Hi, TI Experts
We're using DM8168 with RDK3.0.
In our usecase, when 2-channel RTSP to be received for decoding(720P30), it works properly, but when increased to 6-channel, fault emerged.
By the way, when the resolution of 6-channel received RTSP streams be set to 720*576@30, it can work properly also.
Logs as following.
1)
[m3video] 14797: Assertion @ Line: 159 in utils/src/utils_tiler.c: (UInt32)(pFrame->addr[0][0]) != SYSTEM_TILER_INVALID_ADDR : failed !!!
We analyses that it results from the insufficient capacity of Tiler Memory, So we increased it.
2)
1854:!!!SLAVE CORE [VPSS-M3] DOWN!!!
SystemLink_copySlaveCoreExceptionContext:146
mmap of [0xde9e0000:36864]
mmap virt addresss:0x400ab000
munmap of [0x400ab000:36864]
SystemLink_copySlaveCoreExceptionContext:153
[m3vpss ] 13588: Assertion @ Line: 657 in links_m3vpss/system/system_dctrl.c: retVal == FVID2_SOK : failed !!!
We doubt that it is because of the lack of buffer for LINK Creattime Initialization, so we increased SR2, but actually, we are not certain if SR2 is ready for LINK buffer.
In additional, we increased SR1, Video M3 code, Video M3 data, VPSS M3 Code, and VPSS M3 Data;
Following is the Memory map in .bld file, pls. check it, thanks!
* ======== config.bld ========
* Build configuration script for HDVPSS drivers
/* load the required modules for the configuration */
var M3 = xdc.useModule('ti.targets.arm.elf.M3');
var C674 = xdc.useModule('ti.targets.elf.C674');
var buildReleaseConfig = true;
/* configure the options for the M3 targets */
/* M3 compiler directory path */
M3.rootDir = java.lang.System.getenv("CGTOOLS");
/* linker options */
M3.lnkOpts.suffix += " --zero_init=off ";
M3.lnkOpts.suffix += " --dynamic --retain=_Ipc_ResetVector";
/* compiler options */
M3.ccOpts.suffix += " --gcc -DTI_816X_BUILD -DPLATFORM_EVM_SI -DSYSLINK_BUILD_RTOS -DUSE_SYSLINK_NOTIFY=0 -DUTILS_ASSERT_ENABLE";
/* set default platform and list of all interested
* platforms for M3
M3.platforms = [
"ti.platforms.evmTI816X:core0",
"ti.platforms.evmTI816X:core1",
/* Select the default platform
* Making core1 as defualt core configuration to be used
* Core 0 == Ducati.M3.VIDEO
* Core 1 == Ducati.M3.VPS
M3.platform = M3.platforms[1];
/* configure the options for the C674 targets */
/* C674 compiler directory path */
C674.rootDir = java.lang.System.getenv("CGTOOLS_DSP");
C674.lnkOpts.suffix += " --zero_init=off ";
C674.lnkOpts.suffix += " --dynamic --retain=_Ipc_ResetVector";
C674.ccOpts.suffix += " -DTI_816X_BUILD -DPLATFORM_EVM_SI -DSYSLINK_BUILD_RTOS -DUSE_SYSLINK_NOTIFY=0";
C674.platforms = ["ti.platforms.evmTI816X:plat"];
C674.platform = C674.platforms[0];
/* list interested targets in Build.targets array */
Build.targets = [
M3,
C674,
var KB=1024;
var MB=KB*KB;
var DDR3_ADDR;
var DDR3_SIZE;
var OCMC0_ADDR;
var OCMC1_ADDR;
var OCMC_SIZE;
var LINUX_ADDR;
var LINUX_SIZE;
var SR0_ADDR;
var SR0_SIZE;
var SR1_ADDR;
var SR1_SIZE;
var SR3_INTRADUCATI_IPC_ADDR;
var SR3_INTRADUCATI_IPC_SIZE;
var VIDEO_M3_CODE_ADDR;
var VIDEO_M3_CODE_SIZE;
var VIDEO_M3_DATA_ADDR;
var VIDEO_M3_DATA_SIZE;
var SR2_FRAME_BUFFER_ADDR;
var SR2_FRAME_BUFFER_SIZE;
var DSS_M3_CODE_ADDR;
var DSS_M3_CODE_SIZE;
var DSS_M3_DATA_ADDR;
var DSS_M3_DATA_SIZE;
var DSP_CODE_ADDR;
var DSP_CODE_SIZE;
var DSP_M3_DATA_ADDR;
var DSP_M3_DATA_SIZE;
var TILER_ADDR;
var TILER_SIZE;
var HDVPSS_DESC_ADDR;
var HDVPSS_DESC_SIZE;
var HDVPSS_SHARED_ADDR;
var HDVPSS_SHARED_SIZE;
var NOTIFY_SHARED_ADDR;
var NOTIFY_SHARED_SIZE;
var REMOTE_DEBUG_ADDR;
var REMOTE_DEBUG_SIZE;
DDR3_ADDR = 0x80000000;
DDR3_SIZE = 2048*MB;
OCMC0_ADDR = 0x40300000;
OCMC1_ADDR = 0x40400000;
OCMC0_RUN_ADDR = 0x00300000;
OCMC1_RUN_ADDR = 0x00400000;
OCMC_SIZE = 256*KB;
L2_SRAM_ADDR = 0x55024000;
L2_SRAM_SIZE = 128*KB;
L2_SRAM_RUN_ADDR = 0x20004000;
DUCATI_WB_WA_ADDR = 0x20000000;
/* first 512MB */
LINUX_SIZE = 32*MB;
SR1_SIZE = 394.5*MB;
SR3_INTRADUCATI_IPC_SIZE = 124*KB;
VIDEO_M3_CODE_SIZE = 10.5*MB;
VIDEO_M3_DATA_SIZE = 20*MB;
DSS_M3_CODE_SIZE = 9.5*MB;
DSS_M3_DATA_SIZE = 25*MB;
DSP_CODE_SIZE = 900*KB;
DSP_DATA_SIZE = 19.5*MB;
/* second 512MB */
/* Tiler Buffers in the bottom 512MB */
TILER_SIZE = 512*MB; /* (128+128) - MUST be aligned on 128MB boundary */
SR2_FRAME_BUFFER_SIZE = 490*MB - 256*KB;
SR0_SIZE = 15*MB;
VIDEO_M3_EXCEPTION_CTX_SIZE = 128*KB;
VPSS_M3_EXCEPTION_CTX_SIZE = 128*KB;
HDVPSS_DESC_SIZE = 2*MB;
HDVPSS_SHARED_SIZE = 2*MB;
NOTIFY_SHARED_SIZE = 2*MB;
REMOTE_DEBUG_SIZE = 1*MB;
/* third and fourth 512 MB */
LINUX_SIZE_SEGMENT2 = 512*MB;
print ("Memory Map - 2GB DDR, > 1GB Linux in 2 segments");
print (" 0x80000000 +-------------------+");
print (" ^ | |");
print (" | | " + (LINUX_SIZE / MB) + " MB | Linux");
print (" | | |");
print (" | +-------------------+");
print (" | | " + (SR1_SIZE / MB) + "MB | (SR1) Bitstream buffer");
print (" | | | Cached on A8. Cached on M3, although access by DMAs");
print (" | +-------------------+ ");
print (" | | " + (SR3_INTRADUCATI_IPC_SIZE / KB) + " KB | (SR3)InterDucati IPC ListMP .Cached on M3 ");
print (" + | " + (VIDEO_M3_CODE_SIZE / MB) + " MB | Video M3 Code");
print (" 512 MB +-------------------+");
print (" + | " + (VIDEO_M3_DATA_SIZE / MB) + " MB | Video M3 Data");
print (" | | " + (DSS_M3_CODE_SIZE/ MB) + " MB | VPSS M3 Code");
print (" | | " + (DSS_M3_DATA_SIZE/ MB) + " MB | VPSS M3 Data");
print (" | | " + ( DSP_CODE_SIZE / KB) + " KB | DSP Code");
print (" v | " + (DSP_DATA_SIZE / MB) + " MB | DSP Data");
print (" 0xA0000000 +-------------------+");
print (" ^ | " + (TILER_SIZE / MB) + " MB | Tiled 8-bit + 16-bit region");
print (" | | " + (SR2_FRAME_BUFFER_SIZE / MB) + " MB | (SR2) Frame Buffer Region - <VPSS - Video M3 Frame Buf>");
print (" + | |");
print (" 512 MB | " + (SR0_SIZE / MB) + " MB | (SR0) Syslink MsgQ/IPC List MP - <Non-cached on M3>");
print (" + +-------------------+");
print (" | | " + (VIDEO_M3_EXCEPTION_CTX_SIZE / KB) + " KB | Video M3 exception context");
print (" | | " + (VPSS_M3_EXCEPTION_CTX_SIZE / KB) + "KB | Vpss M3 exception context");
print (" | | " + (HDVPSS_DESC_SIZE / MB) + " MB | VPSS M3 - VPDMA Descriptor");
print (" | | " + (HDVPSS_SHARED_SIZE / MB) + " MB | VPSS M3 - FBDev Shared Memory");
print (" | | " + (NOTIFY_SHARED_SIZE / MB) + " MB | Host - VPSS M3 Notify(For FBDev)");
print (" v | " + (REMOTE_DEBUG_SIZE / MB) + " MB | Remote Debug Print");
print (" 0xC0000000 +-------------------+");
print (" ^ | |");
print (" | | |");
print (" | | " + (LINUX_SIZE_SEGMENT2 / MB) + " MB | Memory for Linux Kernel");
print (" | | |" + " Available only in split of linux kernel");
print (" | | |");
print (" v | |");
print (" 0xFFFFFFFF +-------------------+");
/* first 512MB */
LINUX_ADDR = DDR3_ADDR;
SR1_ADDR = LINUX_ADDR + LINUX_SIZE;
SR3_INTRADUCATI_IPC_ADDR = SR1_ADDR + SR1_SIZE;
VIDEO_M3_CODE_ADDR = SR3_INTRADUCATI_IPC_ADDR + SR3_INTRADUCATI_IPC_SIZE;
VIDEO_M3_DATA_ADDR = VIDEO_M3_CODE_ADDR + VIDEO_M3_CODE_SIZE;
DSS_M3_CODE_ADDR = VIDEO_M3_DATA_ADDR + VIDEO_M3_DATA_SIZE;
DSS_M3_DATA_ADDR = DSS_M3_CODE_ADDR + DSS_M3_CODE_SIZE;
DSP_CODE_ADDR = DSS_M3_DATA_ADDR + DSS_M3_DATA_SIZE;
DSP_DATA_ADDR = DSP_CODE_ADDR + DSP_CODE_SIZE;
/* second 512MB */
TILER_ADDR = DSP_DATA_ADDR + DSP_DATA_SIZE;
/* second 512MB */
SR2_FRAME_BUFFER_ADDR = TILER_ADDR + TILER_SIZE;
VIDEO_M3_EXCEPTION_CTX_ADDR = SR2_FRAME_BUFFER_ADDR + SR2_FRAME_BUFFER_SIZE;
VPSS_M3_EXCEPTION_CTX_ADDR = VIDEO_M3_EXCEPTION_CTX_ADDR + VIDEO_M3_EXCEPTION_CTX_SIZE;
HDVPSS_DESC_ADDR = VPSS_M3_EXCEPTION_CTX_ADDR + VPSS_M3_EXCEPTION_CTX_SIZE;
HDVPSS_SHARED_ADDR = HDVPSS_DESC_ADDR + HDVPSS_DESC_SIZE;
NOTIFY_SHARED_ADDR = HDVPSS_SHARED_ADDR + HDVPSS_SHARED_SIZE;
REMOTE_DEBUG_ADDR = NOTIFY_SHARED_ADDR + NOTIFY_SHARED_SIZE;
SR0_ADDR = REMOTE_DEBUG_ADDR + REMOTE_DEBUG_SIZE;
Build.platformTable["ti.platforms.evmTI816X:core1"] =
externalMemoryMap:
["DDR3_RAM", {
comment: "DDR3_RAM",
base: DDR3_ADDR,
len: DDR3_SIZE
["OCMC1_RAM", {
comment: "OCMC1_RAM",
base: OCMC1_ADDR,
len: OCMC_SIZE
customMemoryMap:
["LINUX_MEM", {
comment : "LINUX_MEM",
base : LINUX_ADDR,
len : LINUX_SIZE
["SR1", {
comment : "SR1",
base : SR1_ADDR,
len : SR1_SIZE
["SR3_INTRADUCATI_IPC", {
comment : "SR3_INTRADUCATI_IPC",
base : SR3_INTRADUCATI_IPC_ADDR,
len : SR3_INTRADUCATI_IPC_SIZE
["VIDEO_M3_CODE_MEM", {
comment : "VIDEO_M3_CODE_MEM",
base : VIDEO_M3_CODE_ADDR,
len : VIDEO_M3_CODE_SIZE
["VIDEO_M3_DATA_MEM", {
comment : "VIDEO_M3_DATA_MEM",
base : VIDEO_M3_DATA_ADDR,
len : VIDEO_M3_DATA_SIZE
["DSS_M3_CODE_MEM", {
comment : "DSS_M3_CODE_MEM",
base : DSS_M3_CODE_ADDR,
len : DSS_M3_CODE_SIZE
["DDR3_M3", {
comment : "DDR3_M3",
base : DSS_M3_DATA_ADDR,
len : DSS_M3_DATA_SIZE
["DSP_CODE_MEM", {
comment : "DSP_CODE_MEM",
base : DSP_CODE_ADDR,
len : DSP_CODE_SIZE
["DSP_DATA_MEM", {
comment : "DSP_DATA_MEM",
base : DSP_DATA_ADDR,
len : DSP_DATA_SIZE
["TILER_MEM", {
comment : "TILER_MEM",
base : TILER_ADDR,
len : TILER_SIZE
["SR2_FRAME_BUFFER_MEM", {
comment : "SR2_FRAME_BUFFER_MEM",
base : SR2_FRAME_BUFFER_ADDR,
len : SR2_FRAME_BUFFER_SIZE
["SR0", {
comment : "SR0",
base : SR0_ADDR,
len : SR0_SIZE
["VIDEO_M3_EXCEPTION_CTX", {
comment : "VIDEO_M3_EXCEPTION_CTX",
base : VIDEO_M3_EXCEPTION_CTX_ADDR,
len : VIDEO_M3_EXCEPTION_CTX_SIZE
["VPSS_M3_EXCEPTION_CTX", {
comment : "VPSS_M3_EXCEPTION_CTX",
base : VPSS_M3_EXCEPTION_CTX_ADDR,
len : VPSS_M3_EXCEPTION_CTX_SIZE
["HDVPSS_DESC_MEM", {
comment : "HDVPSS_DESC_MEM",
base : HDVPSS_DESC_ADDR,
len : HDVPSS_DESC_SIZE
["HDVPSS_SHARED_MEM", {
comment : "HDVPSS_SHARED_MEM",
base : HDVPSS_SHARED_ADDR,
len : HDVPSS_SHARED_SIZE
["HOST_VPSS_NOTIFYMEM", {
comment : "HOST_VPSS_NOTIFYMEM",
base : NOTIFY_SHARED_ADDR,
len : NOTIFY_SHARED_SIZE
["REMOTE_DEBUG_MEM", {
comment : "REMOTE_DEBUG_MEM",
base : REMOTE_DEBUG_ADDR,
len : REMOTE_DEBUG_SIZE
["L2_ROM", {
comment: "L2_ROM",
base: 0x00000000,
len: 0x00004000
["OCMC1_RAM", {
base: OCMC1_ADDR,
len: OCMC_SIZE
["OCMC1_RAM_MAPPED", {
base: OCMC1_RUN_ADDR,
len: OCMC_SIZE
Build.platformTable["ti.platforms.evmTI816X:core0"] =
externalMemoryMap:
["DDR3_RAM", {
base: DDR3_ADDR,
len: DDR3_SIZE
["OCMC0_RAM", {
comment: "OCMC0_RAM",
base: OCMC0_ADDR,
len: OCMC_SIZE
["L2_SRAM", {
comment: "L2_SRAM",
base: L2_SRAM_ADDR,
len: L2_SRAM_SIZE
["L2_SRAM_RUN", {
comment: "L2_SRAM_RUN",
base: L2_SRAM_RUN_ADDR,
len: L2_SRAM_SIZE
customMemoryMap:
["LINUX_MEM", {
base : LINUX_ADDR,
len : LINUX_SIZE
["SR1", {
comment : "SR1",
base : SR1_ADDR,
len : SR1_SIZE
["DDR_M3", {
["DSS_M3_DATA_MEM", {
comment : "DSS_M3_DATA_MEM",
["DSP_CODE_MEM", {
len : DSP_CODE_SIZE
["DSP_DATA_MEM", {
len : DSP_DATA_SIZE
["TILER_MEM", {
base : TILER_ADDR,
len : TILER_SIZE
["SR0", {
comment : "SR0",
base : SR0_ADDR,
len : SR0_SIZE
["L2_SRAM", {
comment: "L2_SRAM",
base: L2_SRAM_ADDR,
len: L2_SRAM_SIZE
["L2_SRAM_RUN", {
len: L2_SRAM_SIZE
["L2_ROM", {
comment: "L2_ROM",
base: 0x00000000,
len: 0x00004000
["OCMC0_RAM", {
base: OCMC0_ADDR,
len: OCMC_SIZE
["OCMC0_RAM_MAPPED", {
base: OCMC0_RUN_ADDR,
len: OCMC_SIZE
Build.platformTable["ti.platforms.evmTI816X:plat"] =
externalMemoryMap:
["DDR3_RAM", {
base: DDR3_ADDR,
len: DDR3_SIZE
["OCMC0_RAM", {
base: OCMC0_ADDR,
len: OCMC_SIZE
["OCMC1_RAM", {
base: OCMC1_ADDR,
len: OCMC_SIZE
customMemoryMap:
["LINUX_MEM", {
base : LINUX_ADDR,
len : LINUX_SIZE
["SR1", {
comment : "SR1",
base : SR1_ADDR,
len : SR1_SIZE
["DSP_CODE_MEM", {
len : DSP_CODE_SIZE
["DSP_DATA_MEM", {
comment : "DDR3_DSP",
len : DSP_DATA_SIZE
["TILER_MEM", {
base : TILER_ADDR,
len : TILER_SIZE
["SR0", {
comment : "SR0",
base : SR0_ADDR,
len : SR0_SIZE
["OCMC0_RAM", {
base: OCMC0_ADDR,
len: OCMC_SIZE
["OCMC1_RAM", {
base: OCMC1_ADDR,
len: OCMC_SIZE
["DSP_L2_RAM", {
comment: "DSP_L2_RAM",
base: 0x10800000,
len: 0x00020000
l1PMode: "32k",
l1DMode: "32k",
l2Mode: "128k"
var addrFileGenerated = false;
if (addrFileGenerated == false)
xdc.loadCapsule("genaddrinfo.xs").GenAddrFile();
addrFileGenerated = true;
How can I fix this issue?
Best Regards!
