I follow the instruction in :
and build a file system with SGX.
When I boot from sd card I See only the android graphic display over hdmi, and no thing happen after :
Here is a console output:
U-Boot SPL 2013.01.01-00129-g6d40c2a (Jun 09 2015 - 10:12:43)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.01.01-00129-g6d40c2a (Jun 09 2015 - 10:12:43)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - readenv() failed, using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot: 0
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
214 bytes read in 4 ms (51.8 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc ...
Running uenvcmd ...
reading uImage
4178872 bytes read in 412 ms (9.7 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-3.2.0-00244-gcf99001-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4178808 Bytes = 4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0-00244-gcf99001-dirty (patrick@patrick-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 Tue Jun 9 10:15:50 EDT 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait init=/init ip=off
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 249984k/249984k available, 12160k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc078a000 (7688 kB)
[ 0.000000] .init : 0xc078a000 - 0xc07e0000 ( 344 kB)
[ 0.000000] .data : 0xc07e0000 - 0xc084ba70 ( 431 kB)
[ 0.000000] .bss : 0xc084ba94 - 0xc09a3890 (1376 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000091] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089233] pid_max: default: 32768 minimum: 301
[ 0.089355] Security Framework initialized
[ 0.089385] Mount-cache hash table entries: 512
[ 0.089752] CPU: Testing write buffer coherency: ok
[ 0.089782] ftrace: allocating 22068 entries in 65 pages
[ 0.145111] omap_hwmod: pruss: failed to hardreset
[ 0.145782] print_constraints: dummy:
[ 0.145965] NET: Registered protocol family 16
[ 0.146820] OMAP GPIO hardware version 0.1
[ 0.147644] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.148468] omap_i2c.1: alias fck already exists
[ 0.148895] omap2_mcspi.1: alias fck already exists
[ 0.148986] omap2_mcspi.2: alias fck already exists
[ 0.149078] edma.0: alias fck already exists
[ 0.149108] edma.0: alias fck already exists
[ 0.156677] bio: create slab <bio-0> at 0
[ 0.157409] SCSI subsystem initialized
[ 0.158081] usbcore: registered new interface driver usbfs
[ 0.158172] usbcore: registered new interface driver hub
[ 0.158294] usbcore: registered new device driver usb
[ 0.158538] registerd cppi-dma Intr @ IRQ 17
[ 0.158538] Cppi41 Init Done Qmgr-base(d087a000) dma-base(d0878000)
[ 0.158569] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.158691] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.169250] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.169860] tps65910 1-002d: could not be detected
[ 0.170257] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.170715] Bluetooth: Core ver 2.16
[ 0.170776] NET: Registered protocol family 31
[ 0.170776] Bluetooth: HCI device and connection manager initialized
[ 0.170776] Bluetooth: HCI socket layer initialized
[ 0.170776] Bluetooth: L2CAP socket layer initialized
[ 0.170806] Bluetooth: SCO socket layer initialized
[ 0.170959] Switching to clocksource gp timer
[ 0.184936] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.185119] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.185241] MUSB0 controller's USBSS revision = 4ea20800
[ 0.185272] musb0: Enabled SW babble control
[ 0.185943] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using DMA, IRQ 18
[ 0.186157] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.186309] MUSB1 controller's USBSS revision = 4ea20800
[ 0.186309] musb1: Enabled SW babble control
[ 0.186645] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.186737] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.186828] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.186828] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.186859] usb usb1: Product: MUSB HDRC host driver
[ 0.186859] usb usb1: Manufacturer: Linux 3.2.0-00244-gcf99001-dirty musb-hcd
[ 0.186859] usb usb1: SerialNumber: musb-hdrc.1
[ 0.187286] hub 1-0:1.0: USB hub found
[ 0.187286] hub 1-0:1.0: 1 port detected
[ 0.187591] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using DMA, IRQ 19
[ 0.187896] NET: Registered protocol family 2
[ 0.188049] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.188354] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.188476] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.188537] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.188568] TCP reno registered
[ 0.188568] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.188598] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.188751] NET: Registered protocol family 1
[ 0.188964] RPC: Registered named UNIX socket transport module.
[ 0.188995] RPC: Registered udp transport module.
[ 0.188995] RPC: Registered tcp transport module.
[ 0.188995] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.189208] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.274963] ashmem: initialized
[ 0.275177] VFS: Disk quotas dquot_6.5.2
[ 0.275238] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.275909] fuse init (API version 7.17)
[ 0.276092] msgmni has been set to 488
[ 0.276885] io scheduler noop registered
[ 0.276885] io scheduler deadline registered
[ 0.276947] io scheduler cfq registered (default)
[ 0.277435] Could not set LED4 to fully on
[ 0.311645] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.933929] console [ttyO0] enabled
[ 0.937957] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.945587] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.953186] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.960784] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.968353] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.976104] [drm] Initialized drm 1.1.0 20060810
[ 0.985351] brd: module loaded
[ 0.990905] loop: module loaded
[ 0.994415] i2c-core: driver [tsl2550] using legacy suspend method
[ 1.000854] i2c-core: driver [tsl2550] using legacy resume method
[ 1.007293] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.091583] No daughter card found on AM335x EVM
[ 1.096466] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.111633] Board name: A335BNLT
[ 1.115020] Board version: 000C
[ 1.118286] The board is a AM335x Beaglebone Black.
[ 1.125061] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[ 1.132324] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[ 1.140502] print_constraints: DCDC2: 900 <--> 3300 mV at 1325 mV
[ 1.148681] print_constraints: DCDC3: 900 <--> 1500 mV at 1125 mV
[ 1.156860] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[ 1.165039] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[ 1.173126] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[ 1.181304] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[ 1.191040] omap_hsmmc.0: alias fck already exists
[ 1.196289] omap_hsmmc.1: alias fck already exists
[ 1.201568] omap_i2c.3: alias fck already exists
[ 1.211578] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[ 1.221588] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 1.227905] davinci-mcasp.0: alias fck already exists
[ 1.234497] at24 3-0054: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.241790] IN : bone_setup_display_daughter_board
[ 1.341552] No display cape found on BeagleBone
[ 1.346740] da8xx_lcdc.0: alias fck already exists
[ 1.352050] da8xx_lcdc da8xx_lcdc.0: GLCD: Found nxp-1280x720@60 panel
[ 1.372009] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b
[ 1.378997] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.386474] usb 1-1: Product: USB Receiver
[ 1.390777] usb 1-1: Manufacturer: Logitech
[ 1.503906] tda998x 1-0070: found TDA19988
[ 1.601593] Setup HDMI display complete
[ 1.605651] at24 3-0055: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.612945] IN : bone_setup_daughter_board
[ 1.711608] at24 3-0056: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.718872] IN : bone_setup_daughter_board
[ 1.821594] at24 3-0057: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.828887] IN : bone_setup_daughter_board
[ 1.911712] (hci_tty): inside hci_tty_init
[ 1.916137] (hci_tty): allocated 251, 0
[ 1.920257] NFC Driver for TI WiLink
[ 1.924530] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.931549] omap2-nand driver initializing
[ 1.935913] OneNAND driver initializing
[ 1.940277] CAN device driver interface
[ 1.944305] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.991607] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.998077] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 2.005340] davinci_mdio.0: probed
[ 2.008880] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 2.017517] PPP generic driver version 2.4.2
[ 2.022155] PPP BSD Compression module registered
[ 2.027069] PPP Deflate Compression module registered
[ 2.032470] usbcore: registered new interface driver cdc_ether
[ 2.038604] usbcore: registered new interface driver cdc_eem
[ 2.044555] usbcore: registered new interface driver dm9601
[ 2.050415] usbcore: registered new interface driver cdc_subset
[ 2.056671] cdc_ncm: 04-Aug-2011
[ 2.060089] usbcore: registered new interface driver cdc_ncm
[ 2.066101] usbcore: registered new interface driver cdc_acm
[ 2.072021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.080383] Initializing USB Mass Storage driver...
[ 2.085662] usbcore: registered new interface driver usb-storage
[ 2.091949] USB Mass Storage support registered.
[ 2.096923] usbcore: registered new interface driver usbserial
[ 2.103057] USB Serial support registered for generic
[ 2.108459] usbcore: registered new interface driver usbserial_generic
[ 2.115295] usbserial: USB Serial Driver core
[ 2.119873] USB Serial support registered for GSM modem (1-port)
[ 2.126373] usbcore: registered new interface driver option
[ 2.132202] option: v0.7.2:USB Driver for GSM modems
[ 2.138732] gadget: Mass Storage Function, version: 2009/09/11
[ 2.144958] gadget: Number of LUNs=1
[ 2.148773] lun0: LUN: removable file: (no medium)
[ 2.154083] gadget: android_usb ready
[ 2.158020] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 2.163635] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 2.171447] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.178558] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.186126] usb usb2: Product: MUSB HDRC host driver
[ 2.191314] usb usb2: Manufacturer: Linux 3.2.0-00244-gcf99001-dirty musb-hcd
[ 2.198791] usb usb2: SerialNumber: musb-hdrc.0
[ 2.203918] hub 2-0:1.0: USB hub found
[ 2.207855] hub 2-0:1.0: 1 port detected
[ 2.212493] mousedev: PS/2 mouse device common for all mice
[ 2.219238] using rtc device, am33xx-rtc, for alarms
[ 2.224334] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[ 2.231628] i2c /dev entries driver
[ 2.235534] Linux video capture interface: v2.00
[ 2.240631] usbcore: registered new interface driver uvcvideo
[ 2.246673] USB Video Class driver (1.1.1)
[ 2.502258] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.508758] device-mapper: uevent: version 1.0.3
[ 2.513763] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 2.522583] Bluetooth: HCI UART driver ver 2.2
[ 2.527221] Bluetooth: HCI H4 protocol initialized
[ 2.532257] Bluetooth: HCILL protocol initialized
[ 2.537170] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 2.544616] cpuidle: using governor ladder
[ 2.548980] cpuidle: using governor menu
[ 2.556854] usbcore: registered new interface driver usbhid
[ 2.562744] usbhid: USB HID core driver
[ 2.567108] logger: created 256K log 'log_main'
[ 2.571960] logger: created 256K log 'log_events'
[ 2.576934] logger: created 256K log 'log_radio'
[ 2.581848] logger: created 256K log 'log_system'
[ 2.587249] usbcore: registered new interface driver snd-usb-audio
[ 2.595550] asoc: am335x-hdmi-hifi <-> davinci-mcasp.0 mapping ok
[ 2.602478] ALSA device list:
[ 2.605560] #0: AM335X BONE
[ 2.608673] oprofile: hardware counters not available
[ 2.613983] oprofile: using timer interrupt.
[ 2.618591] Netfilter messages via NETLINK v0.30.
[ 2.623626] nf_conntrack version 0.5.0 (3906 buckets, 15624 max)
[ 2.630157] ctnetlink v0.93: registering with nfnetlink.
[ 2.635803] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.643096] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.649444] xt_time: kernel timezone is -0000
[ 2.654205] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.659942] arp_tables: (C) 2002 David S. Miller
[ 2.664855] TCP cubic registered
[ 2.668334] NET: Registered protocol family 10
[ 2.673645] Mobile IPv6
[ 2.676239] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.682067] IPv6 over IPv4 tunneling driver
[ 2.686950] NET: Registered protocol family 17
[ 2.691650] NET: Registered protocol family 15
[ 2.696289] can: controller area network core (rev 20090105 abi 8)
[ 2.702880] NET: Registered protocol family 29
[ 2.707519] can: raw protocol (rev 20090105)
[ 2.712005] can: broadcast manager protocol (rev 20090105 t)
[ 2.718078] Bluetooth: RFCOMM TTY layer initialized
[ 2.723236] Bluetooth: RFCOMM socket layer initialized
[ 2.728607] Bluetooth: RFCOMM ver 1.11
[ 2.732543] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.738098] Bluetooth: BNEP filters: protocol multicast
[ 2.743560] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.749877] Registering the dns_resolver key type
[ 2.754882] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.762908] ThumbEE CPU extension supported.
[ 2.767425] mux: Failed to setup hwmod io irq -22
[ 2.772918] Power Management for AM33XX family
[ 2.777740] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 2.784454] Copied the M3 firmware to UMEM
[ 2.788818] Cortex M3 Firmware Version = 0x181
[ 2.796386] clock: disabling unused clocks to save power
[ 2.803253] Detected MACID=d0:39:72:54:33:85
[ 2.808807] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.818206] Waiting for root device /dev/mmcblk0p2...
[ 2.862640] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.873077] mmc0: new high speed SDHC card at address 59b4
[ 2.879241] mmcblk0: mmc0:59b4 29.8 GiB
[ 2.885162] mmcblk0: p1 p2 p3 p4
[ 2.989257] mmc1: new high speed MMC card at address 0001
[ 2.995391] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[ 3.000244] mmcblk1boot0: mmc1:0001 MMC04G partition 1 2.00 MiB
[ 3.006591] mmcblk1boot1: mmc1:0001 MMC04G partition 2 2.00 MiB
[ 3.013824] mmcblk1: p1 p2
[ 3.018249] mmcblk1boot1: unknown partition table
[ 3.024353] mmcblk1boot0: unknown partition table
[ 3.084197] EXT4-fs (mmcblk0p2): recovery complete
[ 3.127960] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.136505] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.143188] Freeing init memory: 344K
[ 3.177093] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.249053] init: cannot open '/initlogo.rle'
[ 3.311737] EXT4-fs (mmcblk0p3): recovery complete
[ 3.316802] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 3.360229] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 3.379974] android_usb: already disabled
[ 3.389587] android_usb: already disabled
[ 3.394500] android_usb: already disabled
[ 3.399383] adb_bind_config
[ 3.404693] adb_bind_config
[ 3.505371] adb_open
root@android:/ # [ 3.739685] Disabling lock debugging due to kernel taint
[ 12.319549] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 20.759368] request_suspend_state: wakeup (3->0) at 20736939349 (2000-01-01 00:00:18.444973385 UTC)
[ 21.171142] net eth0: CPSW phy found : id is : 0x7c0f1
[ 21.177368] PHY 0:01 not found
[ 21.190399] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 21.665740] acc_open
[ 21.668060] acc_release
[ 24.900482] binder: 312: binder_alloc_buf, no vma
[ 24.905517] binder: 488:488 transaction failed 29201, size 96-4
[ 24.924530] binder: 312: binder_alloc_buf, no vma
[ 24.929473] binder: 497:497 transaction failed 29201, size 96-0
[ 24.936279] binder: release 312:312 transaction 2084 in, still active
[ 24.943084] binder: send failed reply for transaction 2084 to 544:544
[ 24.950012] binder: send failed reply for transaction 2230 to 514:514
[ 24.977874] alarm_release: clear alarm, pending 0
[ 24.982910] alarm_release: clear alarm, pending 0
[ 25.005462] binder: 544:544 transaction failed 29189, size 84-0
[ 25.036743] binder: 514:514 transaction failed 29189, size 84-0
[ 25.045166] binder: 488:488 transaction failed 29189, size 364-8
[ 25.114288] binder: 526:526 transaction failed 29189, size 136-0
[ 25.160522] request_suspend_state: wakeup (0->0) at 25138123429 (2000-01-01 00:00:22.846157465 UTC)
[ 25.237274] init: untracked pid 65 exited
[ 25.246337] init: untracked pid 70 exited
[ 25.250579] init: untracked pid 433 exited
[ 25.269073] init: untracked pid 488 exited
[ 25.280639] init: untracked pid 497 exited
[ 25.293487] init: untracked pid 514 exited
[ 25.310424] init: untracked pid 526 exited
[ 25.334228] init: untracked pid 544 exited
[ 37.937805] request_suspend_state: wakeup (0->0) at 37915345111 (2000-01-01 00:00:35.623379147 UTC)
[ 38.775268] acc_open
[ 38.777893] acc_release
[ 41.122772] binder: release 793:804 transaction 4275 in, still active
[ 41.129547] binder: send failed reply for transaction 4275 to 914:914
[ 41.136322] binder: release 793:1025 transaction 4261 in, still active
[ 41.143157] binder: send failed reply for transaction 4261 to 970:970
[ 41.149902] binder: release 793:1046 transaction 4407 in, still active
[ 41.156768] binder: send failed reply for transaction 4407 to 1000:1000
[ 41.163696] binder: release 793:1048 transaction 4378 in, still active
[ 41.170532] binder: send failed reply for transaction 4378 to 1037:1037
[ 41.177459] binder: release 793:1051 transaction 4432 in, still active
[ 41.184326] binder: send failed reply for transaction 4432 to 980:980
[ 41.191070] binder: release 793:1062 transaction 4423 in, still active
[ 41.197906] binder: send failed reply for transaction 4423 to 1012:1012
[ 41.247283] alarm_release: clear alarm, pending 0
[ 41.252288] alarm_release: clear alarm, pending 0
[ 41.258361] binder: 1012:1012 transaction failed 29189, size 96-0
[ 41.325439] binder: 1012:1012 transaction failed 29189, size 64-0
[ 41.334075] init: untracked pid 980 exited
[ 41.345001] request_suspend_state: wakeup (0->0) at 41322571674 (2000-01-01 00:00:39.030605710 UTC)
[ 41.359893] binder: release proc 1064, transaction 4457, not freed
[ 41.387237] init: untracked pid 580 exited
[ 41.416809] init: untracked pid 581 exited
[ 41.424591] init: untracked pid 914 exited
[ 41.428924] init: untracked pid 970 exited
[ 41.446685] init: untracked pid 1000 exited
[ 41.451141] init: untracked pid 1012 exited
[ 41.470916] init: untracked pid 1037 exited
[ 41.492523] init: untracked pid 1064 exited
[ 53.330108] request_suspend_state: wakeup (0->0) at 53307679095 (2000-01-01 00:00:51.015713131 UTC)
[ 54.167633] acc_open
[ 54.169952] acc_release
[ 56.490600] binder: release 1292:1292 transaction 6426 in, still active
[ 56.497619] binder: send failed reply for transaction 6426 to 1503:1503
[ 56.504547] binder: release 1292:1303 transaction 6394 in, still active
[ 56.511474] binder: send failed reply for transaction 6394 to 1536:1536
[ 56.518402] binder: release 1292:1304 transaction 6352 in, still active
[ 56.525299] binder: send failed reply for transaction 6352 to 1526:1526
[ 56.532226] binder: release 1292:1509 transaction 6404 in, still active
[ 56.539154] binder: send failed reply for transaction 6404 to 1470:1470
[ 56.546081] binder: release 1292:1556 transaction 6477 in, still active
[ 56.553009] binder: send failed reply for transaction 6477 to 1414:1414
[ 56.559906] binder: release 1292:1561 transaction 6474 in, still active
[ 56.566833] binder: send failed reply for transaction 6474 to 1480:1480
[ 56.573944] binder: send failed reply for transaction 6486 to 1564:1564
[ 56.644592] alarm_release: clear alarm, pending 0
[ 56.649566] alarm_release: clear alarm, pending 0
[ 56.673614] request_suspend_state: wakeup (0->0) at 56651184955 (2000-01-01 00:00:54.359218991 UTC)
[ 56.711669] init: untracked pid 1079 exited
[ 56.722656] init: untracked pid 1080 exited
[ 56.727111] init: untracked pid 1470 exited
[ 56.753906] init: untracked pid 1526 exited
[ 56.758361] init: untracked pid 1536 exited
[ 56.782318] init: untracked pid 1564 exited
[ 68.690307] request_suspend_state: wakeup (0->0) at 68667878070 (2000-01-01 00:01:06.375912106 UTC)
[ 69.533081] acc_open
[ 69.535675] acc_release
[ 71.666564] binder: release 1790:1790 transaction 8476 in, still active
[ 71.673583] binder: send failed reply for transaction 8476 to 1974:1974
[ 71.680511] binder: release 1790:1802 transaction 8431 in, still active
[ 71.687438] binder: send failed reply for transaction 8431 to 2035:2035
[ 71.694366] binder: release 1790:2005 transaction 8416 in, still active
[ 71.701263] binder: send failed reply for transaction 8416 to 2017:2017
[ 71.708190] binder: release 1790:2034 transaction 8404 in, still active
[ 71.715118] binder: send failed reply for transaction 8404 to 2007:2007
[ 71.722198] binder: send failed reply for transaction 8486 to 1910:1910
[ 71.729156] binder: send failed reply for transaction 8495 to 2055:2055
[ 71.804046] alarm_release: clear alarm, pending 0
[ 71.808990] alarm_release: clear alarm, pending 0
[ 71.866973] request_suspend_state: wakeup (0->0) at 71844544331 (2000-01-01 00:01:09.552578367 UTC)
[ 71.906677] init: untracked pid 1577 exited
[ 71.911102] init: untracked pid 1578 exited
[ 71.941955] init: untracked pid 1910 exited
[ 71.952636] init: untracked pid 1964 exited
[ 71.973083] init: untracked pid 2017 exited
[ 71.977508] init: untracked pid 2035 exited
[ 71.981903] init: untracked pid 2055 exited
[ 83.854705] request_suspend_state: wakeup (0->0) at 83832276262 (2000-01-01 00:01:21.540310298 UTC)
[ 84.694274] acc_open
[ 84.696594] acc_release
[ 86.857269] binder: release 2281:2293 transaction 10487 in, still active
[ 86.864379] binder: send failed reply for transaction 10487 to 2521:2521
[ 86.871398] binder: release 2281:2503 transaction 10480 in, still active
[ 86.878448] binder: send failed reply for transaction 10480 to 2458:2458
[ 86.885467] binder: release 2281:2504 transaction 10350 in, still active
[ 86.892486] binder: send failed reply for transaction 10350 to 2403:2403
[ 86.899505] binder: release 2281:2508 transaction 10448 in, still active
[ 86.906524] binder: send failed reply for transaction 10448 to 2506:2506
[ 86.913543] binder: release 2281:2548 transaction 10499 in, still active
[ 86.920562] binder: send failed reply for transaction 10499 to 2487:2487
[ 86.927581] binder: release 2281:2550 transaction 10543 in, still active
[ 86.934600] binder: send failed reply for transaction 10543 to 2467:2467
[ 86.941802] binder: send failed reply for transaction 10552 to 2551:2551
[ 87.010070] alarm_release: clear alarm, pending 0
[ 87.015045] alarm_release: clear alarm, pending 0
[ 87.031585] binder: 2403:2403 transaction failed 29189, size 160-0
[ 87.075469] request_suspend_state: wakeup (0->0) at 87053040424 (2000-01-01 00:01:24.761074460 UTC)
[ 87.114501] init: untracked pid 2068 exited
[ 87.118927] init: untracked pid 2069 exited
[ 87.142822] init: untracked pid 2403 exited
[ 87.147277] init: untracked pid 2458 exited
[ 87.176788] init: untracked pid 2506 exited
[ 87.181213] init: untracked pid 2521 exited
[ 87.202606] init: untracked pid 2551 exited
It looks like the system in suspend state.
do you have any ideal ?
Patrick
