Hi all
I am using DVRRDK_04.01.00.02 with DM8168X_UD_DVR.
how to divided a 4K reslution(3840*2160) H264 video into 4 parts with 1080P(1920*1080) reslution H264 video.
Hi all
Not sure if the scaler can handle that resolution in the input, if it does you could use the crop feature, something like:
https://developer.ridgerun.com/wiki/index.php/Video_crop_and_scaling_with_DM816x_and_DM814x#Video_crop_in_the_scaling_stage
-David
Passing the 4K stream thru MpSclr will result in scaling the image to 1920x1080.
If you want to avoid this pls use below data flow:
Decode -> Dup (4 output queues) -> Merge (single output queue 4 channels) -> MpSclr -> SWMS
The MpSclr should be configured for forwarding (Link control cmd MP_SCLR_LINK_CMD_SET_HMPCH_FORWARD)
The SwMs should be configured for cropping on HMP stream (Link control cmd SYSTEM_SW_MS_LINK_CMD_SET_HMPCH_INPUT_CROP)
Refer the link API documentation for these cmds for associated param details.
You will still be able to display only 2 potions on the image on 2 1080P displays.
I don't see how you can display the other 2 portions. Can you indicate what you intend to do after spliiting into 4 parts.
