I have simple question.
According to the AM3874 datasheet (SPRS695C) p.296,
Table 8-72. High-Speed Bypass Capacitors
(4) Three of these capacitors should be located underneath the processor, between the cluster of DDR_1V5 balls and ground balls,between the DDR interfaces on the package.
What are "three of these capacitors"? Is it pointed out the HS bypass capacitors? The data sheet recommends to use minimum 35 pcs HS bypass capacitors in around processor. "three of these capacitors" means "three of HS bypass capacitors?
Please let me know.
Michi
