Part Number: TMDSDSK6713
Good morning
I have DSK6713 interface and I want to connect to pc with serial RS232, through McBSP. My board is equipped to 5-56K daughter board. I have already connected DC_DXa and DC_DRa pins to USB/RS232 converter. The baude desired is about 115200. I have some problem to receive serial data. I have verified the time signal produced with oscilloscope; it seems to be not logical correct, I can not recognize all 10 bit expected.
Below the code implemented.
//CONFIG PAR /* create a config structure for digital loopback mode */ static MCBSP_Config ConfigLoopback = { /* Serial Port Control Register (SPCR) */ MCBSP_SPCR_RMK( MCBSP_SPCR_FREE_YES, /* Serial clock free running mode(FREE) MCBSP_SPCR_FREE_NO - During emulation halt,SOFT bit determines operation of McBSP. MCBSP_SPCR_FREE_YES - During emulation halt, serial clocks continue to run. */ MCBSP_SPCR_SOFT_YES, /* Serial clock emulation mode(SOFT) MCBSP_SPCR_SOFT_NO - In conjunction with FREE = 0, serial port clock stops immediately during emulation halt,thus aborting any transmissions. MCBSP_SPCR_SOFT_YES - In conjunction with FREE = 0, during emulation halt, serial port clock stops after completion of current transmission. */ MCBSP_SPCR_FRST_YES, /* Frame sync generator reset(FRST) MCBSP_SPCR_FRST_YES /MCBSP_SPCR_FRST_0 - Frame sync generation logic is reset. MCBSP_SPCR_FRST_NO /MCBSP_SPCR_FRST_1 - Frame sync signal is generated after eight CLKG clocks. */ MCBSP_SPCR_GRST_YES, /* Sample rate generator reset(GRST) MCBSP_SPCR_GRST_YES /MCBSP_SPCR_GRST_0 - Reset MCBSP_SPCR_GRST_NO /MCBSP_SPCR_GRST_1 -Out of reset*/ MCBSP_SPCR_XINTM_XRDY,/* Transmit interrupt mode(XINTM) MCBSP_SPCR_XINTM_XRDY - XINT driven by XRDY MCBSP_SPCR_XINTM_EOS - XINT generated by end-of-subframe in multichannel operation MCBSP_SPCR_XINTM_FRM - XINT generated by a new frame synchronization MCBSP_SPCR_XINTM_XSYNCERR - XINT generated by XSYNCERR */ MCBSP_SPCR_XSYNCERR_NO,/* Transmit synchronization error MCBSP_SPCR_XSYNCERR_NO /MCBSP_SPCR_XSYNCERR_0 - No frame synchronization error MCBSP_SPCR_XSYNCERR_YES /MCBSP_SPCR_XSYNCERR_1 - Frame synchronization error detected by McBSP */ MCBSP_SPCR_XRST_NO, /* Transmitter reset(XRST). This resets or enables transmitter. MCBSP_SPCR_XRST_YES /MCBSP_SPCR_XRST_0 - Serial port transmitter is disabled and is in reset state. MCBSP_SPCR_XRST_NO /MCBSP_SPCR_XRST_1 - Serial port transmitter is enabled. */ MCBSP_SPCR_DLB_OFF, /* Digital loopback(DLB) mode MCBSP_SPCR_DLB_OFF - DLB Disabled MCBSP_SPCR_DLB_ON - DLB Enabled */ MCBSP_SPCR_RJUST_RZF,/*Receive data sign-extension and justification mode(RJUST) MCBSP_SPCR_RJUST_RZF - Right-justify and zero-fill MSBs in DRR. MCBSP_SPCR_RJUST_RSE - Right-justify and sign-extend MSBs in DRR. MCBSP_SPCR_RJUST_LZF - Left-justify and zero-fill LSBs in DRR. */ MCBSP_SPCR_CLKSTP_DISABLE,/* Clock stop(CLKSTP) mode MCBSP_SPCR_CLKSTP_DISABLE - Disabled. Normal clocking enabled for non-SPI mode. MCBSP_SPCR_CLKSTP_NODELAY -Clock starts without delay. MCBSP_SPCR_CLKSTP_DELAY - Clock starts with delay.*/ MCBSP_SPCR_DXENA_OFF,/* DX Enabler(DXENA) -Extra delay for DX turn-on time. Only first bit of data is delayed. MCBSP_SPCR_DXENA_OFF - DX enabler is off. MCBSP_SPCR_DXENA_ON - DX enabler is on. */ MCBSP_SPCR_RINTM_RRDY,/* Receive interrupt(RINT) mode MCBSP_SPCR_RINTM_RRDY - RINT driven by RRDY MCBSP_SPCR_RINTM_EOS - RINT generated by end-of-subframe in multichannel operation MCBSP_SPCR_RINTM_FRM - RINT generated by a new frame synchronization MCBSP_SPCR_RINTM_RSYNCERR -RINT generated by RSYNCERR*/ MCBSP_SPCR_RSYNCERR_NO,/* Receive synchronization error(RSYNCERR) MCBSP_SPCR_RSYNCERR_NO /MCBSP_SPCR_RSYNCERR_0 - No frame synchronization error MCBSP_SPCR_RSYNCERR_YES /MCBSP_SPCR_RSYNCERR_1 - Frame synchronization error detected by McBSP */ MCBSP_SPCR_RRST_NO /* Receiver reset(RRST). This resets or enables receiver. MCBSP_SPCR_RRST_YES /MCBSP_SPCR_RRST_0 - Serial port receiver is disabled and is in reset state. MCBSP_SPCR_RRST_NO /MCBSP_SPCR_RRST_1 - Serial port receiver is enabled. */ ), /* Receive Control Register (RCR) */ MCBSP_RCR_RMK( MCBSP_RCR_RPHASE_SINGLE, /* Receive phases MCBSP_RCR_RPHASE_SINGLE - Single phase frame MCBSP_RCR_RPHASE_DUAL - Dual phase frame */ MCBSP_RCR_RFRLEN2_OF(1), /* Receive frame length in phase 2(RFRLEN2) 000 0000b: 1 word per phase 000 0001b: 2 words per phase . . . . . . . . . . . . 111 1111b: 128 words per phase */ MCBSP_RCR_RWDLEN2_8BIT,/* Receive element length in phase 2(RWDLEN2) MCBSP_RCR_RWDLEN2_8BIT - 8 bits MCBSP_RCR_RWDLEN2_12BIT - 12 bits MCBSP_RCR_RWDLEN2_16BIT - 16 bits MCBSP_RCR_RWDLEN2_20BIT - 20 bits MCBSP_RCR_RWDLEN2_24BIT - 24 bits MCBSP_RCR_RWDLEN2_32BIT - 32 bits */ MCBSP_RCR_RCOMPAND_MSB,/* Receive companding mode (RCOMPAND) MCBSP_RCR_RCOMPAND_MSB - No companding.Data transfer starts with MSB first. MCBSP_RCR_RCOMPAND_8BITLSB - No companding, 8-bit data. Transfer starts with LSB first. Applicable to 8-bit data or 32-bit data in data reversal mode. MCBSP_RCR_RCOMPAND_ULAW - Compand using m-law for receive data. Applicable to 8-bit data only MCBSP_RCR_RCOMPAND_ALAW - Compand using A-law for receive data. Applicable to 8-bit data only */ MCBSP_RCR_RFIG_YES, /* Receive frame ignore(RFIG) MCBSP_RCR_RFIG_NO - Unexpected receive frame synchronization pulses restart the transfer. MCBSP_RCR_RFIG_YES - Unexpected receive frame synchronization pulses are ignored. */ MCBSP_RCR_RDATDLY_1BIT,/* Receive data delay(RDATDLY) MCBSP_RCR_RDATDLY_0BIT - 0 bit data delay MCBSP_RCR_RDATDLY_1BIT - 1 bit data delay MCBSP_RCR_RDATDLY_2BIT - 2 bit data delay */ MCBSP_RCR_RFRLEN1_OF(9), /* Receive frame length in phase 1(RFRLEN1) 000 0000b: 1 word per phase 000 0001b: 2 words per phase . . . . . . . . . . . . 111 1111b: 128 words per phase */ MCBSP_RCR_RWDLEN1_16BIT,/* Receive element length in phase 1(RWDLEN1) MCBSP_RCR_RWDLEN1_8BIT - 8 bits MCBSP_RCR_RWDLEN1_12BIT - 12 bits MCBSP_RCR_RWDLEN1_16BIT - 16 bits MCBSP_RCR_RWDLEN1_20BIT - 20 bits MCBSP_RCR_RWDLEN1_24BIT - 24 bits MCBSP_RCR_RWDLEN1_32BIT - 32 bits */ MCBSP_RCR_RWDREVRS_DISABLE/* Receive 32-bit bit reversal feature.(RWDREVRS) MCBSP_RCR_RWDREVRS_DISABLE -32 bit reversal disabled MCBSP_RCR_RWDREVRS_ENABLE -32 bit reversal enabled. 32-bit data is received LSB first. RWDLEN should be set for 32-bit operation. RCOMPAND should be set to 01b else operation is undefined. */ ), /* Transmit Control Register (XCR) */ MCBSP_XCR_RMK( MCBSP_XCR_XPHASE_SINGLE,/* Transmit phases MCBSP_XCR_XPHASE_SINGLE - Single phase frame MCBSP_XCR_XPHASE_DUAL - Dual phase frame */ MCBSP_XCR_XFRLEN2_OF(1),/* Transmit frame length in phase 2(XFRLEN2) 000 0000b: 1 word per phase 000 0001b: 2 words per phase . . . . . . . . . . . . 111 1111b: 128 words per phase */ MCBSP_XCR_XWDLEN2_32BIT, /* Transmit element length in phase 2 MCBSP_XCR_XWDLEN2_8BIT - 8 bits MCBSP_XCR_XWDLEN2_12BIT - 12 bits MCBSP_XCR_XWDLEN2_16BIT - 16 bits MCBSP_XCR_XWDLEN2_20BIT - 20 bits MCBSP_XCR_XWDLEN2_24BIT - 24 bits MCBSP_XCR_XWDLEN2_32BIT - 32 bits */ MCBSP_XCR_XCOMPAND_MSB, /* Transmit companding mode(XCOMPAND) MCBSP_XCR_XCOMPAND_MSB - No companding. Data transfer starts with MSB first. MCBSP_XCR_XCOMPAND_8BITLSB - No companding, 8-bit data. Transfer starts with LSB first. Applicable to 8-bit data,or 32-bit data in data reversal mode. MCBSP_XCR_XCOMPAND_ULAW - Compand using m-law for receive data.Applicable to 8-bit data only. MCBSP_XCR_XCOMPAND_ALAW - Compand using A-law for receive data.Applicable to 8-bit data only. */ MCBSP_XCR_XFIG_YES, /* Transmit frame ignore(XFIG) MCBSP_XCR_XFIG_NO - Unexpected transmit frame synchronization pulses restart the transfer. MCBSP_XCR_XFIG_YES - Unexpected transmit frame synchronization pulses are ignored. */ MCBSP_XCR_XDATDLY_0BIT, /* Transmit data delay(XDATDLY) MCBSP_XCR_XDATDLY_0BIT - 0 bit data delay MCBSP_XCR_XDATDLY_1BIT - 1 bit data delay MCBSP_XCR_XDATDLY_2BIT - 2 bit data delay */ MCBSP_XCR_XFRLEN1_OF(1), /* Transmit frame length in phase 1(XFRLEN1) 000 0000b: 1 word per phase 000 0001b: 2 words per phase . . . . . . . . . . . . 111 1111b: 128 words per phase */ MCBSP_XCR_XWDLEN1_8BIT, /* Transmit element length in phase 1(XWDLEN1) MCBSP_XCR_XWDLEN1_8BIT - 8 bits MCBSP_XCR_XWDLEN1_12BIT - 12 bits MCBSP_XCR_XWDLEN1_16BIT - 16 bits MCBSP_XCR_XWDLEN1_20BIT - 20 bits MCBSP_XCR_XWDLEN1_24BIT - 24 bits MCBSP_XCR_XWDLEN1_32BIT - 32 bits */ MCBSP_XCR_XWDREVRS_DISABLE /* Transmit 32-bit bit reversal feature MCBSP_XCR_XWDREVRS_DISABLE - 32-bit reversal disabled. MCBSP_XCR_XWDREVRS_ENABLE - 32-bit reversal enabled. 32-bit data is transmitted LSB first. XWDLEN should be set for 32-bit operation. XCOMPAND should be set to 01b; else operation is undefined. */ ), /*serial port sample rate generator register(SRGR) */ MCBSP_SRGR_RMK( MCBSP_SRGR_GSYNC_SYNC,/* Sample rate generator clock synchronization(GSYNC). MCBSP_SRGR_GSYNC_FREE - The sample rate generator clock CLKG) is free running. MCBSP_SRGR_GSYNC_SYNC - (CLKG) is running but is resynchronized, and the frame sync signal (FSG)is generated only after the receive frame synchronization signal(FSR)is detected. Also,the frame period (FPER) is a don’t care because the period is dictated by the external frame sync pulse. */ MCBSP_SRGR_CLKSP_RISING,/* CLKS polarity clock edge select(CLKSP) MCBSP_SRGR_CLKSP_RISING - The rising edge of CLKS generates CLKG and FSG. MCBSP_SRGR_CLKSP_FALLING - The falling edge of CLKS generates CLKG and FSG. */ MCBSP_SRGR_CLKSM_INTERNAL,/* MCBSP sample rate generator clock mode(CLKSM) MCBSP_SRGR_CLKSM_CLKS - The sample rate generator clock is derived from CLKS. MCBSP_SRGR_CLKSM_INTERNAL - (Default value) The sample rate generator clock is derived from the internal clock source. */ MCBSP_SRGR_FSGM_DXR2XSR,/*Sample rate generator transmit frame synchronization mode.(FSGM) MCBSP_SRGR_FSGM_DXR2XSR - The transmit frame sync signal (FSX) is generated on every DXR to XSR copy. MCBSP_SRGR_FSGM_FSG - The transmit frame sync signal is driven by the sample rate generator frame sync signal, FSG. */ MCBSP_SRGR_FPER_OF(4095),/* Frame period(FPER) Valid values: 0 to 4095 */ MCBSP_SRGR_FWID_OF(255),/* Frame width(FWID) Valid values: 0 to 255 */ MCBSP_SRGR_CLKGDV_OF(1)/* Sample rate generator clock divider(CLKGDV) Valid values: 0 to 255 */ ), MCBSP_MCR_DEFAULT, /* Using default value of MCR register */ MCBSP_RCER_DEFAULT,/* Using default value of RCER register */ MCBSP_XCER_DEFAULT,/* Using default value of XCER register */ /* serial port pin control register(PCR) */ MCBSP_PCR_RMK( MCBSP_PCR_XIOEN_SP, /* Transmitter in general-purpose I/O mode - only when XRST = 0 in SPCR - (XIOEN) MCBSP_PCR_XIOEN_SP - CLKS pin is not a general purpose input. DX pin is not a general purpose output.FSX and CLKX are not general-purpose I/Os. MCBSP_PCR_XIOEN_GPIO - CLKS pin is a general-purpose input. DX pin is a general-purpose output. FSX and CLKX are general-purpose I/Os. These serial port pins do not perform serial port operation. */ MCBSP_PCR_RIOEN_SP, /* Receiver in general-purpose I/O mode - only when RRST = 0 in SPCR -(RIOEN) MCBSP_PCR_RIOEN_SP - DR and CLKS pins are not general-purpose inputs. FSR and CLKR are not general-purpose I/Os and perform serial port operation. MCBSP_PCR_RIOEN_GPIO - DR and CLKS pins are general-purpose inputs. FSR and CLKR are general-purpose I/Os. These serial port pins do not perform serial port operation. */ MCBSP_PCR_FSXM_INTERNAL, /* Transmit frame synchronization mode(FSXM) MCBSP_PCR_FSXM_EXTERNAL - Frame synchronization signal is provided by an external source. FSX is an input pin. MCBSP_PCR_FSXM_INTERNAL - Frame synchronization generation is determined by the sample rate generator frame synchronization mode bit FSGM in the SRGR. */ MCBSP_PCR_FSRM_INTERNAL, /* Receive frame synchronization mode (FSRM) MCBSP_PCR_FSRM_EXTERNAL - Frame synchronization signals are generated by an external device. FSR is an input pin. MCBSP_PCR_FSRM_INTERNAL - Frame synchronization signals are generated internally by the sample rate generator. FSR is an output pin except when GSYNC = 1 in SRGR. */ MCBSP_PCR_CLKXM_OUTPUT, /* Transmitter clock mode (CLKXM) MCBSP_PCR_CLKXM_INPUT - Transmitter clock is driven by an external clock with CLKX as an input pin. MCBSP_PCR_CLKXM_OUTPUT - CLKX is an output pin and is driven by the internal sample rate generator. During SPI mode : MCBSP_PCR_CLKXM_INPUT - McBSP is a slave and (CLKX) is driven by the SPI master in the system. CLKR is internally driven by CLKX. MCBSP_PCR_CLKXM_OUTPUT - McBSP is a master and generates the transmitter clock (CLKX) to drive its receiver clock (CLKR) and the shift clock of the SPI-compliant slaves in the system. */ MCBSP_PCR_CLKRM_OUTPUT, /* Receiver clock mode (CLKRM) Case 1: Digital loopback mode not set in SPCR MCBSP_PCR_CLKRM_INPUT - Receive clock (CLKR) is an input driven by an external clock. MCBSP_PCR_CLKRM_OUTPUT - CLKR is an output pin and is driven by the sample rate generator. Case 2: Digital loopback mode set in SPCR MCBSP_PCR_CLKRM_INPUT - Receive clock is driven by the transmit clock (CLKX), which is based on the CLKXM bit in PCR. CLKR is in high impedance. MCBSP_PCR_CLKRM_INPUT - CLKR is an output pin and is driven by the transmit clock. The transmit clock is derived from CLKXM bit in the PCR.*/ MCBSP_PCR_CLKSSTAT_0, /* CLKS pin status(CLKSSTAT) MCBSP_PCR_CLKSSTAT_0 MCBSP_PCR_CLKSSTAT_1 */ MCBSP_PCR_DXSTAT_0, /* DX pin status(DXSTAT) MCBSP_PCR_DXSTAT_0 MCBSP_PCR_DXSTAT_1 */ MCBSP_PCR_FSXP_ACTIVELOW, /* Transmit frame synchronization polarity(FSXP) MCBSP_PCR_FSXP_ACTIVEHIGH - Frame synchronization pulse FSX is active high MCBSP_PCR_FSXP_ACTIVELOW - Frame synchronization pulse FSX is active low */ MCBSP_PCR_FSRP_ACTIVELOW, /* Receive frame synchronization polarity(FSRP) MCBSP_PCR_FSRP_ACTIVEHIGH - Frame synchronization pulse FSR is active high MCBSP_PCR_FSRP_ACTIVELOW - Frame synchronization pulse FSR is active low */ MCBSP_PCR_CLKXP_RISING, /* Transmit clock polarity(CLKXP) MCBSP_PCR_CLKXP_RISING - Transmit data driven on rising edge of CLKX MCBSP_PCR_CLKXP_FALLING - Transmit data driven on falling edge of CLKX */ MCBSP_PCR_CLKRP_FALLING /* Receive clock polarity(CLKRP) MCBSP_PCR_CLKRP_FALLING - Receive data sampled on falling edge of CLKR MCBSP_PCR_CLKRP_RISING - Receive data sampled on rising edge of CLKR */ ) }; //MAIN routine to send '65dec' data on RS232. void main() { DSK6713_rset(DSK6713_MISC,0x03); MCBSP_Handle hMcbsp; volatile Uint32 x,y; x=0; int success = 1; // Initialize the chip support library, must when using CSL CSL_init(); // Let's open up serial port 1 //preInitConfig2(); hMcbsp = MCBSP_open(MCBSP_DEV0, MCBSP_OPEN_RESET); //postConfig2(); // We'll set it up for digital loopback, 32bit mode. We have // to setup the sample rate generator to allow self clocking. MCBSP_config(hMcbsp,&ConfigLoopback); // Start McBSP0 MCBSP_start(hMcbsp, MCBSP_XMIT_START | MCBSP_RCV_START | MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC, 220); // Now we'll loop for a while writing values out to the port // then reading them back in. This should take a few seconds. for (y=0; y<0x00000001; y++) {//for (y=0; y<0x00080000; y++) { x=0; // wait until the transmitter is ready for a sample then write to it while (!MCBSP_xrdy(hMcbsp)); Uint32* handletx = (Uint32*)(MCBSP_getXmtAddr(hMcbsp)); (*handletx) = 0x0000; (*handletx) = 0x0000; (*handletx) = 0xFFFFFFFF; (*handletx) = 0x0000; (*handletx) = 0xFFFFFFFF; (*handletx) = 0x0000; (*handletx) = 0xFFFFFFFF; (*handletx) = 0x0000; (*handletx) = 0xFFFFFFFF; (*handletx) = 0x0000; //MCBSP_write(hMcbsp,'A'); // now wait until the value is received then read it //while (!MCBSP_rrdy(hMcbsp)); //x = MCBSP_read(hMcbsp); printf("\nTx"); // check to make sure they match if (x != 0) { success = 0; printf("\nRx");//printf("\nTEST FAILED"); //break; } } // All done now, close the port. MCBSP_close(hMcbsp); if(success) printf("\nTEST PASSED\n"); }
