I'm using Beagleboard XM.
I tried to compile the u-boot and Linux bundled inside ti-sdk-beagleboard-05.03.02.00.
My Ubuntu is running under VMware with Windows XP host. when I've setup everything and installed the Sitara Linux SDK according to the user guide, I tried to compile the u-boot and Linux inside the sdk.
I followed the commands in the SDK, so that the path of the system (checked by echo $PATH) is: /home/elvinw/ti-sdk-beagleboard-05.03.02.00/linux-devkit/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
Then I issued the command under the u-boot folder:
elvinw@ubuntu:~/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03$ sudo make O=beagleboard CROSS_COMPILE=arm-arago-linux-gnueabi- ARCH=arm omap3_beagle
It couldn't get through and reported the following errors:
/bin/bash: arm-arago-linux-gnueabi-gcc: command not found
dirname: missing operand
Try `dirname --help' for more information.
Configuring for omap3_beagle board...
make
make[1]: Entering directory `/home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03'
Generating /home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/beagleboard/include/autoconf.mk
/bin/bash: line 3: arm-arago-linux-gnueabi-gcc: command not found
Generating /home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/beagleboard/include/autoconf.mk.dep
make[1]: Leaving directory `/home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03'
/bin/bash: arm-arago-linux-gnueabi-ld: command not found
arm-arago-linux-gnueabi-gcc -DDO_DEPS_ONLY \
-g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -I/home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/beagleboard/include2 -I/home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/beagleboard/include -I/home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/include -fno-builtin -ffreestanding -nostdinc -isystem -pipe -DCONFIG_ARM -D__ARM__ -march=armv5 -Wall -Wstrict-prototypes \
-o /home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/beagleboard/lib/asm-offsets.s /home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/lib/asm-offsets.c -c -S
make[1]: *** [/home/elvinw/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03/beagleboard/lib/asm-offsets.s] Error 127
make: *** [omap3_beagle] Error 2
I don't know why it reported so many times "bin/bash: arm-arago-linux-gnueabi-gcc: command not found" and "dirname: missing operand".
If I issued the command arm-arago-linux-gnueabi-gcc at the command prompt, it can respond accordingly and so I am sure that the PATH is correct:
elvinw@ubuntu:~/ti-sdk-beagleboard-05.03.02.00/board-support/u-boot-2011.09-psp04.06.00.03$ arm-arago-linux-gnueabi-gcc -v
Using built-in specs.
COLLECT_GCC=arm-arago-linux-gnueabi-gcc
Target: arm-arago-linux-gnueabi
Configured with: /sim/scratch_a0850442/arago-tmp-arago/work/i686-armv7a-sdk-arago-linux-gnueabi/gcc-cross-sdk-4.5-r41.2+svnr170880/gcc-4_5-branch/configure --build=i686-linux --host=i686-linux --target=arm-arago-linux-gnueabi --prefix=/arago-2011.09/armv7a --exec_prefix=/arago-2011.09/armv7a --bindir=/arago-2011.09/armv7a/bin --sbindir=/arago-2011.09/armv7a/bin --libexecdir=/arago-2011.09/armv7a/libexec --datadir=/arago-2011.09/armv7a/share --sysconfdir=/arago-2011.09/armv7a/etc --sharedstatedir=/arago-2011.09/armv7a/share/com --localstatedir=/arago-2011.09/armv7a/var --libdir=/arago-2011.09/armv7a/lib --includedir=/arago-2011.09/armv7a/include --oldincludedir=/arago-2011.09/armv7a/include --infodir=/arago-2011.09/armv7a/share/info --mandir=/arago-2011.09/armv7a/share/man --enable-largefile --disable-nls --enable-ipv6 --with-gnu-ld --enable-shared --enable-languages=c,c++,objc,fortran --enable-threads=posix --disable-multilib --enable-c99 --enable-long-long --enable-symvers=gnu --enable-libstdcxx-pch --program-prefix=arm-arago-linux-gnueabi- --enable-target-optspace --enable-lto --enable-libssp --disable-bootstrap --disable-libgomp --disable-libmudflap --with-float=softfp --with-sysroot=/arago-2011.09/armv7a/arm-arago-linux-gnueabi --with-build-time-tools=/sim/scratch_a0850442/arago-tmp-arago/sysroots/i686-linux/usr/armv7a/arm-arago-linux-gnueabi/bin --with-build-sysroot=/sim/scratch_a0850442/arago-tmp-arago/sysroots/armv7a-arago-linux-gnueabi --disable-libunwind-exceptions --with-mpfr=/sim/scratch_a0850442/arago-tmp-arago/sysroots/i686-linux/usr --with-system-zlib --enable-__cxa_atexit
Thread model: posix
gcc version 4.5.3 20110311 (prerelease) (GCC)
Anybody can advise me what I can do to fix the problem?
Cheers,
Elvin
