Hello All,
Working on a porting effort to get the Wilink8 ( 1835 mod) working on Am437x GP EVM for Android KK.
The enviroment info:
Host PC - Ubuntu 14.04 LTS
Hardware - AM437x GP EVM
AOSP version - Kitkat 4.4.4 r2 branch
Linux kernel - 3.12.20 ( rowboat kernel) - has WL18xx support
Android device/ti and hardware/ti folders pulled from RowBoat Jelly Bean(437xevm) for Kitkat build
We have 2 issues
1) First problem we dont see the Wpa_supplicant launching from Android while tapping the WIFI tab in settings window. Any clue on why this is not working would be very helpful..
2) Next we tried for running the with the older wpa_supplicant from TI which was part of JB 4.2.2 Am335x Release. But wlan doesnt seem to scan for the AP's. Also we are not able run iwconfig and iwlist commands. The reason to fallback to the old version of the supplicant is the stock supplicant from 4.4.4_r2 doesn’t work.
All the logs given are given below for better understanding of the tries so far..
In our setup, Wilink8 driver is built as modules and insmoded using the script.
130|root@am437xevm:/ # lsmod
Module Size Used by
wl18xx 81032 0
wlcore_sdio 4233 0
wlcore 166157 1 wl18xx
mac80211 255513 2 wl18xx,wlcore
omaplfb 10904 0
pvrsrvkm 179575 57 omaplfb
cfg80211 164600 3 mac80211,wl18xx,wlcore
Dmesg logs from wlcore:
shell@am437xevm:/ $ [ 8.488429] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 8.501678] wlcore: loaded
[ 8.504604] wlcore: driver version: ol_r8.a8.10
[ 8.509638] wlcore: compilation time: Tue Aug 26 16:28:54 2014
root@am437xevm:/ # netcfg
wlan0 DOWN 0.0.0.0/0 0x00001002 84:dd:20:75:d7:7c
eth0 UP 0.0.0.0/0 0x00001003 34:b1:f7:31:53:dc
lo UP 127.0.0.1/8 0x00000049 00:00:00:00:00:00
root@am437xevm:/ # netcfg wlan0 up
[ 87.462319] wlcore: PHY firmware version: Rev 8.2.0.0.195
[ 87.560772] wlcore: firmware booted (Rev 8.8.0.0.13)
wlan0 UP 0.0.0.0/0 0x00001003 84:dd:20:75:d7:7c
from ADB shell execute:
wpa_supplicant -Dnl80211 -iwlan0 -c/data/misc/wifi/wpa_supplicant.conf -dd -B command
D/wpa_supplicant( 6442): wpa_supplicant v2.0-devel-
D/wpa_supplicant( 6442): random: Trying to read entropy from /dev/random
I/wpa_supplicant( 6442): Successfully initialized wpa_supplicant
D/wpa_supplicant( 6442): Initializing interface 'wlan0' conf '/data/misc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridg'
D/wpa_supplicant( 6442): Configuration file '/data/misc/wifi/wpa_supplicant.conf' -> '/data/misc/wifi/wpa_supplicant.conf'
D/wpa_supplicant( 6442): Reading configuration file '/data/misc/wifi/wpa_supplicant.conf'
D/wpa_supplicant( 6442): update_config=1
D/wpa_supplicant( 6442): ctrl_interface='/data/misc/wifi/wpa_supplicant'
D/wpa_supplicant( 6442): eapol_version=1
D/wpa_supplicant( 6442): ap_scan=1
D/wpa_supplicant( 6442): fast_reauth=1
D/wpa_supplicant( 6442): nl80211: interface wlan0 in phy phy0
I/wpa_supplicant( 6442): rfkill: Cannot open RFKILL control device
D/wpa_supplicant( 6442): nl80211: RFKILL status not available
D/wpa_supplicant( 6442): nl80211: Set mode ifindex 3 iftype 2 (STATION)
D/wpa_supplicant( 6442): nl80211: Subscribe to mgmt frames with non-AP handle 0xb8537208
D/wpa_supplicant( 6442): nl80211: Register frame type=0xd0 nl_handle=0xb8537208
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=2): 04 0a
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=2): 04 0b
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=2): 04 0c
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=2): 04 0d
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=6): 04 09 50 6f 9a 09
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=5): 7f 50 6f 9a 09
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=1): 06
D/wpa_supplicant( 6442): nl80211: Register frame match - hexdump(len=2): 0a 07
D/wpa_supplicant( 6442): netlink: Operstate: linkmode=1, operstate=5
D/wpa_supplicant( 6442): nl80211: Using driver-based off-channel TX
D/wpa_supplicant( 6442): nl80211: Supports Probe Response offload in AP mode
D/wpa_supplicant( 6442): nl80211: driver param='(null)'
D/wpa_supplicant( 6442): nl80211: Regulatory information - country=00
D/wpa_supplicant( 6442): nl80211: 2402-2472 @ 40 MHz
D/wpa_supplicant( 6442): nl80211: 2457-2482 @ 40 MHz
D/wpa_supplicant( 6442): nl80211: 2474-2494 @ 20 MHz
D/wpa_supplicant( 6442): nl80211: 5170-5250 @ 80 MHz
D/wpa_supplica[ 137.440719] init: untracked pid 6582 exited
nt( 6442): nl80211: 5735-5835 @ 80 MHz
D/wpa_supplicant( 6442): nl80211: 57240-63720 @ 2160 MHz
D/wpa_supplicant( 6442): nl80211: Added 802.11b mode based on 802.11g information
D/wpa_supplicant( 6442): wlan0: Own MAC address: 88:33:14:16:45:31
D/wpa_supplicant( 6442): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 6442): wpa_driver_nl80211_set_key: ifindex[ 137.482086] init: untracked pid 6507 exited
=3 alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 6442): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 6442): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 6442): wlan0: RSN: flushing PMKID list in the driver
D/wpa_supplicant( 6442): nl80211: Flush PMKIDs
D/wpa_supplicant( 6442): wlan0: State: DISCONNECTED -> INACTIVE
D/wpa_supplicant( 6442): WPS: Set UUID for interface wlan0
D/wpa_supplicant( 6442): WPS: [ 137.537071] init: untracked pid 6571 exited
UUID based on MAC address - hexdump(len=16): 48 d3 4a d8 e3 39 5b 11 a2 ad d4 66 01 67 b7 da
D/wpa_supplicant( 6442): EAPOL: SUPP_PAE entering state DISCONNECTED
D/wpa_supplicant( 6442): EAPOL: Supplicant port status: Unauthorized
D/wpa_supplicant( 6442): EAPOL: KEY_RX entering state NO_KEY_RECEIVE
D/wpa_supplicant( 6442): EAPOL: SUPP_BE entering state INITIALIZE
D/wpa_supplicant( 6442): EAP: EAP entering state DISABLED
D/wpa_supplicant( 6442): Using existing control interface directory.
D/wpa_supplicant( 6442): ctrl_iface bind(PF_UNIX) failed: Address already in use
D/wpa_supplicant( 6442): ctrl_iface exists, but does not allow conne[ 137.615592] init: untracked pid 6612 exited
ctions - assuming it was leftover from forced program termination
D/wpa_supplicant( 6442): Successfully replaced leftover ctrl_iface socket '/data/misc/wifi/wpa_supplicant/wlan0'
D/wpa_supplicant( 6442): Disable P2P on wlan0
D/wpa_supplicant( 6442): wlan0: Added interface wlan0
D/wpa_supplicant( 6442): wlan0: State: INACTIVE -> DISCONNECTED
D/wpa_supplicant( 6442): wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
D/wpa_supplicant( 6442): netlink: Operstate: linkmode=-1, operstate=5
D/wpa_supplicant( 6442): Daemonize..
D/wpa_supplicant( 6443): random: Got 20/20 bytes from /dev/random
D/wpa_supplicant( 6443): EAPOL: disable timer tick
D/wpa_supplicant( 6443): EAPOL: Supplicant port status: Unauthorized
Need to know more on the rfkill error messages, and its dependency for the wifi to work and how to fix this.
3) Third approach with modified conf file from TI SDK release, still the same result.
130|root@am437xevm:/ # logcat | grep wpa
D/wpa_supplicant( 2754): wpa_supplicant v2.0-devel-
D/wpa_supplicant( 2754): random: Trying to read entropy from /dev/random
I/wpa_supplicant( 2754): Successfully initialized wpa_supplicant
D/wpa_supplicant( 2754): Initializing interface 'wlan0' conf '/data/misc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridg'
D/wpa_supplicant( 2754): Configuration file '/data/misc/wifi/wpa_supplicant.conf' -> '/data/misc/wifi/wpa_supplicant.conf'
D/wpa_supplicant( 2754): Reading configuration file '/data/misc/wifi/wpa_supplicant.conf'
D/wpa_supplicant( 2754): ctrl_interface='/data/misc/wifi/wpa_supplicant'
D/wpa_supplicant( 2754): driver_param='use_multi_chan_concurrent=1 use_p2p_group_interface=1'
D/wpa_supplicant( 2754): update_config=1
D/wpa_supplicant( 2754): device_name='Blaze'
D/wpa_supplicant( 2754): manufacturer='TI'
D/wpa_supplicant( 2754): model_name='Wilink'
D/wpa_supplicant( 2754): model_number='wl18xx'
D/wpa_supplicant( 2754): serial_number='12345'
D/wpa_supplicant( 2754): p2p_go_ht40=1
D/wpa_supplicant( 2754): p2p_disabled=1
D/wpa_supplicant( 2754): p2p_multi_chan=1
D/wpa_supplicant( 2754): disassoc_low_ack=1
D/wpa_supplicant( 2754): p2p_go_max_inactivity=60
D/wpa_supplicant( 2754): concurrent_sched_scan=1
D/wpa_supplicant( 2754): Line: 18 - start of a new network block
D/wpa_supplicant( 2754): ssid - hexdump(len=6): 52 65 69 7a 65 72
D/wpa_supplicant( 2754): key_mgmt: 0x4
D/wpa_supplicant( 2754): auth_alg: 0x1
D/wpa_supplicant( 2754): Priority group 0
D/wpa_supplicant( 2754): id=0 ssid='Reizer'
D/wpa_supplicant( 2754): nl80211: interface wlan0 in phy phy0
I/wpa_supplicant( 2754): rfkill: Cannot open RFKILL control device
D/wpa_supplicant( 2754): nl80211: RFKILL status not available
D/wpa_supplicant( 2754): nl80211: Set mode ifindex 3 iftype 2 (STATION)
D/wpa_supplicant( 2754): nl80211: Subscribe to mgmt frames with non-AP handle 0xb71d5208
D/wpa_supplicant( 2754): nl80211: Register frame type=0xd0 nl_handle=0xb71d5208
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=2): 04 0a
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=2): 04 0b
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=2): 04 0c
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=2): 04 0d
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=6): 04 09 50 6f 9a 09
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=5): 7f 50 6f 9a 09
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=1): 06
D/wpa_supplicant( 2754): nl80211: Register frame match - hexdump(len=2): 0a 07
D/wpa_supplicant( 2754): netlink: Operstate: linkmode=1, operstate=5
D/wpa_supplicant( 2754): nl80211: Using driver-based off-channel TX
D/wpa_supplicant( 2754): nl80211: Supports Probe Response offload in AP mode
D/wpa_supplicant( 2754): nl80211: driver param='use_multi_chan_concurrent=1 use_p2p_group_interface=1'
D/wpa_supplicant( 2754): nl80211: Use separate P2P group interface
D/wpa_supplicant( 2754): nl80211: Use Multi channel concurrency
D/wpa_supplicant( 2754): nl80211: Regulatory information - country=00
D/wpa_supplicant( 2754): nl80211: 2402-2472 @ 40 MHz
D/wpa_supplicant( 2754): nl80211: 2457-2482 @ 40 MHz
D/wpa_supplicant( 2754): nl80211: 2474-2494 @ 20 MHz
D/wpa_supplicant( 2754): nl80211: 5170-5250 @ 80 MHz
D/wpa_supplicant( 2754): nl80211: 5735-5835 @ 80 MHz
D/wpa_supplicant( 2754): nl80211: 57240-63720 @ 2160 MHz
D/wpa_supplicant( 2754): nl80211: Added 802.11b mode based on 802.11g information
D/wpa_supplicant( 2754): wlan0: Own MAC address: 00:d2:8b:43:9f:fd
D/wpa_supplicant( 2754): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 2754): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 2754): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 2754): wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 2754): wlan0: RSN: flushing PMKID list in the driver
D/wpa_supplicant( 2754): nl80211: Flush PMKIDs
D/wpa_supplicant( 2754): WPS: Set UUID for interface wlan0
D/wpa_supplicant( 2754): WPS: UUID based on MAC address - hexdump(len=16): e6 37 19 9e 4e 5e 54 e7 94 9e 71 68 ed cd fa b1
D/wpa_supplicant( 2754): EAPOL: SUPP_PAE entering state DISCONNECTED
D/wpa_supplicant( 2754): EAPOL: Supplicant port status: Unauthorized
D/wpa_supplicant( 2754): EAPOL: KEY_RX entering state NO_KEY_RECEIVE
D/wpa_supplicant( 2754): EAPOL: SUPP_BE entering state INITIALIZE
D/wpa_supplicant( 2754): EAP: EAP entering state DISABLED
D/wpa_supplicant( 2754): Using existing control interface directory.
D/wpa_supplicant( 2754): ctrl_iface bind(PF_UNIX) failed: Address already in use
D/wpa_supplicant( 2754): ctrl_iface exists, but does not allow connections - assuming it was leftover from forced program termination
D/wpa_supplicant( 2754): Successfully replaced leftover ctrl_iface socket '/data/misc/wifi/wpa_supplicant/wlan0'
D/wpa_supplicant( 2754): Disable P2P on wlan0
D/wpa_supplicant( 2754): wlan0: Added interface wlan0
D/wpa_supplicant( 2754): wlan0: State: DISCONNECTED -> DISCONNECTED
D/wpa_supplicant( 2754): wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
D/wpa_supplicant( 2754): netlink: Operstate: linkmode=-1, operstate=5
D/wpa_supplicant( 2754): Daemonize..
D/wpa_supplicant( 2756): random: Got 19/20 bytes from /dev/random
D/wpa_supplicant( 2756): wlan0: Starting delayed sched scan
D/wpa_supplicant( 2756): wlan0: add to filter ssid: Reizer
D/wpa_supplicant( 2756): wlan0: Starting sched scan: short interval 5 long_interval 30 num_short_intervals 10
D/wpa_supplicant( 2756): nl80211: Sched scan filter SSID - hexdump(len=6): 52 65 69 7a 65 72
D/wpa_supplicant( 2756): nl80211: Sched scan SSID - hexdump(len=0): [NULL]
D/wpa_supplicant( 2756): nl80211: Sched scan requested (ret=0) intervals: short=5000 ms long=30000 ms num_short_intervals=10
D/wpa_supplicant( 2756): nl80211: Event message available
D/wpa_supplicant( 2756): nl80211: Sched scan started
D/wpa_supplicant( 2756): EAPOL: disable timer tick
D/wpa_supplicant( 2756): EAPOL: Supplicant port status: Unauthorized
4) Snippet of other commands executed:
root@am437xevm:/ # iwlist wlan0 scanning
wlan0 Interface doesn't support scanning.
root@am437xevm:/ # iwconfig wlan0 ap auto
Error for wireless request "Set AP Address" (8B14) :
SET failed on device wlan0 ; Operation not supported on transport endpoint.
130|root@am437xevm:/ # iwconfig wlan0 mode managed
Error for wireless request "Set Mode" (8B06) :
Configuration files under Kitkat FS
Board_config.mk file:
# wifi configs
BOARD_WPA_SUPPLICANT_DRIVER := NL80211
BOARD_HOSTAPD_DRIVER := NL80211
WPA_SUPPLICANT_VERSION := VER_0_8_X_TI
BOARD_WLAN_DEVICE := wl12xx_mac80211
BOARD_SOFTAP_DEVICE := wl12xx_mac80211
WIFI_DRIVER_MODULE_PATH := "/system/lib/modules/wlcore_sdio.ko"
WIFI_DRIVER_MODULE_NAME := "wlcore_sdio"
#init.am.rc file
# wi-fi
#mkdir /data/misc/wifi/sockets 0770 wifi wifi
#mkdir /data/misc/dhcp 0770 dhcp dhcp
mkdir /system/etc/wifi 0777 wifi wifi
chmod 0777 /system/etc/wifi
chmod 0777 /system/etc/wifi/wpa_supplicant.conf
chown wifi wifi /system/etc/wifi/wpa_supplicant.conf
mkdir /data/misc/wifi 0777 wifi wifi
mkdir /data/misc/wifi/sockets 0777 wifi wifi
chmod 0777 /data/misc/wifi
chown wifi wifi /data/misc/wifi/wpa_supplicant.conf
chmod 0666 /data/misc/wifi/wpa_supplicant.conf
chown dhcp dhcp /data/misc/dhcp
insmod /system/lib/modules/cfg80211.ko
insmod /system/lib/modules/mac80211.ko
insmod /system/lib/modules/wlcore.ko
insmod /system/lib/modules/wlcore_sdio.ko
insmod /system/lib/modules/wl18xx.ko
#service p2p_supplicant /system/bin/wpa_supplicant \
# -iwlan0 -Dnl80211 -c/data/misc/wifi/wpa_supplicant.conf \
# -ip2p0 -Dnl80211 -c/data/misc/wifi/p2p_supplicant.conf \
# -puse_p2p_group_interface=1
# class main
# socket wpa_wlan0 dgram 660 wifi wifi
# disabled
# oneshot
#service wpa_supplicant /system/bin/wpa_supplicant \
# -e/data/misc/wifi/entropy.bin
# class main
# disabled
# oneshot
-I/system/etc/wifi/wpa_supplicant_overlay.conf \
-O/data/misc/wifi/sockets -N \
-I/system/etc/wifi/p2p_supplicant_overlay.conf \
-puse_p2p_group_interface=1 -e/data/misc/wifi/entropy.bin \
-g@android:wpa_wlan0
# we will start as root and wpa_supplicant will switch to user wifi
# after setting up the capabilities required for WEXT
# user wifi
# group wifi inet keystore
class main
disabled
oneshot
#-I/system/etc/wifi/wpa_supplicant_overlay.conf \
#-O/data/misc/wifi/sockets \
-e/data/misc/wifi/entropy.bin -g@android:wpa_wlan0
# user wifi
class main
disabled
oneshot
service dhcpcd_wlan0 /system/bin/dhcpcd -ABKL
class latestart
disabled
oneshot
service iprenew_wlan0 /system/bin/dhcpcd -n
class latestart
disabled
oneshot
service dhcpcd_p2p /system/bin/dhcpcd -aABKL
class main
disabled
oneshot
service iprenew_p2p /system/bin/dhcpcd -n
class main
disabled
oneshot
service hostapd_bin /system/bin/hostapd -d /data/misc/wifi/hostapd.conf
class main
disabled
oneshot
Any help on solving the problem would be greatly appreciated.
