In dvsdk_1_01_00_15 or dvsdk_1_11_00_00, viedo_preview is a demo.
In this demo, there is a function called video_preview(), which is showed at the last of the post. And this function is called in the PreviewTask of DSP/BIOS, working well.
I modified this demo. Now calling video_preview() function manual in main() function, but no display.
I feel puzzle, Is there any wrong ?
/* * ======== video_preview ======== */ void video_preview(void) { FVID_Frame *frameBuffTable[FRAME_BUFF_CNT]; FVID_Frame *frameBuffPtr; GIO_Handle hGioVpfeCcdc; GIO_Handle hGioVpbeVid0; GIO_Handle hGioVpbeVenc; int status = 0; int result; int i; int standard; int width; int height; /* Set video display/capture driver params to defaults */ PSP_VPFE_TVP5146_ConfigParams tvp5146Params = VID_PARAMS_TVP5146_DEFAULT; PSP_VPFECcdcConfigParams vpfeCcdcConfigParams = VID_PARAMS_CCDC_DEFAULT_D1; PSP_VPBEOsdConfigParams vpbeOsdConfigParams = VID_PARAMS_OSD_DEFAULT_D1; PSP_VPBEVencConfigParams vpbeVencConfigParams; standard = read_JP1(); /* Update display/capture params based on video standard (PAL/NTSC) */ if (standard == STANDARD_PAL) { width = 720; height = 576; vpbeVencConfigParams.displayStandard = PSP_VPBE_DISPLAY_PAL_INTERLACED_COMPOSITE; } else { width = 720; height = 480; vpbeVencConfigParams.displayStandard = PSP_VPBE_DISPLAY_NTSC_INTERLACED_COMPOSITE; } vpfeCcdcConfigParams.height = vpbeOsdConfigParams.height = height; vpfeCcdcConfigParams.width = vpbeOsdConfigParams.width = width; vpfeCcdcConfigParams.pitch = vpbeOsdConfigParams.pitch = width * 2; /* init the frame buffer table */ for (i=0; i<FRAME_BUFF_CNT; i++) { frameBuffTable[i] = NULL; } /* create video input channel */ if (status == 0) { PSP_VPFEChannelParams vpfeChannelParams; vpfeChannelParams.id = PSP_VPFE_CCDC; vpfeChannelParams.params = (PSP_VPFECcdcConfigParams*)&vpfeCcdcConfigParams; hGioVpfeCcdc = FVID_create("/VPFE0",IOM_INOUT,NULL,&vpfeChannelParams,NULL); status = (hGioVpfeCcdc == NULL ? -1 : 0); } /* create video output channel, plane 0 */ if (status == 0) { PSP_VPBEChannelParams vpbeChannelParams; vpbeChannelParams.id = PSP_VPBE_VIDEO_0; vpbeChannelParams.params = (PSP_VPBEOsdConfigParams*)&vpbeOsdConfigParams; hGioVpbeVid0 = FVID_create("/VPBE0",IOM_INOUT,NULL,&vpbeChannelParams,NULL); status = (hGioVpbeVid0 == NULL ? -1 : 0); } /* create video output channel, venc */ if (status == 0) { PSP_VPBEChannelParams vpbeChannelParams; vpbeChannelParams.id = PSP_VPBE_VENC; vpbeChannelParams.params = (PSP_VPBEVencConfigParams *)&vpbeVencConfigParams; hGioVpbeVenc = FVID_create("/VPBE0",IOM_INOUT,NULL,&vpbeChannelParams,NULL); status = (hGioVpbeVenc == NULL ? -1 : 0); } /* configure the TVP5146 video decoder */ if (status == 0) { result = FVID_control(hGioVpfeCcdc, VPFE_ExtVD_BASE+PSP_VPSS_EXT_VIDEO_DECODER_CONFIG, &tvp5146Params); status = (result == IOM_COMPLETED ? 0 : -1); } /* allocate some frame buffers */ if (status == 0) { for (i=0; i<FRAME_BUFF_CNT && status == 0; i++) { result = FVID_allocBuffer(hGioVpfeCcdc, &frameBuffTable[i]); status = (result == IOM_COMPLETED && frameBuffTable[i] != NULL ? 0 : -1); } } /* prime up the video capture channel */ if (status == 0) { FVID_queue(hGioVpfeCcdc, frameBuffTable[0]); FVID_queue(hGioVpfeCcdc, frameBuffTable[1]); FVID_queue(hGioVpfeCcdc, frameBuffTable[2]); } /* prime up the video display channel */ if (status == 0) { FVID_queue(hGioVpbeVid0, frameBuffTable[3]); FVID_queue(hGioVpbeVid0, frameBuffTable[4]); FVID_queue(hGioVpbeVid0, frameBuffTable[5]); } /* grab first buffer from input queue */ if (status == 0) { FVID_dequeue(hGioVpfeCcdc, &frameBuffPtr); } /* loop forever performing video capture and display */ while ( status == 0 ) { /* grab a fresh video input frame */ FVID_exchange(hGioVpfeCcdc, &frameBuffPtr); /* display the video frame */ FVID_exchange(hGioVpbeVid0, &frameBuffPtr); }
