5
crw--w---- 1 root root 4, 50 Aug 31 16:28 tty50
crw--w---- 1 root root 4, 51 Aug 31 16:28 tty51
crw--w---- 1 root root 4, 52 Aug 31 16:28 tty52
crw--w---- 1 root root 4, 53 Aug 31 16:28 tty53
crw--w---- 1 root root 4, 54 Aug 31 16:28 tty54
crw--w---- 1 root root 4, 55 Aug 31 16:28 tty55
crw--w---- 1 root root 4, 56 Aug 31 16:28 tty56
crw--w---- 1 root root 4, 57 Aug 31 16:28 tty57
crw--w---- 1 root root 4, 58 Aug 31 16:28 tty58
crw--w---- 1 root root 4, 59 Aug 31 16:28 tty59
crw--w---- 1 root root 4, 6 Aug 31 16:28 tty6
crw--w---- 1 root root 4, 60 Aug 31 16:28 tty60
crw--w---- 1 root root 4, 61 Aug 31 16:28 tty61
crw--w---- 1 root root 4, 62 Aug 31 16:28 tty62
crw--w---- 1 root root 4, 63 Aug 31 16:28 tty63
crw--w---- 1 root root 4, 7 Aug 31 16:28 tty7
crw--w---- 1 root root 4, 8 Aug 31 16:28 tty8
crw--w---- 1 root root 4, 9 Aug 31 16:28 tty9
crw-rw---- 1 root dialout 4, 64 Aug 31 16:28 ttyS0
crw-rw---- 1 root dialout 4, 65 Aug 31 16:28 ttyS1
crw-rw---- 1 root dialout 4, 66 Aug 31 16:43 ttyS2
-rw-r--r-- 1 root root 0 Aug 31 16:42 udev_network_queue
crw-rw-rw- 1 root root 1, 9 Aug 31 16:28 urandom
crw-rw---- 1 root tty 7, 0 Aug 31 16:28 vcs
crw-rw---- 1 root tty 7, 1 Aug 31 16:28 vcs1
crw-rw---- 1 root tty 7, 128 Aug 31 16:28 vcsa
crw-rw---- 1 root tty 7, 129 Aug 31 16:28 vcsa1
crw-rw---- 1 root root 10, 130 Aug 31 16:28 watchdog
crw-rw-rw- 1 root root 1, 5 Aug 31 16:28 zero
bash-4.2#
bash-4.2#
bash-4.2# flash_eraseall /dev/mtd3
flash_eraseall: /dev/mtd3: No such file or directory
bash-4.2#
Please guys help me to come out from this issue,
S.Titus.
