Bonjour
s'il vous plaît aidez moi j'ai un probléme dans l'execution sur le processeur OMAP3530 dans le gtkterm il affiche:
Starting kernel ...Uncompressing Linux........................................................................................................................................................ done, booting the kernel.Linux version 2.6.32 (sdk@nemo) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Wed Jan 12 23:53:52 CST 2011CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7fCPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cacheMachine: OMAP3 EVMMemory policy: ECC disabled, Data cache writebackIgnoring RAM at 053ed000-0d3ebfff (vmalloc region overlap).OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000Reserving 4194304 bytes SDRAM for VRAMBuilt 1 zonelists in Zone order, mobility grouping on. Total pages: 25146Kernel command line: mem=99M@0x80000000 mem=128M@88000000 console=ttyS0,115200n8 loglevel=7 noinitrd root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwaitPID hash table entries: 512 (order: -1, 2048 bytes)Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)Memory: 99MB = 99MB totalMemory: 91348KB available (4192K code, 372K data, 172K init, 0K highmem)Hierarchical RCU implementation.NR_IRQS:402Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHzReprogramming SDRC clock to 332000000 HzGPMC revision 5.0IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interruptsTotal of 96 interrupts on 1 active controllerOMAP GPIO hardware version 2.5OMAP clockevent source: GPTIMER1 at 32768 HzConsole: colour dummy device 80x30Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696)Mount-cache hash table entries: 512CPU: Testing write buffer coherency: okregulator: core version 0.5NET: Registered protocol family 16omap3evmdc: Driver registration complete OMAP DMA hardware revision 4.0bio: create slab <bio-0> at 0SCSI subsystem initializedusbcore: registered new interface driver usbfsusbcore: registered new interface driver hubusbcore: registered new device driver usbi2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHztwl4030: PIH (irq 7) chaining IRQs 368..375twl4030: power (irq 373) chaining IRQs 376..383twl4030: gpio (irq 368) chaining IRQs 384..401regulator: VMMC1: 1850 <--> 3150 mV normal standbyregulator: VDAC: 1800 mV normal standbyregulator: VAUX2_4030: 2800 mV normal standbyregulator: VPLL2: 1800 mV normal standbyregulator: VSIM: 1800 <--> 3000 mV normal standbyi2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHzi2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHzSwitching to clocksource 32k_countermusb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92NET: Registered protocol family 2IP route cache hash table entries: 1024 (order: 0, 4096 bytes)TCP established hash table entries: 4096 (order: 3, 32768 bytes)TCP bind hash table entries: 4096 (order: 2, 16384 bytes)TCP: Hash tables configured (established 4096 bind 4096)TCP reno registeredUDP hash table entries: 256 (order: 0, 4096 bytes)UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)NET: Registered protocol family 1RPC: Registered udp transport module.RPC: Registered tcp transport module.RPC: Registered tcp NFSv4.1 backchannel transport module.omap-iommu omap-iommu.0: isp registeredOMAP35x Linux PSP version 03.00.01.06 (OMAP3EVM)NetWinder Floating Point Emulator V0.97 (double precision)VFS: Disk quotas dquot_6.5.2Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.msgmni has been set to 178alg: No test for stdrng (krng)io scheduler noop registeredio scheduler deadline registeredio scheduler cfq registered (default)OMAP DSS rev 2.0OMAP DISPC rev 3.0OMAP VENC rev 2OMAP DSI rev 1.0Serial: 8250/16550 driver, 4 ports, IRQ sharing enabledserial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654console [ttyS0] enabledserial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654brd: module loadedloop: module loadedomap2-nand driver initializingNAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)Creating 5 MTD partitions on "omap2-nand.0":0x000000000000-0x000000080000 : "xloader-nand"0x000000080000-0x000000240000 : "uboot-nand"0x000000240000-0x000000280000 : "params-nand"0x000000280000-0x000000780000 : "linux-nand"0x000000780000-0x000010000000 : "jffs2-nand"OneNAND driver initializingomap2-onenand omap2-onenand: Cannot request GPMC CSomap2-onenand: probe of omap2-onenand failed with error -16smsc911x: Driver version 2008-10-21.smsc911x-mdio: probedeth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:01, irq=-1)net eth0: MAC Address: 00:50:c2:7e:91:48usbcore: registered new interface driver cdc_etherusbcore: registered new interface driver dm9601ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci-omap ehci-omap.0: OMAP-EHCI Host Controllerehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1ehci-omap ehci-omap.0: irq 77, io mem 0x48064800ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00usb usb1: New USB device found, idVendor=1d6b, idProduct=0002usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1usb usb1: Product: OMAP-EHCI Host Controllerusb usb1: Manufacturer: Linux 2.6.32 ehci_hcdusb usb1: SerialNumber: ehci-omap.0hub 1-0:1.0: USB hub foundhub 1-0:1.0: 3 ports detectedInitializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.usbcore: registered new interface driver usbtestg_ether gadget: using random self ethernet addressg_ether gadget: using random host ethernet addressusb0: MAC d2:1e:f7:3b:a1:8fusb0: HOST MAC 32:f7:28:e8:2e:7ag_ether gadget: Ethernet Gadget, version: Memorial Day 2008g_ether gadget: g_ether readymusb_hdrc musb_hdrc: MUSB HDRC host drivermusb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2usb usb2: New USB device found, idVendor=1d6b, idProduct=0002usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1usb usb2: Product: MUSB HDRC host driverusb usb2: Manufacturer: Linux 2.6.32 musb-hcdusb usb2: SerialNumber: musb_hdrchub 2-0:1.0: USB hub foundhub 2-0:1.0: 1 port detectedmice: PS/2 mouse device common for all miceinput: TWL4030 Keypad as /devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keypad/input/input0ads7846 spi1.0: touchscreen, irq 335input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input1twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0twl_rtc twl_rtc: Power up reset detected.twl_rtc twl_rtc: Enabling TWL-RTC.i2c /dev entries driverLinux video capture interface: v2.00tvp514x 3-005c: Registered to v4l2 master omap34xxcam!!omap-iommu omap-iommu.0: isp: version 1.1usbcore: registered new interface driver uvcvideoUSB Video Class driver (v0.1.0)OMAP Watchdog Timer Rev 0x31: initial timeout 60 secusbcore: registered new interface driver usbhidusbhid: USB HID core driverAdvanced Linux Sound Architecture Driver Version 1.0.21.usbcore: registered new interface driver snd-usb-audioNo device for DAI omap-mcbsp-dai-0No device for DAI omap-mcbsp-dai-1No device for DAI omap-mcbsp-dai-2No device for DAI omap-mcbsp-dai-3No device for DAI omap-mcbsp-dai-4OMAP3 EVM SoC initasoc: twl4030 <-> omap-mcbsp-dai-0 mapping okALSA device list: #0: omap3evm (twl4030)TCP cubic registeredNET: Registered protocol family 17NET: Registered protocol family 15Power Management for TI OMAP3.SmartReflex driver initializedVFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)tvp514x 3-005c: tvp5146m2 found at 0xb8 (OMAP I2C adapter)omapdss DPI error: display already enabledomap_vout omap_vout: 'lcd' Display already enabledomapdss DPI error: display already enabledomap_vout omap_vout: 'lcd' Display already enabledomap_vout omap_vout: Buffer Size = 3686400omap_vout omap_vout: : registered and initialized video device 1omap_vout omap_vout: Buffer Size = 3686400omap_vout omap_vout: : registered and initialized video device 2Waiting for root device /dev/mmcblk0p2...
il se planté je ne sais pas pourquoi donc je peux pas travailler donc qu'est ce qu'il faut faire??
Merciii bcp
