We using TI AISgen tool for creating images for the processor (OMAPL138).
When we load image onto the processor and run it – sometimes we experiencing “crash” of the our device.
But when we load program via J-Tag – crushes do not happen. We are using IAR IDE for ARM code development.
During our system start up we rely on IAR 2475.omap_with_ddr_456MHz.cfg
// ----------------------------------------------------------------------- // This file contains the DDRRAM set up configuration for the TMS470R1B768. // // // Revision : 0.01 JM 2/16/06 // //------------------------------------------------------------------------- CHGBIT (addr, mask, data) { __var reg; reg = __readMemory32(addr, "Memory"); reg &= ~mask; reg |= data; __writeMemory32(reg, addr, "Memory"); } CLRBIT (addr, mask) { __var reg; reg = __readMemory32(addr, "Memory"); reg &= ~mask; __writeMemory32(reg, addr, "Memory"); } SETBIT (addr, mask) { __var reg; reg = __readMemory32(addr, "Memory"); reg |= mask; __writeMemory32(reg, addr, "Memory"); } TESTBIT (addr, mask) { return(__readMemory32(addr, "Memory") & mask); } lpsc0Enable(in_domain, in_module, in_next_state) { __var psc_base; __var reg; __var module_offest; psc_base = 0x01C10000; module_offest = in_module << 2; // spin until existing transitions are done. while(TESTBIT(psc_base + 0x0128,in_domain)); // if we are already in the requested state...just return. if(in_next_state != TESTBIT(psc_base + 0x0800 + module_offest, 0x3F)) // !PSC_ENABLE { // setup the transition...clear the bits before setting the next state. CHGBIT(psc_base + 0x0A00 + module_offest,0x3F,in_next_state); // MDCTRL + module_offest // kick off the transition. SETBIT(psc_base + 0x0120,in_domain); // PTCMD // spin until transition is done. while(TESTBIT(psc_base + 0x0128,in_domain)); //reg = TESTBIT(psc_base + 0x0800 + module_offest, 0x3F); //__message "PSC 0 Module: ", in_module:%d,", MDSTAT: ", reg:%x, "\n"; while(in_next_state != TESTBIT(psc_base + 0x0800 + module_offest, 0x3F)); } } lpsc1Enable(in_domain, in_module, in_next_state) { __var psc_base; __var reg; __var module_offest; psc_base = 0x01E27000; module_offest = in_module << 2; // spin until existing transitions are done. while(TESTBIT(psc_base + 0x0128,in_domain)); // if we are already in the requested state...just return. if(in_next_state != TESTBIT(psc_base + 0x0800 + module_offest, 0x3F)) // !PSC_ENABLE { // setup the transition...clear the bits before setting the next state. CHGBIT(psc_base + 0x0A00 + module_offest,0x3F,in_next_state); // MDCTRL + module_offest // kick off the transition. SETBIT(psc_base + 0x0120,in_domain); // PTCMD // spin until transition is done. while(TESTBIT(psc_base + 0x0128,in_domain)); //reg = TESTBIT(psc_base + 0x0800 + module_offest, 0x3F); //__message "PSC 1 Module: ", in_module:%d,", MDSTAT: ", reg:%x, "\n"; while(in_next_state != TESTBIT(psc_base + 0x0800 + module_offest, 0x3F)); } } SetupPLL0() { __var i; // unlock the system config registers. __writeMemory32(0x83E70B13, 0x01C14038, "Memory"); // SYSCONFIG->KICKR[0] = KICK0R_UNLOCK; __writeMemory32(0x95A4F1E0, 0x01C1403C, "Memory"); // SYSCONFIG->KICKR[1] = KICK1R_UNLOCK; // unlock pll regs. CLRBIT(0x01C1417C, 0x00000010); // CLRBIT(SYSCONFIG->CFGCHIP[0], PLL0_MASTER_LOCK); // prepare to enable pll (PLLENSRC must be clear for PLLEN to have effect). CLRBIT(0x01C11100, 0x00000020); // CLRBIT(PLL0->PLLCTL, PLLENSRC); // disable external clock source. CLRBIT(0x01C11100, 0x00000200); // CLRBIT(PLL0->PLLCTL, EXTCLKSRC); // switch to bypass mode...wait 4 cycles to ensure it switches properly. CLRBIT(0x01C11100, 0x00000001); // CLRBIT(PLL0->PLLCTL, PLLEN); for (i = 0; i < 4; i++) {} // select clock mode (on-chip oscillator or external). CLRBIT(0x01C11100, 0x00000100); // CLRBIT(PLL0->PLLCTL, CLKMODE); SETBIT(0x01C11100, 0x00000000); // SETBIT(PLL0->PLLCTL, (clkmode << CLKMODE_SHIFT)); // reset the pll. CLRBIT(0x01C11100, 0x00000008); // CLRBIT(PLL0->PLLCTL, PLLRST); // disable the pll...set disable bit. SETBIT(0x01C11100, 0x00000010); // SETBIT(PLL0->PLLCTL, PLLDIS); // PLL initialization sequence //---------------------------- // power up the pll...clear power down bit. CLRBIT(0x01C11100, 0x00000002); // CLRBIT(PLL0->PLLCTL, PLLPWRDN); // enable the pll...clear disable bit. CLRBIT(0x01C11100, 0x00000010); // CLRBIT(PLL0->PLLCTL, PLLDIS); /*PLL stabilisation time- take out this step , not required here when PLL in bypassmode*/ __delay(10); // program the required multiplier value. __writeMemory32(18, 0x01C11110, "Memory"); // PLL0->PLLM = pllm; // with postdiv = 1 // program postdiv ratio. __writeMemory32(0x00008000 | 0, 0x01C11128, "Memory"); // PLL0->POSTDIV = DIV_ENABLE | postdiv (0 + 1 = 1); // spin until all transitions are complete. while (TESTBIT(0x01C1113C, 0x00000001)) {} // while (CHKBIT(PLL0->PLLSTAT, GOSTAT)) {} // program the divisors. __writeMemory32(0x00008000 | 0, 0x01C11118, "Memory"); // PLL0->PLLDIV1 = DIV_ENABLE | plldiv1; __writeMemory32(0x00008000 | 1, 0x01C1111C, "Memory"); // PLL0->PLLDIV2 = DIV_ENABLE | plldiv2; __writeMemory32(0x00008000 |11, 0x01C11120, "Memory"); // PLL0->PLLDIV3 = DIV_ENABLE | plldiv3; __writeMemory32(0x00008000 | (((0+1)*4)-1), 0x01C11160, "Memory"); // PLL0->PLLDIV4 = DIV_ENABLE | (((plldiv1 + 1) * 4) - 1); __writeMemory32(0x00008000 | 0, 0x01C11168, "Memory"); // PLL0->PLLDIV6 = DIV_ENABLE | plldiv1; __writeMemory32(0x00008000 | 9, 0x01C1116C, "Memory"); // PLL0->PLLDIV7 = DIV_ENABLE | plldiv7; // kick off the transitions and spin until they are complete. SETBIT(0x01C11138, 0x00000001); // SETBIT(PLL0->PLLCMD, GOSET); while (TESTBIT(0x01C1113C, 0x00000001)) {} // while (CHKBIT(PLL0->PLLSTAT, GOSTAT)) {} /*Wait for PLL to reset properly. See PLL spec for PLL reset time - This step is not required here -step11*/ __delay(10); /*128 MXI Cycles*/ // bring pll out of reset and wait for pll to lock. SETBIT(0x01C11100, 0x00000008); // SETBIT(PLL0->PLLCTL, PLLRST); __delay(10); // exit bypass mode. SETBIT(0x01C11100, 0x00000001); // SETBIT(PLL0->PLLCTL, PLLEN); // lock pll regs. SETBIT(0x01C1417C, 0x00000010); // SETBIT(SYSCONFIG->CFGCHIP[0], PLL0_MASTER_LOCK); } SetupPLL1() { __var i; // unlock the system config registers. __writeMemory32(0x83E70B13, 0x01C14038, "Memory"); // SYSCONFIG->KICKR[0] = KICK0R_UNLOCK; __writeMemory32(0x95A4F1E0, 0x01C1403C, "Memory"); // SYSCONFIG->KICKR[1] = KICK1R_UNLOCK; // unlock pll regs. CLRBIT(0x01C14188, 0x00000020); // CLRBIT(SYSCONFIG->CFGCHIP[3], PLL1_MASTER_LOCK); // prepare to enable pll (PLLENSRC must be clear for PLLEN to have effect). CLRBIT(0x01E1A100, 0x00000020); // CLRBIT(PLL1->PLLCTL, PLLENSRC); CLRBIT(0x01E1A100, 0x00000200); // CLRBIT(PLL1->PLLCTL, EXTCLKSRC); // switch to bypass mode...wait 4 cycles to ensure it switches properly. CLRBIT(0x01E1A100, 0x00000001); // CLRBIT(PLL1->PLLCTL, PLLEN); for (i = 0; i < 4; i++) {} // reset the pll. CLRBIT(0x01E1A100, 0x00000008); // CLRBIT(PLL1->PLLCTL, PLLRST); // disable the pll...set disable bit. SETBIT(0x01E1A100, 0x00000010); // SETBIT(PLL1->PLLCTL, PLLDIS); // PLL initialization sequence //---------------------------- // power up the pll...clear power down bit. CLRBIT(0x01E1A100, 0x00000002); // CLRBIT(PLL1->PLLCTL, PLLPWRDN); // enable the pll...clear disable bit. CLRBIT(0x01E1A100, 0x00000010); // CLRBIT(PLL1->PLLCTL, PLLDIS); /*PLL stabilisation time- take out this step , not required here when PLL in bypassmode*/ __delay(10); // program the required multiplier value. __writeMemory32(18, 0x01E1A110, "Memory"); // PLL1->PLLM = pllm; // postdiv = 1 // program postdiv ratio. __writeMemory32(0x00008000 | 0, 0x01E1A128, "Memory"); // PLL1->POSTDIV = DIV_ENABLE | postdiv (0+1); // spin until all transitions are complete. while (TESTBIT(0x01E1A13C, 0x00000001)) {} // while (CHKBIT(PLL1->PLLSTAT, GOSTAT)) {} // program the divisors. __writeMemory32(0x00008000 | 0, 0x01E1A118, "Memory"); // PLL1->PLLDIV1 = DIV_ENABLE | plldiv1; __writeMemory32(0x00008000 | 1, 0x01E1A11C, "Memory"); // PLL1->PLLDIV2 = DIV_ENABLE | plldiv2; __writeMemory32(0x00008000 | 2, 0x01E1A120, "Memory"); // PLL1->PLLDIV3 = DIV_ENABLE | plldiv3; // kick off the transitions and spin until they are complete. SETBIT(0x01E1A100, 0x00000001); // SETBIT(PLL1->PLLCMD, GOSET); while (TESTBIT(0x01E1A13C, 0x00000001)) {} // while (CHKBIT(PLL1->PLLSTAT, GOSTAT)) {} /*Wait for PLL to reset properly. See PLL spec for PLL reset time - This step is not required here -step11*/ __delay(10); // bring pll out of reset and wait for pll to lock. SETBIT(0x01E1A100, 0x00000008); // SETBIT(PLL1->PLLCTL, PLLRST); __delay(10); // exit bypass mode. SETBIT(0x01E1A100, 0x00000001); // SETBIT(PLL1->PLLCTL, PLLEN); // lock pll regs. SETBIT(0x01C14188, 0x00000020); // SETBIT(SYSCONFIG->CFGCHIP[3], PLL1_MASTER_LOCK); } SetupPSC() { __message "Executing PSC setup\n"; //----------------------------------------- // PSC0, domain 0 - all modules, always on. //----------------------------------------- // configure the next state for psc0 modules. lpsc0Enable(1, 3, 3); lpsc0Enable(1, 4, 3); lpsc0Enable(1, 5, 3); lpsc0Enable(1, 6, 3); lpsc0Enable(1, 9, 3); lpsc0Enable(1, 10, 3); lpsc0Enable(1, 11, 3); lpsc0Enable(1, 12, 3); //----------------------------------------- // PSC1, domain 0 - all modules, always on. //----------------------------------------- // configure the next state for psc1 modules. lpsc1Enable(1, 1, 3); lpsc1Enable(1, 2, 3); lpsc1Enable(1, 3, 3); lpsc1Enable(1, 4, 3); lpsc1Enable(1, 5, 3); lpsc1Enable(1, 7, 3); // lpsc1Enable(1, 8, 3); lpsc1Enable(1, 9, 3); lpsc1Enable(1, 10, 3); lpsc1Enable(1, 11, 3); lpsc1Enable(1, 12, 3); lpsc1Enable(1, 13, 3); lpsc1Enable(1, 14, 3); lpsc1Enable(1, 15, 3); lpsc1Enable(1, 16, 3); lpsc1Enable(1, 17, 3); lpsc1Enable(1, 18, 3); lpsc1Enable(1, 19, 3); // lpsc1Enable(1, 20, 3); // lpsc1Enable(1, 24, 3); // lpsc1Enable(1, 25, 3); // lpsc1Enable(1, 26, 3); lpsc1Enable(1, 31, 3); } SetupPLLs() { __message "Executing PLLs setup\n"; SetupPLL0(); SetupPLL1(); } SetupDDRRAM() { __message "Executing DDRRAM setup\n"; // unlock the system config registers and set the ddr 2x clock source. __writeMemory32(0x83E70B13, 0x01C14038, "Memory"); // SYSCONFIG->KICKR[0] = KICK0R_UNLOCK; __writeMemory32(0x95A4F1E0, 0x01C1403C, "Memory"); // SYSCONFIG->KICKR[1] = KICK1R_UNLOCK; CLRBIT(0x01C14188, 0x00000080); // CLRBIT(SYSCONFIG->CFGCHIP[3], CLK2XSRC); // enable emif3a clock. lpsc1Enable(1, 6, 3); // EVMOMAPL138_lpscTransition(PSC1, DOMAIN0, LPSC_EMIF3A, PSC_ENABLE); // check if vtp calibration is enabled. if (TESTBIT(0x1E2C0000, 0x00000040)) { // vtp cal disabled, begin cal. // enable input buffer and vtp. SETBIT(0x1E2C0000, 0x00004000); // SETBIT(VTPIO_CTL, 0x00004000); CLRBIT(0x1E2C0000, 0x00000040); // CLRBIT(VTPIO_CTL, 0x00000040); // pulse clrz to init vtp cal. SETBIT(0x1E2C0000, 0x00002000); // SETBIT(VTPIO_CTL, 0x00002000); CLRBIT(0x1E2C0000, 0x00002000); // CLRBIT(VTPIO_CTL, 0x00002000); SETBIT(0x1E2C0000, 0x00002000); // SETBIT(VTPIO_CTL, 0x00002000); // poll ready bit to wait for cal to complete. while (!TESTBIT(0x1E2C0000, 0x00008000)) {} // set lock and power save bits. SETBIT(0x1E2C0000, 0x00000180); // SETBIT(VTPIO_CTL, 0x00000180); } // config ddr timing. __writeMemory32(0x000000C4, 0xB00000E4, "Memory"); // DDR->DDRPHYCTL1 = 0x000000C4; __writeMemory32(0x0893C622, 0xB0000008, "Memory"); // DDR->SDCR = 0x0893C622; CHGBIT(0xB0000008,0x00F00000,0x00800000); // DDR->SDCR &= ((DDR->SDCR & 0xFF0FFFFF) | 0x00800000); CHGBIT(0xB0000008,0x00F00000,0x02000000); // DDR->SDCR = ((DDR->SDCR & 0xFF0FFFFF) | 0x02000000); CLRBIT(0xB0000008,0x00008000); // DDR->SDCR &= (~0x00008000); __writeMemory32(0x20923A89, 0xB0000010, "Memory"); // DDR->SDTIMR1 = 0x20923A89; __writeMemory32(0x0015C720, 0xB0000014, "Memory"); // DDR->SDTIMR2 = 0x0015C720; __writeMemory32(0x00000492, 0xB000001C, "Memory"); // DDR->SDCR2 = 0x0; __writeMemory32(0x000000C4, 0xB000000C, "Memory"); // DDR->SDRCR = 0x00000492; // set ddr2 to sync reset. SETBIT(0xB000000C, 0xC0000000); // SETBIT(DDR->SDRCR, 0xC0000000); // sync reset the ddr clock. lpsc1Enable(1, 6, 1); // EVMOMAPL138_lpscTransition(PSC1, DOMAIN0, LPSC_EMIF3A, PSC_SYNCRESET); // enable the clock. lpsc1Enable(1, 6, 3); // EVMOMAPL138_lpscTransition(PSC1, DOMAIN0, LPSC_EMIF3A, PSC_ENABLE); // disable self refresh. CLRBIT(0xB000000C,0xC0000000); // CLRBIT(DDR->SDRCR, 0xC0000000); } execUserPreload() { __var Reg; __message "Executing user preload macro\n"; __hwReset(0); // Disable MMU and enable ICache Reg = __jtagCP15ReadReg(1, 0, 0, 0); Reg &= 0xFFFFFFFA; Reg |= 1<<12; __jtagCP15WriteReg(1, 0, 0, 0, Reg); __message "Enable I Cache\n"; SetupPSC(); SetupPLLs(); SetupDDRRAM(); }
I'm attaching AIS configuration file and IAR macro file (as txt file).
Please advise.
Thank you
Andrey Bondarev
