I am a newby working with C6748 LCDK and testing below example code. However, I couldn't get the expected result and found that GPIO Direction is not correct. Every GPIO Direction register are indicating they are input in debug memory pane. So I wonder why? It is so weird that starterware function doesn't work as expected. Futhermore, if you look at the function declaration, pin number is limited to less than 32. Am I missing something?
* \file gpioCardDetect.c
* \brief This is a sample application file demonstrating the use of
* a GPIO pin to generate an interrupt whenever an MMC/SD card
* is inserted or ejected from the Evaluation Module(EVM).
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include<stdio.h>
#include "gpio.h"
#include "psc.h"
#include "soc_C6748.h"
#include "lcdkC6748.h"
#include "hw_types.h"
#include "PinMuxC6748.h"
#include "hw_syscfg0_C6748.h"
/* LOCAL FUNCTION PROTOTYPES */
static void Delay(volatile unsigned int delay);
/* GLOBAL VARIABLES */
/* LOCAL FUNCTION DEFINITIONS */
void PinMuxSetup()
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(0)) |= PINMUX0_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(1)) |= PINMUX1_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(2)) |= PINMUX2_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(3)) |= PINMUX3_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(4)) |= PINMUX4_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(5)) |= PINMUX5_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(6)) |= PINMUX6_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(7)) |= PINMUX7_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(8)) |= PINMUX8_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(9)) |= PINMUX9_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(10)) |= PINMUX10_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(11)) |= PINMUX11_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(12)) |= PINMUX12_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(13)) |= PINMUX13_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(14)) |= PINMUX14_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(15)) |= PINMUX15_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(16)) |= PINMUX16_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(17)) |= PINMUX17_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(18)) |= PINMUX18_VALUE;
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(19)) |= PINMUX19_VALUE;
int main(void)
/* The Local PSC number for GPIO is 3. GPIO belongs to PSC1 module.*/
PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_GPIO, PSC_POWERDOMAIN_ALWAYS_ON, PSC_MDCTL_NEXT_ENABLE);
/* Pin Multiplexing of pin 12, and 13 of GPIO Bank 6, Pin 1,2,3,4,and 9 of GPIO Bank 0, and Pin12 of GPIO Bank2 .*/
PinMuxSetup();
/* SWITCHEs SETUP */
/* Sets the pin 2 (GP0[1]) as input.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 2, GPIO_DIR_INPUT);
/* Sets the pin 3 (GP0[2]) as input.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 3, GPIO_DIR_INPUT);
/* Sets the pin 4 (GP0[3]) as input.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 4, GPIO_DIR_INPUT);
/* Sets the pin 5 (GP0[4]) as input.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 5, GPIO_DIR_INPUT);
/* LEDs SETUP */
/* Sets the pin 109 (GP6[12]) as output.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 109, GPIO_DIR_OUTPUT);
/* Sets the pin 110 (GP6[13]) as output.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 110, GPIO_DIR_OUTPUT);
/* Sets the pin 45 (GP2[12]) as output.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 45, GPIO_DIR_OUTPUT);
/* Sets the pin 10 (GP0[9]) as output.*/
GPIODirModeSet(SOC_GPIO_0_REGS, 10, GPIO_DIR_OUTPUT);
while(1)
GPIOPinWrite(SOC_GPIO_0_REGS, 109, GPIO_PIN_LOW);
printf("LED toggle\n");
// Delay(1000000);
GPIOPinWrite(SOC_GPIO_0_REGS, 109, GPIO_PIN_HIGH);
// Delay(1000000);
** \brief This function checks the insertion status of the MMC/SD card
** in the device and prints related statements on the serial
** commuincation console of the external device.
** \brief This function can be called to generate a delay.
while(delay--);
/*****************************END OF FILE************************************/
