I had tried out both online and off line version CCS v 6.1.2.00015.
Both are showing following log for this error is:
5327.ccs_setup_6.1.2.00015_install.log
02/09/2016 13:19:59(GMT) - Validation::linuxLibChecks - LD_LIBRARY_PATH == :/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/tcl/lib 02/09/2016 13:19:59(GMT) - Validation::linuxLibChecks - tempLD == {} 02/09/2016 13:19:59(GMT) - Validation::linuxLibChecks - cmd = /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/dependency-checker/check_depends.sh --ldpath 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - ran /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/dependency-checker/check_depends.sh --ldpath :Installed versions of glibc and glibcxx: GLIBC_2.18, N/A Required versions of glibc and glibcxx: GLIBC_2.11, GLIBCXX_3.4.16 Checking availability of libraries in ext-depends.txt ... Failed to find lib: libgcrypt.so.11 Done. 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - Line: Installed versions of glibc and glibcxx: GLIBC_2.18, N/A 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - Line: Required versions of glibc and glibcxx: GLIBC_2.11, GLIBCXX_3.4.16 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - Line: Checking availability of libraries in ext-depends.txt ... 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - Line: Failed to find lib: libgcrypt.so.11 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - Val: libgcrypt.so.11 02/09/2016 13:20:01(GMT) - Validation::linuxLibChecks - Line: Done. 02/09/2016 13:20:10(GMT) - Util::httpCopy - http::config now: -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.5} 02/09/2016 13:20:10(GMT) - Util::httpCopy - Downloading /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/apps_6.1.2.json from http://software-dl.ti.com/ccs/non-esd/ccs_appcenter/apps_6.1.2.json 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Server: Apache 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Last-Modified: Fri, 29 Jan 2016 21:04:54 GMT 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= ETag: "6def-52a7f63046980" 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Accept-Ranges: bytes 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Content-Length: 28143 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Content-Type: application/json 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Date: Tue, 09 Feb 2016 13:20:10 GMT 02/09/2016 13:20:11(GMT) - Util::httpCopy - httpstate= Connection: close 02/09/2016 13:20:24(GMT) - writeDebugFile - Install Information: 02/09/2016 13:20:24(GMT) - writeDebugFile - Install Version: 6.1.2.00015 02/09/2016 13:20:24(GMT) - writeDebugFile - Install Source : /home/pinkeshk/Downloads/CCS6.1.2.00015_linux 02/09/2016 13:20:24(GMT) - writeDebugFile - Install Temp : /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131 02/09/2016 13:20:24(GMT) - writeDebugFile - Install Type : Offline 02/09/2016 13:20:24(GMT) - writeDebugFile - OS : Linux 02/09/2016 13:20:24(GMT) - writeDebugFile - OS Version : 3.19.0-15-generic 02/09/2016 13:20:24(GMT) - writeDebugFile - OS Platform : unix 02/09/2016 13:20:24(GMT) - writeDebugFile - : 64-bit 02/09/2016 13:20:24(GMT) - writeDebugFile - User ID : pinkeshk 02/09/2016 13:20:24(GMT) - writeDebugFile - Timezone : IST 02/09/2016 13:20:24(GMT) - writeDebugFile - IPAddress : 127.0.1.1 02/09/2016 13:20:24(GMT) - writeDebugFile - Update/Rerun : 0 02/09/2016 13:20:24(GMT) - writeDebugFile - Command line : installersrc /home/pinkeshk/Downloads/CCS6.1.2.00015_linux installertmp /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131 buildid 6.1.2.00015 installer /home/pinkeshk/Downloads/CCS6.1.2.00015_linux/ccs_setup_6.1.2.00015.bin bitness 64-bit os linux 02/09/2016 13:20:24(GMT) - writeDebugFile - CCS_WARNING: {Failed to locate 32-bit system libraries required for CCS operation: } { libgcrypt.so.11} { For more information on how to install these, please visit: http://processors.wiki.ti.com/index.php/Linux_Host_Support_CCSv6} 02/09/2016 13:20:24(GMT) - writeDebugFile - Product families selected: 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_MSP430 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_C28 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_WIRELESS 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_STELLARIS 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_SITARA 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_OMAPL13 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_C6000_SINGLE 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_C6000_MULTI 02/09/2016 13:20:24(GMT) - writeDebugFile - PF_DIGITAL_POWER 02/09/2016 13:20:24(GMT) - writeDebugFile - Components to be installed: 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_MSP430 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_MSP430 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_MSP432 02/09/2016 13:20:24(GMT) - writeDebugFile - TIVA_STELLARIS_DRIVERS 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_TI 02/09/2016 13:20:24(GMT) - writeDebugFile - MSP430_CGT_HELP 02/09/2016 13:20:24(GMT) - writeDebugFile - CGT_DEFAULTLIBS_MSP430 02/09/2016 13:20:24(GMT) - writeDebugFile - DMED 02/09/2016 13:20:24(GMT) - writeDebugFile - ARM_CGT_HELP 02/09/2016 13:20:24(GMT) - writeDebugFile - CGT_DEFAULTLIBS_TMS470 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_ARM 02/09/2016 13:20:24(GMT) - writeDebugFile - GCC_ARM_COMPILER 02/09/2016 13:20:24(GMT) - writeDebugFile - C2000_CGT_HELP 02/09/2016 13:20:24(GMT) - writeDebugFile - CGT_DEFAULTLIBS_C2800 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_CC2538 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_CC26XX 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_CC32XX 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_CC32XX_COMMON 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_STELLARIS 02/09/2016 13:20:24(GMT) - writeDebugFile - TIVA_TM4C 02/09/2016 13:20:24(GMT) - writeDebugFile - TIVA_TM4E 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_HERCULES 02/09/2016 13:20:24(GMT) - writeDebugFile - C6000_CGT_HELP 02/09/2016 13:20:24(GMT) - writeDebugFile - CGT_DEFAULTLIBS_C6000_V8P 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_INTEGRA 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_OMAP 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_DAVINCI 02/09/2016 13:20:24(GMT) - writeDebugFile - CGT_DEFAULTLIBS_C6000 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_C6000 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_C55XX 02/09/2016 13:20:24(GMT) - writeDebugFile - C5500_CGT_HELP 02/09/2016 13:20:24(GMT) - writeDebugFile - CGT_DEFAULTLIBS_C5500 02/09/2016 13:20:24(GMT) - writeDebugFile - KEYSTONE1 02/09/2016 13:20:24(GMT) - writeDebugFile - KEYSTONE2 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_C6000MC 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_UCD31XX 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_BH 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_SD 02/09/2016 13:20:24(GMT) - writeDebugFile - JRE 02/09/2016 13:20:24(GMT) - writeDebugFile - P2APP 02/09/2016 13:20:24(GMT) - writeDebugFile - ECLIPSE 02/09/2016 13:20:24(GMT) - writeDebugFile - ECLIPSECORE 02/09/2016 13:20:24(GMT) - writeDebugFile - P2TOOLS 02/09/2016 13:20:24(GMT) - writeDebugFile - GMF 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_MAIN 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_WORKFLOW 02/09/2016 13:20:24(GMT) - writeDebugFile - DVT_COMMON 02/09/2016 13:20:24(GMT) - writeDebugFile - DVT_UIA 02/09/2016 13:20:24(GMT) - writeDebugFile - DVT_VIA_CCS 02/09/2016 13:20:24(GMT) - writeDebugFile - XULRUNNER 02/09/2016 13:20:24(GMT) - writeDebugFile - INSTALLER 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_CHROME 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_TOOLS_COMMON 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_GC 02/09/2016 13:20:24(GMT) - writeDebugFile - TARGET_CONTENT_CORE 02/09/2016 13:20:24(GMT) - writeDebugFile - DS 02/09/2016 13:20:24(GMT) - writeDebugFile - DS_FLASH 02/09/2016 13:20:24(GMT) - writeDebugFile - DVT_ENERGYTRACE 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_C2000 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_C2000_FLASH 02/09/2016 13:20:24(GMT) - writeDebugFile - EMU_C2000 02/09/2016 13:20:24(GMT) - writeDebugFile - GREE_C2000_SUPPORT 02/09/2016 13:20:24(GMT) - writeDebugFile - DVT_TRACE 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_SITARA 02/09/2016 13:20:24(GMT) - writeDebugFile - DEV_SUPPORT_SHARED 02/09/2016 13:20:24(GMT) - writeDebugFile - BBONE_FTDI_DRIVERS 02/09/2016 13:20:24(GMT) - writeDebugFile - ARM_QT 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_C6000 02/09/2016 13:20:24(GMT) - writeDebugFile - IDE_C5500 02/09/2016 13:20:24(GMT) - writeDebugFile - Apps to be installed when CCS starts up: 02/09/2016 13:20:24(GMT) - writeDebugFile - iu=com.ti.gcc.msp430.linux.feature.group 02/09/2016 13:20:24(GMT) - writeDebugFile - repo=http://software-dl.ti.com/ccs/esd/msp430/ 02/09/2016 13:20:24(GMT) - writeDebugFile - iu=com.ti.cgt.pru..*.linux.feature.group:resolve 02/09/2016 13:20:24(GMT) - writeDebugFile - repo=http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/ 02/09/2016 13:20:24(GMT) - writeDebugFile - iu=org.eclipse.cdt.autotools.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.linuxtools.callgraph.feature.feature.group,org.eclipse.linuxtools.cdt.libhover.devhelp.feature.feature.group,org.eclipse.linuxtools.cdt.libhover.feature.feature.group,org.eclipse.linuxtools.changelog.c.feature.group,org.eclipse.linuxtools.ctf.feature.group,org.eclipse.linuxtools.gcov.feature.group,org.eclipse.linuxtools.gdbtrace.feature.group,org.eclipse.linuxtools.gprof.feature.feature.group,org.eclipse.linuxtools.lttng2.control.feature.group,org.eclipse.linuxtools.lttng2.kernel.feature.group,org.eclipse.linuxtools.lttng2.ust.feature.group,org.eclipse.linuxtools.profiling.feature.group,org.eclipse.linuxtools.rpm.feature.group,org.eclipse.linuxtools.tmf.ctf.feature.group,org.eclipse.linuxtools.tmf.feature.group,org.eclipse.linuxtools.valgrind.feature.group 02/09/2016 13:20:24(GMT) - writeDebugFile - repo=http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v6.1/EveElseRepo/ 02/09/2016 13:20:24(GMT) - writeDebugFile - iu=com.ti.msp430.msp430ware.linux.feature.group 02/09/2016 13:20:24(GMT) - writeDebugFile - repo=http://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/MSP430ware/update/latest/ 02/09/2016 13:20:24(GMT) - writeDebugFile - iu=com.ti.ccstudio.gui.composer.ccs.feature.group,com.ti.gc.common.feature.group,org.eclipse.wst.jsdt.feature.feature.group,com.ti.chromium.browser.feature.group 02/09/2016 13:20:24(GMT) - writeDebugFile - repo=http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v6.1/gc-ccsRepo/,http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v6.1/gcRepo/,http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v6.1/EveElseRepo/,http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v6.1/linux32/browserRepo 02/09/2016 13:20:24(GMT) - getprefix - installdir for ARM_CGT_HELP: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for C2000_CGT_HELP: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for C5500_CGT_HELP: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for C6000_CGT_HELP: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_DOC. Using Defaults. 02/09/2016 13:20:24(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_LAUNCHER. Using Defaults. 02/09/2016 13:20:24(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_UTILS. Using Defaults. 02/09/2016 13:20:24(GMT) - getprefix - installdir for DVT_COMMON: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for DVT_ENERGYTRACE: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for DVT_TRACE: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for DVT_UIA: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for DVT_VIA_CCS: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for ECLIPSE: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for EMU_SD: /home/pinkeshk/ti/ccsv6/ccs_base 02/09/2016 13:20:24(GMT) - getprefix - installdir for GMF: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_ARM: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_C2000: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_C5500: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_C6000: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_CHROME: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_GC: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_MAIN: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_MSP430: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_TOOLS_COMMON: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for IDE_WORKFLOW: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for KEYSTONE1: /home/pinkeshk/ti/ccsv6/ccs_base 02/09/2016 13:20:24(GMT) - getprefix - installdir for KEYSTONE2: /home/pinkeshk/ti/ccsv6/ccs_base 02/09/2016 13:20:24(GMT) - getprefix - installdir for MSP430_CGT_HELP: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for P2APP: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getprefix - installdir for P2TOOLS: /home/pinkeshk/ti/ccsv6/ 02/09/2016 13:20:24(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni TARGETDB_DEF_PROPS. Using Defaults. 02/09/2016 13:20:24(GMT) - getprefix - installdir for TARGET_CONTENT_CORE: /home/pinkeshk/ti/ccsv6/.. 02/09/2016 13:20:24(GMT) - Util::getProperty - No /home/pinkeshk/ti/ccsv6/eclipse/ccs.properties file found 02/09/2016 13:20:24(GMT) - Util::getProperty - No /home/pinkeshk/ti/ccsv6/eclipse/ccs.properties file found 02/09/2016 13:20:24(GMT) - ProgressPane::Run - non-threaded 02/09/2016 13:20:24(GMT) - ProgressPane::Run - RunInstall /home/pinkeshk/ti/ccsv6/eclipse/ccs_config.xml 0 0 0 0 /home/pinkeshk/ti/ccsv6/install_logs/ccs_setup_6.1.2.00015_install.log ::progressPane0 -1 02/09/2016 13:20:24(GMT) - RunMain - Started with params pConfigFile=/home/pinkeshk/ti/ccsv6/eclipse/ccs_config.xml pProfiling=0 pUpdate=0 logfile=/home/pinkeshk/ti/ccsv6/install_logs/ccs_setup_6.1.2.00015_install.log progress=::progressUpdate0 02/09/2016 13:20:24(GMT) - RunMain - encoding = utf-8 02/09/2016 13:20:24(GMT) - readConfigFile - Start installing components: 02/09/2016 13:20:24(GMT) - readConfigFile - read config file /home/pinkeshk/ti/ccsv6/eclipse/ccs_config.xml 02/09/2016 13:20:24(GMT) - readConfigFile - found /home/pinkeshk/ti/ccsv6/eclipse/ccs_config.xml 02/09/2016 13:20:24(GMT) - readConfigFile - Parsing Root Elements 02/09/2016 13:20:24(GMT) - readConfigFile - Done Parsing 02/09/2016 13:20:24(GMT) - readConfigFile - CCSDIR=/home/pinkeshk/ti/ccsv6 02/09/2016 13:20:24(GMT) - readConfigFile - EclipseDir=/home/pinkeshk/ti/ccsv6/eclipse 02/09/2016 13:20:24(GMT) - readConfigFile - InstallDir=/home/pinkeshk/ti 02/09/2016 13:20:24(GMT) - readConfigFile - TempDir=/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131 02/09/2016 13:20:24(GMT) - readConfigFile - platform=linux 02/09/2016 13:20:24(GMT) - readConfigFile - LocalBaseRepository=/home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo 02/09/2016 13:20:24(GMT) - readConfigFile - baserepourl=/home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo 02/09/2016 13:20:24(GMT) - readConfigFile - featureurl=/home/pinkeshk/Downloads/CCS6.1.2.00015_linux/featurerepo 02/09/2016 13:20:24(GMT) - readConfigFile - LocalRepository_Exists=1 02/09/2016 13:20:24(GMT) - readConfigFile - componentinstaller=false 02/09/2016 13:20:24(GMT) - readConfigFile - eclipseexe=eclipse 02/09/2016 13:20:24(GMT) - readConfigFile - in install components 02/09/2016 13:20:24(GMT) - readUserProfile - userprofile = 02/09/2016 13:20:24(GMT) - downloadIfRequired - deleted /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/jre_root.gtk.linux.x86_1.7.0.60 02/09/2016 13:20:24(GMT) - downloadIfRequired - copying /home/pinkeshk/Downloads/CCS6.1.2.00015_linux/featurerepo/binary/jre_root.gtk.linux.x86_1.7.0.60 02/09/2016 13:20:24(GMT) - downloadIfRequired - copied /home/pinkeshk/Downloads/CCS6.1.2.00015_linux/featurerepo/binary/jre_root.gtk.linux.x86_1.7.0.60 to /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/jre_root.gtk.linux.x86_1.7.0.60 02/09/2016 13:20:24(GMT) - downloadIfRequired - File /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/jre_root.gtk.linux.x86_1.7.0.60 already exists. Not attempting to download 02/09/2016 13:20:24(GMT) - extract - cmd = "unzip" -q -o -d "/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131" "/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/jre_root.gtk.linux.x86_1.7.0.60" 02/09/2016 13:20:25(GMT) - extract - successfully unzipped /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/jre_root.gtk.linux.x86_1.7.0.60 02/09/2016 13:20:25(GMT) - extract - cmd = "unzip" -q -o -d "/home/pinkeshk/ti/ccsv6/eclipse" "/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/downloads/jre_1.7.0_60.zip" 02/09/2016 13:20:28(GMT) - extract - successfully unzipped /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/downloads/jre_1.7.0_60.zip 02/09/2016 13:20:28(GMT) - installEclipse - In InstallEclipse for linux 02/09/2016 13:20:28(GMT) - installEclipse - CCS_INFO: JAVA_TOOL_OPTIONS was set to -javaagent:/usr/share/java/jayatanaag.jar , temporarily unsetting it. 02/09/2016 13:20:28(GMT) - downloadIfRequired - File /home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip already exists. Not attempting to download 02/09/2016 13:20:28(GMT) - extract - cmd = "unzip" -q -o -d "/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131" "/home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip" 02/09/2016 13:20:28(GMT) - extract - successfully unzipped /home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip 02/09/2016 13:20:28(GMT) - findLauncher - launcher version = 1.3.0.v20130327-1440 02/09/2016 13:20:28(GMT) - installEclipse - CCS_INFO: eclipse does not exist 02/09/2016 13:20:28(GMT) - installEclipse - using /home/pinkeshk/ti/ccsv6/eclipse/jre/bin/java 02/09/2016 13:20:28(GMT) - installEclipse - "/home/pinkeshk/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/cfg" "-Dosgi.instance.area=/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/ws" -jar "/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "/home/pinkeshk/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/home/pinkeshk/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arch x86 -roaming 02/09/2016 13:20:28(GMT) - runEclipseApp - running cmd "/home/pinkeshk/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/cfg" "-Dosgi.instance.area=/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/ws" -jar "/tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/home/pinkeshk/Downloads/CCS6.1.2.00015_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "/home/pinkeshk/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/home/pinkeshk/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arch x86 -roaming 02/09/2016 13:21:34(GMT) - runEclipseApp - FAILED 0: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 53256 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:21:34(GMT) - runEclipseApp - Running again 02/09/2016 13:21:49(GMT) - runEclipseApp - FAILED 1: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3288 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:21:49(GMT) - runEclipseApp - Running again 02/09/2016 13:22:03(GMT) - runEclipseApp - FAILED 2: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3208 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:22:03(GMT) - runEclipseApp - Running again 02/09/2016 13:22:17(GMT) - runEclipseApp - FAILED 3: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3117 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:22:17(GMT) - runEclipseApp - Running again 02/09/2016 13:22:31(GMT) - runEclipseApp - FAILED 4: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3276 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:22:31(GMT) - runEclipseApp - Running again 02/09/2016 13:22:46(GMT) - runEclipseApp - FAILED 5: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3427 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:22:46(GMT) - runEclipseApp - Running again 02/09/2016 13:23:00(GMT) - runEclipseApp - FAILED 6: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3099 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:23:00(GMT) - runEclipseApp - Running again 02/09/2016 13:23:14(GMT) - runEclipseApp - FAILED 7: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3294 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:23:14(GMT) - runEclipseApp - Running again 02/09/2016 13:23:28(GMT) - runEclipseApp - FAILED 8: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3317 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:23:28(GMT) - runEclipseApp - Running again 02/09/2016 13:23:43(GMT) - runEclipseApp - FAILED 9: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3180 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:23:43(GMT) - runEclipseApp - Running again 02/09/2016 13:23:57(GMT) - runEclipseApp - FAILED 10: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3287 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:23:57(GMT) - runEclipseApp - Running again 02/09/2016 13:24:11(GMT) - runEclipseApp - FAILED 11: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3187 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:24:11(GMT) - runEclipseApp - Running again 02/09/2016 13:24:25(GMT) - runEclipseApp - FAILED 12: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3214 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:24:25(GMT) - runEclipseApp - Running again 02/09/2016 13:24:40(GMT) - runEclipseApp - FAILED 13: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3521 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:24:40(GMT) - runEclipseApp - Running again 02/09/2016 13:24:54(GMT) - runEclipseApp - FAILED 14: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3233 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:24:54(GMT) - runEclipseApp - Running again 02/09/2016 13:25:08(GMT) - runEclipseApp - FAILED 15: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3221 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:25:08(GMT) - runEclipseApp - Running again 02/09/2016 13:25:23(GMT) - runEclipseApp - FAILED 16: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3314 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:25:23(GMT) - runEclipseApp - Running again 02/09/2016 13:25:37(GMT) - runEclipseApp - FAILED 17: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3313 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:25:37(GMT) - runEclipseApp - Running again 02/09/2016 13:25:51(GMT) - runEclipseApp - FAILED 18: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3193 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:25:51(GMT) - runEclipseApp - Running again 02/09/2016 13:26:05(GMT) - runEclipseApp - FAILED 19: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3127 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:26:05(GMT) - runEclipseApp - Running again 02/09/2016 13:26:05(GMT) - runEclipseApp - FAILED 20: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 3127 ms. Picked up JAVA_TOOL_OPTIONS: 02/09/2016 13:26:05(GMT) - runEclipseApp - Can't run again. 02/09/2016 13:26:05(GMT) - installEclipse - Eclipse installation failed have to exit here 02/09/2016 13:26:05(GMT) - installEclipse - CCS_ERROR: Failed to install eclipse. Cannot recover from this error. 02/09/2016 13:26:05(GMT) - installEclipse - new state: feature registered 02/09/2016 13:26:05(GMT) - checkStatus - CCS_ERROR: Installer failed to install org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group correctly. Please submit these logs to TI for analysis using the next dialog. You may also visit the TI E2E CCS Support forum for additional help. The install logs are located in: /home/pinkeshk/ti/ccsv6/install_logs. 02/09/2016 13:26:05(GMT) - checkStatus - file does not exist /tmp/ccs_2cbfd434-c13a-450f-5595-ce6e52a48131/eclipse/ws/.metadata/.log 02/09/2016 13:26:05(GMT) - checkStatus - saving /home/pinkeshk/ti/ccsv6/install_logs 02/09/2016 13:26:05(GMT) - checkStatus - CCS_ERROR: Code Composer Studio v6 installation failed.
Please give any solution for this problem.
