Hi ,
I am trying to execute some sample OpenCV examples on 8148 hardware .
I followed below link to build OpenCV for ARM Cortex-A8 -
http://processors.wiki.ti.com/index.php/Building_OpenCV_for_ARM_Cortex-A8
But when I am trying to run ,am getting following errors like "Can not connect to X server "
I checked the x server log file .
PFB log file -
module ABI major version (12) doesn't match the server's versi on (11): [ 1140.525] X.Org X Server 1.11.3 Release Date: 2011-12-16 [ 1140.525] X Protocol Version 11, Revision 0 [ 1140.525] Build Operating System: Linux 2.6.42-51-highbank armv7l Ubuntu [ 1140.525] Current Operating System: Linux localhost.localdomain 2.6.37 #1 Tue Jul 8 16:49:39 IST 2014 armv7l [ 1140.525] Kernel command line: console=ttyO0,115200n8 noinitrd rw ethaddr=10. 60.4.222 ip=dhcp root=/dev/nfs nfsroot=10.60.4.135:/home/ppc/Downloads/armel_ubu ntu,nolock, mem=128M vram=50M ti814xfb.vram=0:48M,1:1M,2:1M notifyk.vpssm3_sva=0 xA0000000 omapdss.def_disp="hdmi" [ 1140.533] Build Date: 16 October 2013 04:40:01PM [ 1140.534] xorg-server 2:1.11.4-0ubuntu10.14 (For technical support please see http://www.ubuntu.com/support) [ 1140.534] Current version of pixman: 0.30.2 [ 1140.534] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 1140.534] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 1140.547] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 1 00:19:00 197 0 [ 1140.555] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 1140.560] (==) No Layout section. Using the first Screen section. [ 1140.560] (==) No screen section available. Using defaults. [ 1140.560] (**) |-->Screen "Default Screen Section" (0) [ 1140.560] (**) | |-->Monitor "<default monitor>" [ 1140.562] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 1140.562] (==) Automatically adding devices [ 1140.562] (==) Automatically enabling devices [ 1140.563] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 1140.563] Entry deleted from font path. [ 1140.563] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 1140.563] Entry deleted from font path. [ 1140.564] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 1140.564] Entry deleted from font path. [ 1140.564] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 1140.565] Entry deleted from font path. [ 1140.565] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 1140.565] Entry deleted from font path. [ 1140.565] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueTyp e" does not exist. [ 1140.566] Entry deleted from font path. [ 1140.566] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/Type1, built-ins [ 1140.566] (==) ModulePath set to "/usr/lib/arm-linux-gnueabi/xorg/extra-modul es,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules" [ 1140.566] (II) The server relies on udev to provide the list of input devices . If no devices become available, reconfigure udev or disable AutoAddDevic es. [ 1140.566] (II) Loader magic: 0x40159d00 [ 1140.566] (II) Module ABI versions: [ 1140.566] X.Org ANSI C Emulation: 0.4 [ 1140.566] X.Org Video Driver: 11.0 [ 1140.566] X.Org XInput driver : 16.0 [ 1140.566] X.Org Server Extension : 6.0 [ 1140.566] (II) LoadModule: "extmod" [ 1140.576] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so [ 1140.585] (II) Module extmod: vendor="X.Org Foundation" [ 1140.585] compiled for 1.11.3, module version = 1.0.0 [ 1140.585] Module class: X.Org Server Extension [ 1140.585] ABI class: X.Org Server Extension, version 6.0 [ 1140.585] (II) Loading extension MIT-SCREEN-SAVER [ 1140.585] (II) Loading extension XFree86-VidModeExtension [ 1140.585] (II) Loading extension XFree86-DGA [ 1140.585] (II) Loading extension DPMS [ 1140.585] (II) Loading extension XVideo [ 1140.585] (II) Loading extension XVideo-MotionCompensation [ 1140.585] (II) Loading extension X-Resource [ 1140.585] (II) LoadModule: "dbe" [ 1140.587] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so [ 1140.590] (II) Module dbe: vendor="X.Org Foundation" [ 1140.590] compiled for 1.11.3, module version = 1.0.0 [ 1140.590] Module class: X.Org Server Extension [ 1140.591] ABI class: X.Org Server Extension, version 6.0 [ 1140.591] (II) Loading extension DOUBLE-BUFFER [ 1140.591] (II) LoadModule: "glx" [ 1140.593] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 1140.616] (II) Module glx: vendor="X.Org Foundation" [ 1140.616] compiled for 1.11.3, module version = 1.0.0 [ 1140.616] ABI class: X.Org Server Extension, version 6.0 [ 1140.616] (==) AIGLX enabled [ 1140.616] (II) Loading extension GLX [ 1140.616] (II) LoadModule: "record" [ 1140.618] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so [ 1140.622] (II) Module record: vendor="X.Org Foundation" [ 1140.622] compiled for 1.11.3, module version = 1.13.0 [ 1140.622] Module class: X.Org Server Extension [ 1140.622] ABI class: X.Org Server Extension, version 6.0 [ 1140.622] (II) Loading extension RECORD [ 1140.622] (II) LoadModule: "dri" [ 1140.624] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so [ 1140.630] (II) Module dri: vendor="X.Org Foundation" [ 1140.630] compiled for 1.11.3, module version = 1.0.0 [ 1140.630] ABI class: X.Org Server Extension, version 6.0 [ 1140.630] (II) Loading extension XFree86-DRI [ 1140.630] (II) LoadModule: "dri2" [ 1140.632] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so [ 1140.635] (II) Module dri2: vendor="X.Org Foundation" [ 1140.635] compiled for 1.11.3, module version = 1.2.0 [ 1140.635] ABI class: X.Org Server Extension, version 6.0 [ 1140.636] (II) Loading extension DRI2 [ 1140.636] (==) Matched pvr as autoconfigured driver 0 [ 1140.636] (==) Matched fbdev as autoconfigured driver 1 [ 1140.636] (==) Assigned the driver to the xf86ConfigLayout [ 1140.636] (II) LoadModule: "pvr" [ 1140.641] (II) Loading /usr/lib/xorg/modules/drivers/pvr_drv.so [ 1140.751] (II) Module PVR: vendor="X.Org Foundation" [ 1140.751] compiled for 1.12.0, module version = 110.235.9475 [ 1140.751] Module class: X.Org Video Driver [ 1140.752] ABI class: X.Org Video Driver, version 12.0 [ 1140.752] (EE) module ABI major version (12) doesn't match the server's version (11) [ 1140.752] (II) UnloadModule: "pvr" [ 1140.752] (II) Unloading pvr [ 1140.752] (EE) Failed to load module "pvr" (module requirement mismatch, 0) [ 1140.752] (II) LoadModule: "fbdev" [ 1140.755] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 1140.759] (II) Module fbdev: vendor="X.Org Foundation" [ 1140.759] compiled for 1.11.3, module version = 0.4.2 [ 1140.759] ABI class: X.Org Video Driver, version 11.0 [ 1140.759] (==) Matched pvr as autoconfigured driver 0 [ 1140.759] (==) Matched fbdev as autoconfigured driver 1 [ 1140.759] (==) Assigned the driver to the xf86ConfigLayout [ 1140.759] (II) LoadModule: "pvr" [ 1140.763] (II) Loading /usr/lib/xorg/modules/drivers/pvr_drv.so [ 1140.763] (II) Module PVR: vendor="X.Org Foundation" [ 1140.763] compiled for 1.12.0, module version = 110.235.9475 [ 1140.763] Module class: X.Org Video Driver [ 1140.763] ABI class: X.Org Video Driver, version 12.0 [ 1140.763] (EE) module ABI major version (12) doesn't match the server's versi on (11) [ 1140.763] (II) UnloadModule: "pvr" [ 1140.763] (II) Unloading pvr [ 1140.763] (EE) Failed to load module "pvr" (module requirement mismatch, 0) [ 1140.763] (II) LoadModule: "fbdev" [ 1140.766] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 1140.766] (II) Module fbdev: vendor="X.Org Foundation" [ 1140.766] compiled for 1.11.3, module version = 0.4.2 [ 1140.766] ABI class: X.Org Video Driver, version 11.0 [ 1140.766] (II) UnloadModule: "fbdev" [ 1140.767] (II) Unloading fbdev [ 1140.767] (II) Failed to load module "fbdev" (already loaded, 0) [ 1140.767] (II) FBDEV: driver for framebuffer: fbdev [ 1140.767] (--) using VT number 8 [ 1140.767] (WW) Falling back to old probe method for fbdev [ 1140.768] (II) Loading sub module "fbdevhw" [ 1140.768] (II) LoadModule: "fbdevhw" [ 1140.771] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 1140.774] (II) Module fbdevhw: vendor="X.Org Foundation" [ 1140.774] compiled for 1.11.3, module version = 0.0.2 [ 1140.774] ABI class: X.Org Video Driver, version 11.0 [ 1140.889] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 1140.889] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 1140.890] (II) FBDEV(0): using default device [ 1140.890] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 1140.955] (II) FBDEV(0): Creating default Display subsection in Screen sectio n "Default Screen Section" for depth/fbbpp 24/32 [ 1140.955] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32 [ 1140.955] (==) FBDEV(0): RGB weight 888 [ 1140.955] (==) FBDEV(0): Default visual is TrueColor [ 1140.955] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0) [ 1140.955] (II) FBDEV(0): hardware: ti81xxfb (video memory: 24576kB) [ 1140.955] (II) FBDEV(0): checking modes against framebuffer device... [ 1140.955] (II) FBDEV(0): checking modes against monitor... [ 1140.955] (--) FBDEV(0): Virtual size is 1920x1080 (pitch 1920) [ 1140.955] (**) FBDEV(0): Built-in mode "current": 148.5 MHz, 67.5 kHz, 60.0 Hz [ 1140.955] (II) FBDEV(0): Modeline "current"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync -csync (67.5 kHz) [ 1140.955] (==) FBDEV(0): DPI set to (96, 96) [ 1140.955] (II) Loading sub module "fb" [ 1140.956] (II) LoadModule: "fb" [ 1140.959] (II) Loading /usr/lib/xorg/modules/libfb.so [ 1140.969] (II) Module fb: vendor="X.Org Foundation" [ 1140.969] compiled for 1.11.3, module version = 1.0.0 [ 1140.969] ABI class: X.Org ANSI C Emulation, version 0.4 [ 1140.969] (**) FBDEV(0): using shadow framebuffer [ 1140.969] (II) Loading sub module "shadow" [ 1140.969] (II) LoadModule: "shadow" [ 1140.973] (II) Loading /usr/lib/xorg/modules/libshadow.so [ 1140.976] (II) Module shadow: vendor="X.Org Foundation" [ 1140.976] compiled for 1.11.3, module version = 1.1.0 [ 1140.976] ABI class: X.Org ANSI C Emulation, version 0.4 [ 1140.976] (==) Depth 24 pixmap format is 32 bpp [ 1141.022] (EE) FBDEV(0): Failed to allocate shadow framebuffer [ 1141.022] Fatal server error: [ 1141.022] AddScreen/ScreenInit failed for driver 0 [ 1141.022] [ 1141.022] Please consult the The X.Org Foundation support at http://wiki.x.org for help. [ 1141.022] Please also check the log file at "/var/log/Xorg.0.log" for additio nal information. [ 1141.022] [ 1141.024] ddxSigGiveUp: Closing log [ 1141.024] Server terminated with error (1). Closing log file.
Can you help me in resolving OpenCV on 8148 issue ??
Tr,
studinstru
