Other Parts Discussed in Thread: TVP5151, TVP5150,
Tool/software: Linux
Hello, I have a big issue with with omap3 ISP driver. I'm trying to capture frames from different CCD sensors and analog video to digital converter; in my cases the TVP5151 and OV7670.
INFO
Linux Kernel : 4.13.
Capture Driver: omap3 ISP
Sensors: TVP5150, OV7670
The sensor probing seems to be correct for both of the CCD, the media PADS and ENTITYs are correctly generated and links seems to be OK.
Media-ctl -p Output
# media-ctl -p Media controller API version 0.1.0 Media device information ------------------------ driver omap3isp model TI OMAP3 ISP serial bus info hw revision 0xf0 driver version 0.0.0 Device topology - entity 1: OMAP3 ISP CCP2 (2 pads, 2 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 pad0: Sink [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb] <- "OMAP3 ISP CCP2 input":0 [] pad1: Source [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb] -> "OMAP3 ISP CCDC":0 [] - entity 4: OMAP3 ISP CCP2 input (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video0 pad0: Source -> "OMAP3 ISP CCP2":0 [] - entity 8: OMAP3 ISP CSI2a (2 pads, 2 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 pad0: Sink [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb] pad1: Source [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb] -> "OMAP3 ISP CSI2a output":0 [] -> "OMAP3 ISP CCDC":0 [] - entity 11: OMAP3 ISP CSI2a output (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video1 pad0: Sink <- "OMAP3 ISP CSI2a":1 [] - entity 15: OMAP3 ISP CCDC (3 pads, 9 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev2 pad0: Sink [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb] <- "OMAP3 ISP CCP2":1 [] <- "OMAP3 ISP CSI2a":1 [] <- "ov7670 1-0021":0 [ENABLED] pad1: Source [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb crop.bounds:(0,0)/4096x4096 crop:(0,0)/4096x4096] -> "OMAP3 ISP CCDC output":0 [] -> "OMAP3 ISP resizer":0 [] pad2: Source [fmt:SGRBG10_1X10/4096x4095 field:none colorspace:srgb] -> "OMAP3 ISP preview":0 [ENABLED] -> "OMAP3 ISP AEWB":0 [ENABLED,IMMUTABLE] -> "OMAP3 ISP AF":0 [ENABLED,IMMUTABLE] -> "OMAP3 ISP histogram":0 [ENABLED,IMMUTABLE] - entity 19: OMAP3 ISP CCDC output (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video2 pad0: Sink <- "OMAP3 ISP CCDC":1 [] - entity 23: OMAP3 ISP preview (2 pads, 4 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev3 pad0: Sink [fmt:SGRBG10_1X10/4096x4096 field:none colorspace:srgb crop.bounds:(10,4)/4078x4088 crop:(8,4)/4082x4088] <- "OMAP3 ISP CCDC":2 [ENABLED] <- "OMAP3 ISP preview input":0 [] pad1: Source [fmt:UYVY8_1X16/4082x4088 field:none colorspace:jpeg] -> "OMAP3 ISP preview output":0 [ENABLED] -> "OMAP3 ISP resizer":0 [] - entity 26: OMAP3 ISP preview input (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Source -> "OMAP3 ISP preview":0 [] - entity 30: OMAP3 ISP preview output (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "OMAP3 ISP preview":1 [ENABLED] - entity 34: OMAP3 ISP resizer (2 pads, 4 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev4 pad0: Sink [fmt:YUYV8_1X16/4095x4095 field:none colorspace:jpeg crop.bounds:(4,6)/4086x4082 crop:(4,6)/4086x4082] <- "OMAP3 ISP CCDC":1 [] <- "OMAP3 ISP preview":1 [] <- "OMAP3 ISP resizer input":0 [] pad1: Source [fmt:YUYV8_1X16/4096x4095 field:none colorspace:jpeg] -> "OMAP3 ISP resizer output":0 [] - entity 37: OMAP3 ISP resizer input (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Source -> "OMAP3 ISP resizer":0 [] - entity 41: OMAP3 ISP resizer output (1 pad, 1 link) type Node subtype V4L flags 1 device node name /dev/video6 pad0: Sink <- "OMAP3 ISP resizer":1 [] - entity 45: OMAP3 ISP AEWB (1 pad, 1 link) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev5 pad0: Sink <- "OMAP3 ISP CCDC":2 [ENABLED,IMMUTABLE] - entity 47: OMAP3 ISP AF (1 pad, 1 link) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev6 pad0: Sink <- "OMAP3 ISP CCDC":2 [ENABLED,IMMUTABLE] - entity 49: OMAP3 ISP histogram (1 pad, 1 link) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev7 pad0: Sink <- "OMAP3 ISP CCDC":2 [ENABLED,IMMUTABLE] - entity 81: ov7670 1-0021 (1 pad, 1 link) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev8 pad0: Source [fmt:SBGGR8_1X8/320x240 field:none colorspace:srgb] -> "OMAP3 ISP CCDC":0 [ENABLED]
but when i try to capture frames from sensors whit v4l capture applications like YAVTA, or FFPLAY it give me this error:
FFPLAY output
# DISPLAY=:0 ffplay -i /dev/video4 ffplay version 3.4.2 Copyright (c) 2003-2018 the FFmpeg developers built with gcc 4.9.4 (Buildroot 2018.02-rc2-00018-g38d8d86) configuration: --enable-cross-compile --cross-prefix=/home/prog/logic/buildroot/output/host/bin/arm-buildroot-linux-gnueabihf- --sysroot=/home/prog/logic/buildroot/output/host/arm-buildroot-linux-gnueabihf/sysroot --host-cc='/home/prog/logic/buildroot/output/host/bin/ccache /usr/bin/gcc' --arch=arm --target-os=linux --disable-stripping --pkg-config=/home/prog/logic/buildroot/output/host/bin/pkg-config --disable-static --enable-shared --prefix=/usr --enable-avfilter --disable-version3 --enable-logging --enable-optimizations --disable-extra-warnings --enable-avdevice --enable-avcodec --enable-avformat --enable-network --disable-gray --enable-swscale-alpha --disable-small --enable-dct --enable-fft --enable-mdct --enable-rdft --disable-crystalhd --disable-dxva2 --enable-runtime-cpudetect --disable-hardcoded-tables --disable-mipsdsp --disable-mipsdspr2 --disable-msa --enable-hwaccels --disable-cuda --disable-cuvid --disable-nvenc --disable-avisynth --disable-frei0r --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libcdio --disable-libdc1394 --disable-libgsm --disable-libilbc --disable-libvo-amrwbenc --disable-symver --disable-doc --enable-gpl --enable-nonfree --enable-ffmpeg --enable-ffplay --enable-ffserver --disable-avresample --enable-ffprobe --disable-postproc --enable-swscale --enable-indevs --enable-alsa --enable-outdevs --enable-pthreads --enable-zlib --disable-bzlib --disable-libfdk-aac --disable-gnutls --enable-openssl --disable-libopenh264 --enable-libvorbis --enable-muxer=ogg --enable-encoder=libvorbis --enable-vaapi --disable-vdpau --disable-mmal --disable-omx --disable-omx-rpi --disable-libopencv --disable-libopus --disable-libvpx --disable-libass --disable-libbluray --disable-librtmp --disable-libmp3lame --disable-libmodplug --enable-libspeex --enable-libtheora --disable-libwavpack --disable-iconv --enable-libfreetype --enable-fontconfig --disable-libopenjpeg --disable-libx264 --disable-libx265 --disable-x86asm --disable-mmx --disable-sse --disable-sse2 --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --disable-avx --disable-avx2 --enable-armv6 --enable-vfp --enable-neon --disable-altivec --extra-libs=-latomic --enable-pic --cpu=cortex-a8 libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 Failed to initialize a hardware accelerated renderer: Couldn't find matching render driver [video4linux2,v4l2 @ 0xb30005f0] [IMGUTILS @ 0xb39fc7b4] Picture size 0x0 is invalid /dev/video4: Invalid argument nan : 0.000 fd= 0 aq= 0KB vq= 0KB sq= 0B f=0/0
OR , if i try to set the size and the framerate:
# DISPLAY=:0 ffplay -i /dev/video4 -s 320x240 -framerate 10 ffplay version 3.4.2 Copyright (c) 2003-2018 the FFmpeg developers built with gcc 4.9.4 (Buildroot 2018.02-rc2-00018-g38d8d86) configuration: --enable-cross-compile --cross-prefix=/home/prog/logic/buildroot/output/host/bin/arm-buildroot-linux-gnueabihf- --sysroot=/home/prog/logic/buildroot/output/host/arm-buildroot-linux-gnueabihf/sysroot --host-cc='/home/prog/logic/buildroot/output/host/bin/ccache /usr/bin/gcc' --arch=arm --target-os=linux --disable-stripping --pkg-config=/home/prog/logic/buildroot/output/host/bin/pkg-config --disable-static --enable-shared --prefix=/usr --enable-avfilter --disable-version3 --enable-logging --enable-optimizations --disable-extra-warnings --enable-avdevice --enable-avcodec --enable-avformat --enable-network --disable-gray --enable-swscale-alpha --disable-small --enable-dct --enable-fft --enable-mdct --enable-rdft --disable-crystalhd --disable-dxva2 --enable-runtime-cpudetect --disable-hardcoded-tables --disable-mipsdsp --disable-mipsdspr2 --disable-msa --enable-hwaccels --disable-cuda --disable-cuvid --disable-nvenc --disable-avisynth --disable-frei0r --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libcdio --disable-libdc1394 --disable-libgsm --disable-libilbc --disable-libvo-amrwbenc --disable-symver --disable-doc --enable-gpl --enable-nonfree --enable-ffmpeg --enable-ffplay --enable-ffserver --disable-avresample --enable-ffprobe --disable-postproc --enable-swscale --enable-indevs --enable-alsa --enable-outdevs --enable-pthreads --enable-zlib --disable-bzlib --disable-libfdk-aac --disable-gnutls --enable-openssl --disable-libopenh264 --enable-libvorbis --enable-muxer=ogg --enable-encoder=libvorbis --enable-vaapi --disable-vdpau --disable-mmal --disable-omx --disable-omx-rpi --disable-libopencv --disable-libopus --disable-libvpx --disable-libass --disable-libbluray --disable-librtmp --disable-libmp3lame --disable-libmodplug --enable-libspeex --enable-libtheora --disable-libwavpack --disable-iconv --enable-libfreetype --enable-fontconfig --disable-libopenjpeg --disable-libx264 --disable-libx265 --disable-x86asm --disable-mmx --disable-sse --disable-sse2 --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --disable-avx --disable-avx2 --enable-armv6 --enable-vfp --enable-neon --disable-altivec --extra-libs=-latomic --enable-pic --cpu=cortex-a8 libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 Option -s is deprecated, use -video_size. Failed to initialize a hardware accelerated renderer: Couldn't find matching render driver [video4linux2,v4l2 @ 0xb30005f0] ioctl(VIDIOC_G_PARM): Invalid argument [video4linux2,v4l2 @ 0xb30005f0] Time per frame unknown [video4linux2,v4l2 @ 0xb30005f0] ioctl(VIDIOC_STREAMON): Broken pipe /dev/video4: Broken pipe [ 457.957550] vb2: counters for queue ce3d5040, buffer 0: UNBALANCED! [ 457.964447] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 457.971893] vb2: buf_queue: 0 buf_done: 0 [ 457.976440] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 457.982849] vb2: get_userptr: 0 put_userptr: 0 [ 457.987854] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 457.995971] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.002471] vb2: counters for queue ce3d5040, buffer 1: UNBALANCED! [ 458.009216] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.016601] vb2: buf_queue: 0 buf_done: 0 [ 458.021148] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.027557] vb2: get_userptr: 0 put_userptr: 0 [ 458.032592] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.040679] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.047180] vb2: counters for queue ce3d5040, buffer 2: UNBALANCED! [ 458.053924] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.061309] vb2: buf_queue: 0 buf_done: 0 [ 458.065887] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.072265] vb2: get_userptr: 0 put_userptr: 0 [ 458.077270] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.085449] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.091949] vb2: counters for queue ce3d5040, buffer 3: UNBALANCED! [ 458.098663] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.106079] vb2: buf_queue: 0 buf_done: 0 [ 458.110626] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.117004] vb2: get_userptr: 0 put_userptr: 0 [ 458.122039] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.130157] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.136627] vb2: counters for queue ce3d5040, buffer 4: UNBALANCED! [ 458.143402] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.150756] vb2: buf_queue: 0 buf_done: 0 [ 458.155334] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.161743] vb2: get_userptr: 0 put_userptr: 0 [ 458.166748] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.174865] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.181335] vb2: counters for queue ce3d5040, buffer 5: UNBALANCED! [ 458.188079] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.195495] vb2: buf_queue: 0 buf_done: 0 [ 458.200042] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.206451] vb2: get_userptr: 0 put_userptr: 0 [ 458.211456] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.219573] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.226074] vb2: counters for queue ce3d5040, buffer 6: UNBALANCED! [ 458.232818] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.240173] vb2: buf_queue: 0 buf_done: 0 [ 458.244781] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.251129] vb2: get_userptr: 0 put_userptr: 0 [ 458.256195] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.264312] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.270782] vb2: counters for queue ce3d5040, buffer 7: UNBALANCED! [ 458.277526] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.284912] vb2: buf_queue: 0 buf_done: 0 [ 458.289489] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.295867] vb2: get_userptr: 0 put_userptr: 0 [ 458.300872] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.309020] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.315490] vb2: counters for queue ce3d5040, buffer 8: UNBALANCED! [ 458.322265] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.329620] vb2: buf_queue: 0 buf_done: 0 [ 458.334197] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.340576] vb2: get_userptr: 0 put_userptr: 0 [ 458.345611] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.353729] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.360198] vb2: counters for queue ce3d5040, buffer 9: UNBALANCED! [ 458.366943] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.374359] vb2: buf_queue: 0 buf_done: 0 [ 458.378906] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.385284] vb2: get_userptr: 0 put_userptr: 0 [ 458.390289] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.398437] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.404907] vb2: counters for queue ce3d5040, buffer 10: UNBALANCED! [ 458.411773] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.419128] vb2: buf_queue: 0 buf_done: 0 [ 458.423706] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.430084] vb2: get_userptr: 0 put_userptr: 0 [ 458.435119] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.443237] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.449707] vb2: counters for queue ce3d5040, buffer 11: UNBALANCED! [ 458.456542] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.463928] vb2: buf_queue: 0 buf_done: 0 [ 458.468505] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.474884] vb2: get_userptr: 0 put_userptr: 0 [ 458.479888] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.488037] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.494506] vb2: counters for queue ce3d5040, buffer 12: UNBALANCED! [ 458.501342] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.508728] vb2: buf_queue: 0 buf_done: 0 [ 458.513305] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.519683] vb2: get_userptr: 0 put_userptr: 0 [ 458.524719] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.532836] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.539306] vb2: counters for queue ce3d5040, buffer 13: UNBALANCED! [ 458.546173] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.553558] vb2: buf_queue: 0 buf_done: 0 [ 458.558105] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.564514] vb2: get_userptr: 0 put_userptr: 0 [ 458.569519] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.577636] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.584136] vb2: counters for queue ce3d5040, buffer 14: UNBALANCED! [ 458.590972] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.598388] vb2: buf_queue: 0 buf_done: 0 [ 458.602966] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.609344] vb2: get_userptr: 0 put_userptr: 0 [ 458.614379] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.622497] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.628967] vb2: counters for queue ce3d5040, buffer 15: UNBALANCED! [ 458.635833] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.643249] vb2: buf_queue: 0 buf_done: 0 [ 458.647796] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.654205] vb2: get_userptr: 0 put_userptr: 0 [ 458.659210] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.667327] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.673828] vb2: counters for queue ce3d5040, buffer 16: UNBALANCED! [ 458.680664] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.688079] vb2: buf_queue: 0 buf_done: 0 [ 458.692657] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.699035] vb2: get_userptr: 0 put_userptr: 0 [ 458.704071] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.712188] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.718658] vb2: counters for queue ce3d5040, buffer 17: UNBALANCED! [ 458.725524] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.732940] vb2: buf_queue: 0 buf_done: 0 [ 458.737487] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.743896] vb2: get_userptr: 0 put_userptr: 0 [ 458.748901] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.757049] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.763519] vb2: counters for queue ce3d5040, buffer 18: UNBALANCED! [ 458.770355] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.777770] vb2: buf_queue: 0 buf_done: 0 [ 458.782348] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.788726] vb2: get_userptr: 0 put_userptr: 0 [ 458.793762] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.801910] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.808380] vb2: counters for queue ce3d5040, buffer 19: UNBALANCED! [ 458.815246] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.822631] vb2: buf_queue: 0 buf_done: 0 [ 458.827178] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.833587] vb2: get_userptr: 0 put_userptr: 0 [ 458.838623] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.846740] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.853240] vb2: counters for queue ce3d5040, buffer 20: UNBALANCED! [ 458.860076] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.867462] vb2: buf_queue: 0 buf_done: 0 [ 458.872070] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.878417] vb2: get_userptr: 0 put_userptr: 0 [ 458.883483] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.891601] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.898071] vb2: counters for queue ce3d5040, buffer 21: UNBALANCED! [ 458.904937] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.912353] vb2: buf_queue: 0 buf_done: 0 [ 458.916900] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.923309] vb2: get_userptr: 0 put_userptr: 0 [ 458.928314] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.936462] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.942932] vb2: counters for queue ce3d5040, buffer 22: UNBALANCED! [ 458.949768] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 458.957183] vb2: buf_queue: 0 buf_done: 0 [ 458.961761] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 458.968139] vb2: get_userptr: 0 put_userptr: 0 [ 458.973175] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 458.981292] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 458.987762] vb2: counters for queue ce3d5040, buffer 23: UNBALANCED! [ 458.994628] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.002044] vb2: buf_queue: 0 buf_done: 0 [ 459.006591] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.013000] vb2: get_userptr: 0 put_userptr: 0 [ 459.018005] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.026153] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.032653] vb2: counters for queue ce3d5040, buffer 24: UNBALANCED! [ 459.039459] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.046874] vb2: buf_queue: 0 buf_done: 0 [ 459.051452] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.057861] vb2: get_userptr: 0 put_userptr: 0 [ 459.062896] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.070983] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.077484] vb2: counters for queue ce3d5040, buffer 25: UNBALANCED! [ 459.084350] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.091766] vb2: buf_queue: 0 buf_done: 0 [ 459.096313] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.102722] vb2: get_userptr: 0 put_userptr: 0 [ 459.107727] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.115875] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.122344] vb2: counters for queue ce3d5040, buffer 26: UNBALANCED! [ 459.129180] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.136596] vb2: buf_queue: 0 buf_done: 0 [ 459.141143] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.147552] vb2: get_userptr: 0 put_userptr: 0 [ 459.152587] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.160705] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.167205] vb2: counters for queue ce3d5040, buffer 27: UNBALANCED! [ 459.174041] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.181427] vb2: buf_queue: 0 buf_done: 0 [ 459.186004] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.192413] vb2: get_userptr: 0 put_userptr: 0 [ 459.197418] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.205566] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.212066] vb2: counters for queue ce3d5040, buffer 28: UNBALANCED! [ 459.218872] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.226287] vb2: buf_queue: 0 buf_done: 0 [ 459.230834] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.237243] vb2: get_userptr: 0 put_userptr: 0 [ 459.242279] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.250396] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.256896] vb2: counters for queue ce3d5040, buffer 29: UNBALANCED! [ 459.263763] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.271118] vb2: buf_queue: 0 buf_done: 0 [ 459.275726] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.282104] vb2: get_userptr: 0 put_userptr: 0 [ 459.287139] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.295257] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.301757] vb2: counters for queue ce3d5040, buffer 30: UNBALANCED! [ 459.308593] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.315979] vb2: buf_queue: 0 buf_done: 0 [ 459.320526] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.326934] vb2: get_userptr: 0 put_userptr: 0 [ 459.331970] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.340057] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1 [ 459.346557] vb2: counters for queue ce3d5040, buffer 31: UNBALANCED! [ 459.353393] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 1 buf_finish: 1 [ 459.360748] vb2: buf_queue: 0 buf_done: 0 [ 459.365356] vb2: alloc: 1 put: 1 prepare: 1 finish: 0 mmap: 1 [ 459.371734] vb2: get_userptr: 0 put_userptr: 0 [ 459.376739] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0 [ 459.384857] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 1
The same scenario with TVP5151.
I'm really stuck.....
THANKS TOMMASO.
