Hi all,
i had ported android on dm365 succesfully by using the linux staging 2.6.32 kernel .I am comfortable with video but while working with audio i am not geting sound.I had activated "tlv320aic3x" audio IC. Can u please help me how to build audio codecs on android.
Here is my logcat
I/DEBUG ( 1642): debuggerd: Oct 5 2010 18:14:50
E/flash_image( 1650): error scanning partitions
I/vold ( 1641): Android Volume Daemon version 2.0
E/vold ( 1641): Unable to open '/sys/class/mmc_host' (m)
E/vold ( 1641): Unable to open '/sys/class/switch' (m)
D/vold ( 1641): Bootstrapping complete
D/AndroidRuntime( 1644):
D/AndroidRuntime( 1644): >>>>>>>>>>>>>> AndroidRuntime START <<<<<<<<<<<<<<
D/AndroidRuntime( 1644): CheckJNI is ON
D/AndroidRuntime( 1644): --- registering native functions ---
I/ ( 1645): ServiceManager: 0xac38
W/AudioHardwareInterface( 1645): Using stubbed audio hardware. No sound will be produced.
I/CameraService( 1645): CameraService started: pid=1645
I/AudioFlinger( 1645): AudioFlinger's thread ready to run for output 0
I/Zygote ( 1644): Preloading classes...
D/dalvikvm( 1644): GC freed 763 objects / 42128 bytes in 8ms
D/dalvikvm( 1644): GC freed 278 objects / 17200 bytes in 7ms
D/dalvikvm( 1644): GC freed 208 objects / 12664 bytes in 9ms
D/dalvikvm( 1644): Trying to load lib /system/lib/libmedia_jni.so 0x0
D/dalvikvm( 1644): Added shared lib /system/lib/libmedia_jni.so 0x0
D/dalvikvm( 1644): Shared lib '/system/lib/libmedia_jni.so' already loaded in same CL 0x0
D/dalvikvm( 1644): GC freed 462 objects / 29168 bytes in 12ms
D/dalvikvm( 1644): GC freed 3584 objects / 171008 bytes in 35ms
D/dalvikvm( 1644): GC freed 11301 objects / 401080 bytes in 64ms
D/dalvikvm( 1644): GC freed 10490 objects / 438840 bytes in 69ms
D/dalvikvm( 1644): GC freed 10985 objects / 460024 bytes in 78ms
D/dalvikvm( 1644): GC freed 14372 objects / 506760 bytes in 93ms
D/dalvikvm( 1644): GC freed 11314 objects / 481360 bytes in 88ms
D/dalvikvm( 1644): GC freed 5928 objects / 248824 bytes in 70ms
D/dalvikvm( 1644): GC freed 349 objects / 37040 bytes in 57ms
D/dalvikvm( 1644): GC freed 778 objects / 48424 bytes in 77ms
D/dalvikvm( 1644): GC freed 321 objects / 37288 bytes in 77ms
D/dalvikvm( 1644): GC freed 477 objects / 29520 bytes in 77ms
D/dalvikvm( 1644): Trying to load lib /system/lib/libwebcore.so 0x0
D/dalvikvm( 1644): Added shared lib /system/lib/libwebcore.so 0x0
D/dalvikvm( 1644): GC freed 441 objects / 26176 bytes in 79ms
D/dalvikvm( 1644): GC freed 505 objects / 41456 bytes in 80ms
D/dalvikvm( 1644): GC freed 537 objects / 38696 bytes in 82ms
D/dalvikvm( 1644): GC freed 342 objects / 22576 bytes in 82ms
D/dalvikvm( 1644): GC freed 338 objects / 18720 bytes in 85ms
D/dalvikvm( 1644): GC freed 628 objects / 32008 bytes in 89ms
D/dalvikvm( 1644): GC freed 14258 objects / 497384 bytes in 139ms
D/dalvikvm( 1644): GC freed 11179 objects / 469840 bytes in 136ms
D/dalvikvm( 1644): GC freed 7118 objects / 310384 bytes in 123ms
D/dalvikvm( 1644): GC freed 753 objects / 43552 bytes in 102ms
D/dalvikvm( 1644): GC freed 598 objects / 31536 bytes in 104ms
D/dalvikvm( 1644): GC freed 413 objects / 26280 bytes in 106ms
I/Zygote ( 1644): ...preloaded 1166 classes in 16926ms.
D/dalvikvm( 1644): GC freed 313 objects / 19960 bytes in 107ms
I/Zygote ( 1644): Preloading resources...
D/dalvikvm( 1644): GC freed 54 objects / 11248 bytes in 107ms
D/dalvikvm( 1644): GC freed 337 objects / 14976 bytes in 109ms
D/dalvikvm( 1644): GC freed 280 objects / 11688 bytes in 110ms
I/Zygote ( 1644): ...preloaded 48 resources in 1239ms.
I/Zygote ( 1644): ...preloaded 15 resources in 35ms.
D/dalvikvm( 1644): GC freed 117 objects / 8456 bytes in 111ms
D/dalvikvm( 1644): GC freed 205 objects / 8104 bytes in 109ms
D/dalvikvm( 1644): GC freed 36 objects / 1384 bytes in 109ms
I/dalvikvm( 1644): Splitting out new zygote heap
I/dalvikvm( 1644): System server process 1660 has been created
I/Zygote ( 1644): Accepting command socket connections
D/dalvikvm( 1660): Trying to load lib /system/lib/libandroid_servers.so 0x0
D/dalvikvm( 1660): Added shared lib /system/lib/libandroid_servers.so 0x0
I/sysproc ( 1660): Entered system_init()
I/sysproc ( 1660): ServiceManager: 0x16cb98
I/SurfaceFlinger( 1660): SurfaceFlinger is starting
I/SurfaceFlinger( 1660): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
E/MemoryHeapBase( 1660): error opening /dev/pmem: No such file or directory
E/SurfaceFlinger( 1660): Couldn't open /sys/power/wait_for_fb_sleep or /sys/power/wait_for_fb_wake
E/GLLogger( 1660): couldn't load <libhgl.so> library (Cannot find library)
I/SurfaceFlinger( 1660): EGL informations:
I/SurfaceFlinger( 1660): # of configs : 6
I/SurfaceFlinger( 1660): vendor : Android
I/SurfaceFlinger( 1660): version : 1.31 Android META-EGL
I/SurfaceFlinger( 1660): extensions:
I/SurfaceFlinger( 1660): Client API: OpenGL ES
I/EGLDisplaySurface( 1660): using (fd=21)
I/EGLDisplaySurface( 1660): id = dm_osd0_fb
I/EGLDisplaySurface( 1660): xres = 720 px
I/EGLDisplaySurface( 1660): yres = 480 px
I/EGLDisplaySurface( 1660): xres_virtual = 720 px
I/EGLDisplaySurface( 1660): yres_virtual = 960 px
I/EGLDisplaySurface( 1660): bpp = 16
I/EGLDisplaySurface( 1660): r = 11:5
I/EGLDisplaySurface( 1660): g = 5:6
I/EGLDisplaySurface( 1660): b = 0:5
I/EGLDisplaySurface( 1660): width = 114 mm (160.421051 dpi)
I/EGLDisplaySurface( 1660): height = 76 mm (160.421051 dpi)
I/EGLDisplaySurface( 1660): refresh rate = 29.97 Hz
W/HAL ( 1660): load: module=/system/lib/hw/copybit.dm365.so error=Cannot find library
W/HAL ( 1660): load: module=/system/lib/hw/copybit.default.so error=Cannot find library
W/SurfaceFlinger( 1660): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger( 1660): OpenGL informations:
I/SurfaceFlinger( 1660): renderer : Android PixelFlinger 1.0
I/SurfaceFlinger( 1660): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 1660): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_ARB_texture_compression GL_ARB_texture_non_power_of_two GL_ANDROID_direct_texture GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
W/HAL ( 1660): load: module=/system/lib/hw/overlay.dm365.so error=Cannot find library
W/HAL ( 1660): load: module=/system/lib/hw/overlay.default.so error=Cannot find library
I/sysproc ( 1660): System server: starting Android runtime.
I/sysproc ( 1660): System server: starting Android services.
I/SystemServer( 1660): Entered the Android system server!
I/sysproc ( 1660): System server: entering thread pool.
I/SystemServer( 1660): Starting Power Manager.
I/ARMAssembler( 1660): generated scanline__00000077:03545404_00000A01_00000000 [ 30 ipp] (51 ins) at [0x18fe08:0x18fed4] in 0 ns
I/SystemServer( 1660): Starting Activity Manager.
I/SystemServer( 1660): Starting telephony registry
I/SystemServer( 1660): Starting Package Manager.
I/Installer( 1660): connecting...
I/installd( 1649): new connection
I/PackageManager( 1660): Got library android.awt in /system/framework/android.awt.jar
I/PackageManager( 1660): Got library android.test.runner in /system/framework/android.test.runner.jar
I/PackageManager( 1660): Got library com.android.im.plugin in /system/framework/com.android.im.plugin.jar
D/PackageManager( 1660): Scanning app dir /system/framework
D/PackageManager( 1660): Scanning app dir /system/app
D/dalvikvm( 1660): GC freed 5949 objects / 249800 bytes in 182ms
I/PackageManager( 1660): /system/app/SubscribedFeedsProvider.apk changed; collecting certs
E/PackageManager( 1660): Package com.android.providers.subscribedfeeds requires unavailable shared library com.google.android.gtalkservice; ignoring!
I/PackageManager( 1660): /system/app/Development.apk changed; collecting certs
D/dalvikvm( 1660): GC freed 4170 objects / 280768 bytes in 175ms
E/PackageManager( 1660): Package com.android.development requires unavailable shared library com.google.android.maps; ignoring!
D/PackageManager( 1660): Scanning app dir /data/app
W/PackageParser( 1660): Skipping non-package file: /data/app/busybox
D/PackageManager( 1660): Scanning app dir /data/app-private
I/PackageManager( 1660): Time to scan packages: 4.759 seconds
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 1660): Unknown permission com.google.android.providers.gmail.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 1660): Unknown permission com.google.android.providers.gmail.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.browser
W/PackageManager( 1660): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
D/dalvikvm( 1660): GC freed 5305 objects / 325192 bytes in 181ms
I/SystemServer( 1660): Starting Content Manager.
W/ActivityManager( 1660): Unable to start service Intent { action=android.accounts.IAccountsService comp={com.google.android.googleapps/com.google.android.googleapps.GoogleLoginService} }: not found
W/AccountMonitor( 1660): Couldn't connect to Intent { action=android.accounts.IAccountsService comp={com.google.android.googleapps/com.google.android.googleapps.GoogleLoginService} } (Missing service?)
I/SystemServer( 1660): Starting System Content Providers.
I/ActivityThread( 1660): Publishing provider settings: com.android.providers.settings.SettingsProvider
I/ActivityThread( 1660): Publishing provider sync: android.content.SyncProvider
I/SystemServer( 1660): Starting Battery Service.
I/SystemServer( 1660): Starting Hardware Service.
W/HAL ( 1660): load: module=/system/lib/hw/lights.dm365.so error=Cannot find library
W/HAL ( 1660): load: module=/system/lib/hw/lights.default.so error=Cannot find library
I/SystemServer( 1660): Starting Alarm Manager.
W/AlarmManager( 1660): Failed to open alarm driver. Falling back to a handler.
I/SystemServer( 1660): Starting Sensor Service.
W/HAL ( 1660): load: module=/system/lib/hw/sensors.dm365.so error=Cannot find library
W/HAL ( 1660): load: module=/system/lib/hw/sensors.default.so error=Cannot find library
I/SystemServer( 1660): Starting Window Manager.
E/EventHub( 1660): could not get driver version for /dev/input/mice, Not a typewriter
D/SensorManager( 1660): found sensor: null, handle=0
I/SystemServer( 1660): Starting Bluetooth Service.
I/SystemServer( 1660): Starting Status Bar Service.
I/SystemServer( 1660): Starting Clipboard Service.
I/SystemServer( 1660): Starting Input Method Service.
W/ResourceType( 1660): No package identifier when getting value for resource number 0x7f060001
I/InputManagerService( 1660): Enabled input methods: com.android.inputmethod.latin/.LatinIME
I/SystemServer( 1660): Starting NetStat Service.
I/SystemServer( 1660): Starting Connectivity Service.
I/WifiService( 1660): WifiService starting up with Wi-Fi disabled
I/SystemServer( 1660): Starting Notification Manager.
I/SystemServer( 1660): Starting Mount Service.
I/SystemServer( 1660): Starting DeviceStorageMonitor service
W/PackageManager( 1660): Couldn't clear application caches
I/SystemServer( 1660): Starting Location Manager.
D/libhardware_legacy( 1660): no GPS hardware on this device
I/SystemServer( 1660): Starting Search Service.
I/SystemServer( 1660): Starting Checkin Service.
W/ActivityManager( 1660): Unable to start service Intent { comp={com.google.android.server.checkin/com.google.android.server.checkin.CheckinService} }: not found
W/SystemServer( 1660): Using fallback Checkin Service.
I/SystemServer( 1660): Starting Wallpaper Service
D/WallpaperService( 1660): WallpaperService startup
I/SystemServer( 1660): Starting Audio Service
D/dalvikvm( 1660): Trying to load lib /system/lib/libsoundpool.so 0x0
D/dalvikvm( 1660): Added shared lib /system/lib/libsoundpool.so 0x0
W/AudioService( 1660): Soundpool could not load file: /system/media/audio/ui/Effect_Tick.ogg
W/AudioService( 1660): Soundpool could not load file: /system/media/audio/ui/KeypressStandard.ogg
W/AudioService( 1660): Soundpool could not load file: /system/media/audio/ui/KeypressSpacebar.ogg
W/AudioService( 1660): Soundpool could not load file: /system/media/audio/ui/KeypressDelete.ogg
W/AudioService( 1660): Soundpool could not load file: /system/media/audio/ui/KeypressReturn.ogg
I/SystemServer( 1660): Starting HeadsetObserver
W/HeadsetObserver( 1660): This kernel does not have wired headset support
I/SystemServer( 1660): Starting AppWidget Service
I/WindowManager( 1660): Menu key state: -1 safeMode=false
I/WindowManager( 1660): Config changed: { scale=1.0 imsi=0/0 locale=en_US touch=1 key=1/1/2 nav=1 orien=2 }
D/PowerManagerService( 1660): system ready!
W/ResourceType( 1660): No package identifier when getting value for resource number 0x7f030003
W/ResourceType( 1660): No package identifier when getting value for resource number 0x7f030000
W/ResourceType( 1660): No package identifier when getting value for resource number 0x7f03000c
D/ActivityManager( 1660): Start running!
D/dalvikvm( 1660): GC freed 4935 objects / 277400 bytes in 206ms
I/Zygote ( 1660): Process: zygote socket opened
I/ActivityManager( 1660): Start proc com.android.phone for added application com.android.phone: pid=1694 uid=1001 gids={3002, 3001, 3003}
I/ActivityManager( 1660): Starting activity: Intent { action=android.intent.action.MAIN categories={android.intent.category.HOME} flags=0x10000000 comp={com.android.launcher/com.android.launcher.Launcher} }
I/ActivityManager( 1660): Start proc android.process.acore for activity com.android.launcher/.Launcher: pid=1698 uid=10000 gids={3003}
W/ResourceType( 1660): No package identifier when getting value for resource number 0x00000000
W/StatusBar( 1660): Icon not found in <system>: 0
I/ActivityThread( 1698): Publishing provider user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
I/ActivityThread( 1694): Publishing provider mms-sms: com.android.providers.telephony.MmsSmsProvider
I/DeviceStorageMonitorService( 1660): Running low on memory. Sending notification
I/ActivityThread( 1698): Publishing provider com.android.googlesearch.SuggestionProvider: com.android.googlesearch.SuggestionProvider
I/ActivityThread( 1694): Publishing provider mms: com.android.providers.telephony.MmsProvider
I/ActivityThread( 1694): Publishing provider telephony: com.android.providers.telephony.TelephonyProvider
I/ActivityThread( 1698): Publishing provider contacts;call_log: com.android.providers.contacts.ContactsProvider
I/ActivityThread( 1694): Publishing provider sms: com.android.providers.telephony.SmsProvider
I/ActivityThread( 1694): Publishing provider sim: com.android.phone.SimProvider
D/StatusBar( 1660): updateResources
W/AccountMonitor( 1698): Couldn't connect to Intent { action=android.accounts.IAccountsService comp={com.google.android.googleapps/com.google.android.googleapps.GoogleLoginService} } (Missing service?)
I/ActivityThread( 1698): Publishing provider com.android.launcher.settings: com.android.launcher.LauncherProvider
W/ActivityManager( 1660): Unable to start service Intent { action=com.android.ussd.IExtendedNetworkService }: not found
D/PhoneApp( 1694): Resetting audio state/mode: IDLE
I/ActivityManager( 1660): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=1720 uid=10009 gids={3003}
I/ActivityManager( 1660): processNextBroadcast: waiting for ProcessRecord{43705748 1720:com.android.mms/10009}
D/dalvikvm( 1660): GC freed 5144 objects / 316088 bytes in 521ms
D/BT HSHFP( 1694): Starting BluetoothHeadsetService
D/dalvikvm( 1698): GC freed 2869 objects / 193936 bytes in 489ms
D/HomeLoaders( 1698): load applications
D/HomeLoaders( 1698): loading user items
D/HomeLoaders( 1698): --> starting workspace loader
D/dalvikvm( 1698): GC freed 655 objects / 56864 bytes in 197ms
I/ActivityManager( 1660): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=1734 uid=10000 gids={3003}
I/ActivityManager( 1660): Displayed activity com.android.launcher/.Launcher: 5676 ms
I/SurfaceFlinger( 1660): Boot is finished (16447 ms)
D/HomeLoaders( 1698): --> starting applications loader
D/vold ( 1641): Accepted connection from framework
D/vold ( 1641): dispatch_cmd(send_ums_status):
D/MountListener( 1660): handleEvent volume_nomedia:/sdcard
D/dalvikvm( 1660): GC freed 3010 objects / 311272 bytes in 426ms
D/MountListener( 1660): handleEvent ums_disabled
D/MountListener( 1660): handleEvent ums_disconnected
I/ActivityManager( 1660): Start proc com.android.alarmclock for broadcast com.android.alarmclock/.AlarmInitReceiver: pid=1743 uid=10002 gids={}
I/ActivityThread( 1743): Publishing provider com.android.alarmclock: com.android.alarmclock.AlarmProvider
I/ActivityManager( 1660): Start proc android.process.media for content provider com.android.providers.media/.MediaProvider: pid=1750 uid=10006 gids={1006, 2001, 3003}
I/ActivityThread( 1750): Publishing provider downloads: com.android.providers.downloads.DownloadProvider
I/ActivityThread( 1750): Publishing provider drm: com.android.providers.drm.DrmProvider
D/dalvikvm( 1734): Trying to load lib /system/lib/libjni_latinime.so 0x435bb760
I/ActivityThread( 1750): Publishing provider media: com.android.providers.media.MediaProvider
D/dalvikvm( 1734): Added shared lib /system/lib/libjni_latinime.so 0x435bb760
V/MediaProvider( 1750): Attached volume: internal
I/ActivityManager( 1660): Start proc com.android.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=1762 uid=10004 gids={3003}
I/ActivityManager( 1660): Exiting empty application process com.android.mms (android.os.BinderProxy@436c4490)
I/Process ( 1660): Sending signal. PID: 1720 SIG: 9
I/ActivityManager( 1660): Exiting empty application process com.android.alarmclock (android.os.BinderProxy@436aced0)
I/Process ( 1660): Sending signal. PID: 1743 SIG: 9
D/ActivityManager( 1660): Received spurious death notification for thread android.os.BinderProxy@436aced0
D/ActivityManager( 1660): Received spurious death notification for thread android.os.BinderProxy@436c4490
D/dalvikvm( 1660): GREF has increased to 201
I/ActivityThread( 1762): Publishing provider calendar: com.android.providers.calendar.CalendarProvider
D/ActivityManager( 1660): checkComponentPermission() adjusting {pid,uid} to {1645,1013}
W/AccountMonitor( 1762): Couldn't connect to Intent { action=android.accounts.IAccountsService comp={com.google.android.googleapps/com.google.android.googleapps.GoogleLoginService} } (Missing service?)
E/MediaPlayerService( 1645): Couldn't open fd for content://settings/system/notification_sound
E/MediaPlayer( 1660): Unable to to create media player
W/NotificationService( 1660): error loading sound for content://settings/system/notification_sound
W/NotificationService( 1660): java.io.IOException: setDataSource failed.: status=0x80000000
W/NotificationService( 1660): at android.media.MediaPlayer.setDataSource(Native Method)
W/NotificationService( 1660): at android.media.MediaPlayer.setDataSource(MediaPlayer.java:610)
W/NotificationService( 1660): at android.media.AsyncPlayer$Thread.run(AsyncPlayer.java:76)
I/ActivityManager( 1660): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=1779 uid=10009 gids={3003}
I/ActivityManager( 1660): Stopping service: com.android.providers.downloads/.DownloadService
D/MediaScannerService( 1750): start scanning volume internal
I/ActivityManager( 1660): Stopping service: com.android.calendar/.AlertService
D/MediaScanner( 1750): opendir /system/media/ failed, errno: 2
D/MediaScanner( 1750): prescan time: 644ms
D/MediaScanner( 1750): scan time: 113ms
D/MediaScanner( 1750): postscan time: 1ms
D/MediaScanner( 1750): total time: 758ms
D/MediaScannerService( 1750): done scanning volume internal
I/ActivityManager( 1660): Stopping service: com.android.providers.media/.MediaScannerService
I/ActivityManager( 1660): Exiting empty application process com.android.calendar (android.os.BinderProxy@43692480)
I/Process ( 1660): Sending signal. PID: 1762 SIG: 9
D/ActivityManager( 1660): Received spurious death notification for thread android.os.BinderProxy@43692480
I/ActivityManager( 1660): Start proc com.android.alarmclock for broadcast com.android.alarmclock/.AnalogAppWidgetProvider: pid=1789 uid=10002 gids={}
D/dalvikvm( 1644): GC freed 269 objects / 10096 bytes in 228ms
D/dalvikvm( 1644): GC freed 45 objects / 1912 bytes in 295ms
I/ActivityThread( 1789): Publishing provider com.android.alarmclock: com.android.alarmclock.AlarmProvider
I/ActivityManager( 1660): Stopping service: com.android.mms/.transaction.SmsReceiverService
D/dalvikvm( 1644): GC freed 2 objects / 48 bytes in 246ms
I/ActivityManager( 1660): Exiting empty application process android.process.media (android.os.BinderProxy@4370be40)
I/Process ( 1660): Sending signal. PID: 1750 SIG: 9
I/ActivityManager( 1660): Exiting empty application process com.android.mms (android.os.BinderProxy@436e1870)
I/Process ( 1660): Sending signal. PID: 1779 SIG: 9
D/ActivityManager( 1660): Received spurious death notification for thread android.os.BinderProxy@436e1870
D/ActivityManager( 1660): Received spurious death notification for thread android.os.BinderProxy@4370be40
D/dalvikvm( 1694): GC freed 3176 objects / 196768 bytes in 155ms
I/DEBUG ( 1642): debuggerd committing suicide to free the zombie!
I/DEBUG ( 1803): debuggerd: Oct 5 2010 18:14:50
