My customer test the HEVC encoder (C66x_h265venc_01_00_00_44_ELF) on single C6678 chip. The detail test parameter please refer to attached encparam.txt. (1080p30 with 1Mbps,qpMax 40,qpMin20). If the test clip has big block movement or the background has gradual changing color, the quality is not good. Please refer to attached encode result enc1920x1080Hpayload_108.265.
Would you kindly check this and suggest how to improve the quality by configuration (Guarantee 30fps)?
Best Regards.
Marvin
//StaticParams - IVIDENC2_Params pStaticEnc->videnc2Params.size = sizeof(IH265VENC_Params); pStaticEnc->videnc2Params.encodingPreset = 4; // 0: DEFAULT, 1: HIGH_QUALITY, 2: HIGH_SPEED, 3: USER_DEFINED. If not USER_DEFINED most of configuration parameters are chosen by encoder, thus ignored. pStaticEnc->videnc2Params.rateControlPreset = 2; // 1: LOW_DELAY, 2: STORAGE, 4: NONE, 5: USER_DEFINED pStaticEnc->videnc2Params.maxWidth = 1920; pStaticEnc->videnc2Params.maxHeight = 1080; pStaticEnc->videnc2Params.dataEndianness = XDM_BYTE; // Not configurable pStaticEnc->videnc2Params.maxInterFrameInterval = 1; // Max I to P frame distance. 1: no B frames, 2: one B frame, 3: two B frames, etc [1, 255] pStaticEnc->videnc2Params.maxBitRate = 1024*1200; // In bits per second. Should be valid as per LEVEL limit pStaticEnc->videnc2Params.minBitRate = 1024*1024; // In bits per second pStaticEnc->videnc2Params.inputChromaFormat = XDM_YUV_420P; // Not configurable pStaticEnc->videnc2Params.inputContentType = IVIDEO_PROGRESSIVE; // 0: PROGRESSIVE, 1: INTERLACED pStaticEnc->videnc2Params.operatingMode = IVIDEO_ENCODE_ONLY; // Not configurable pStaticEnc->videnc2Params.profile = IH265_MAIN_PROFILE; // TODO: change description pStaticEnc->videnc2Params.level = IH265_LEVEL_41; // TODO: change description pStaticEnc->videnc2Params.inputDataMode = IVIDEO_ENTIREFRAME; // Not configurable pStaticEnc->videnc2Params.outputDataMode = IVIDEO_ENTIREFRAME; // Not configurable pStaticEnc->videnc2Params.numInputDataUnits = 1; pStaticEnc->videnc2Params.numOutputDataUnits = 1; int i; for (i = 0 ; i < IVIDEO_MAX_NUM_METADATA_PLANES; i++) { pStaticEnc->videnc2Params.metadataType[i] = IVIDEO_METADATAPLANE_NONE; } //StaticParams - Misc pStaticEnc->scalingMatrixPreset = IH265_SCALINGMATRIXPRESET_DEFAULT; pStaticEnc->decRefreshType = 0; // Decoder referesh type: IDR or CDR [0 or 1]. pStaticEnc->decRefreshInterval = 0; pStaticEnc->enableTransQuantBypass = 0; pStaticEnc->maxPoc = 256; pStaticEnc->enableTransformSkip = 0; pStaticEnc->maxIntraFrameInterval = 10000; pStaticEnc->enableWPP = 1; pStaticEnc->maxNumRefFrames = 1; pStaticEnc->enableVirtualTile = 31; pStaticEnc->disableVirtualTileDependency = 0; pStaticEnc->debugTraceLevel = 0; pStaticEnc->lastNFramesToLog = 0; //StaticParams - IH265VENC_RateControlParams pStaticEnc->rateControlParams.rateControlParamsPreset = IH265_RATECONTROLPARAMS_USERDEFINED; pStaticEnc->rateControlParams.rcAlgo = IH265_RATECONTROL_CBR; pStaticEnc->rateControlParams.qpI = 28; pStaticEnc->rateControlParams.qpMaxI = 40; pStaticEnc->rateControlParams.qpMinI = 20; pStaticEnc->rateControlParams.qpP = 28; pStaticEnc->rateControlParams.qpMaxP = 40; pStaticEnc->rateControlParams.qpMinP = 20; pStaticEnc->rateControlParams.qpOffsetB = 4; pStaticEnc->rateControlParams.qpMaxB = 40; pStaticEnc->rateControlParams.qpMinB = 20; pStaticEnc->rateControlParams.enableFrameSkip = 0; pStaticEnc->rateControlParams.enablePartialFrameSkip = 0; pStaticEnc->rateControlParams.qualityFactorIP = 0; pStaticEnc->rateControlParams.cbQPIndexOffset = 2; pStaticEnc->rateControlParams.crQPIndexOffset = 2; pStaticEnc->rateControlParams.initialBufferLevel = 2000000; pStaticEnc->rateControlParams.hrdBufferSize = 2000000; pStaticEnc->rateControlParams.enableHRDComplianceMode = 0; pStaticEnc->rateControlParams.maxFrameSkipCnt = 0; pStaticEnc->rateControlParams.SubFrameRC = 0; pStaticEnc->rateControlParams.maxDeltaQP = 0; pStaticEnc->rateControlParams.enablePRC = 0; //StaticParams - IH265VENC_LoopFilterParams pStaticEnc->loopFilterParams.loopFilterParamsPreset = IH265_SLICECODINGPRESET_USERDEFINED; pStaticEnc->loopFilterParams.enableDeblockFilter = 1; pStaticEnc->loopFilterParams.enableSaoFilter = 1;// sao quality better pStaticEnc->loopFilterParams.enableLoopFilterSliceBoundary = 0; pStaticEnc->loopFilterParams.enableLoopFilterTileBoundary = 0; pStaticEnc->loopFilterParams.separateCbCrSAO = 0; pStaticEnc->loopFilterParams.offsetLoopFilterInPPSFlag = 0; pStaticEnc->loopFilterParams.offsetDeblockBetaDiv2 = 0; pStaticEnc->loopFilterParams.offsetDeblockTcDiv2 = 0; //StaticParams - IH265VENC_GopCntrlParams pStaticEnc->gopCntrlParams.gopCntrlParamsPreset = IH265_GOPCTRLPRESET_DEFAULT; //StaticParams - IH265VENC_SliceCodingParams pStaticEnc->sliceCodingParams.sliceCodingPreset = IH265_SLICECODINGPRESET_USERDEFINED; pStaticEnc->sliceCodingParams.sliceCodingMode = 0; pStaticEnc->sliceCodingParams.sliceCodingArg = 0; pStaticEnc->sliceCodingParams.enableTiles = 0; pStaticEnc->sliceCodingParams.numTileColumns = 2; pStaticEnc->sliceCodingParams.numTileRows = 2; pStaticEnc->sliceCodingParams.enableDependentSlice = 0; //StaticParams - IH265VENC_IntraCodingParams pStaticEnc->intraCodingParams.intraCodingPreset = IH265_INTRACODINGPRESET_USERDEFINED; pStaticEnc->intraCodingParams.intraRefreshMethod = 0; pStaticEnc->intraCodingParams.intraRefreshRate = 0; pStaticEnc->intraCodingParams.constrainedIntraPredEnable = 0; pStaticEnc->intraCodingParams.enableStrongIntraSmoothing = 1; pStaticEnc->intraCodingParams.matchYCbCrIntraMode = 0; pStaticEnc->intraCodingParams.enableLumaIntra4x4Mode = 0; pStaticEnc->intraCodingParams.enableLumaIntra8x8Mode = 0; pStaticEnc->intraCodingParams.enableLumaIntra16x16Mode = 0; pStaticEnc->intraCodingParams.enableLumaIntra32x32Mode = 0; pStaticEnc->intraCodingParams.enableChromaIntra4x4Mode = 0; pStaticEnc->intraCodingParams.enableChromaIntra8x8Mode = 0; pStaticEnc->intraCodingParams.enableChromaIntra16x16Mode = 0; //StaticParams - IH265VENC_InterCodingParams pStaticEnc->interCodingParams.interCodingPreset = IH265_INTERCODINGPRESET_USERDEFINED; pStaticEnc->interCodingParams.enableTmvp = 0; pStaticEnc->interCodingParams.searchRangeHorP = 144; pStaticEnc->interCodingParams.searchRangeVerP = 32; pStaticEnc->interCodingParams.searchRangeHorB = 144; pStaticEnc->interCodingParams.searchRangeVerB = 32; pStaticEnc->interCodingParams.interCodingBias = 0; pStaticEnc->interCodingParams.skipMVCodingBias = 0; pStaticEnc->interCodingParams.numMergeCandidates = 3; pStaticEnc->interCodingParams.enableBiPredMode = 1; pStaticEnc->interCodingParams.enableFastIntraAlgo = 1; //StaticParams - IH265VENC_VUICodingParams pStaticEnc->vuiCodingParams.vuiCodingPreset = IH265_VUICODINGPRESET_DEFAULT; pStaticEnc->vuiCodingParams.aspectRatioInfoPresentFlag = 0; pStaticEnc->vuiCodingParams.aspectRatioIdc = 0; pStaticEnc->vuiCodingParams.videoSignalTypePresentFlag = 0; pStaticEnc->vuiCodingParams.videoFormat = 0; pStaticEnc->vuiCodingParams.videoFullRangeFlag = 0; pStaticEnc->vuiCodingParams.colourDescriptionPresentFlag = 0; pStaticEnc->vuiCodingParams.colourPrimaries = 0; pStaticEnc->vuiCodingParams.transferCharacteristics = 0; pStaticEnc->vuiCodingParams.matrixCoefficients = 0; pStaticEnc->vuiCodingParams.timingInfoPresentFlag = 0; //StaticParams - IH265VENC_SEIParams pStaticEnc->seiParams.enableSeiFlag = 0; //StaticParams - IH265VENC_CTBCodingParams pStaticEnc->ctbCodingParams.maxCTBSize = 64; pStaticEnc->ctbCodingParams.maxCUDepth = 3; //DynamicParams - IVIDENC2_DynamicParams IH265VENC_DynamicParams* pDynEnc = (IH265VENC_DynamicParams*)pDynParam; pDynEnc->videnc2DynamicParams.size = sizeof(IH265VENC_DynamicParams); pDynEnc->videnc2DynamicParams.inputWidth = 1920; pDynEnc->videnc2DynamicParams.inputHeight = 1080; pDynEnc->videnc2DynamicParams.refFrameRate = 30 * 1000; pDynEnc->videnc2DynamicParams.targetFrameRate = 30 * 1000; pDynEnc->videnc2DynamicParams.targetBitRate = 1024*1024; pDynEnc->videnc2DynamicParams.intraFrameInterval = 3000; // The number of frames between two I frames. 0: IPPPP..., 1: IIII..., 2: IPIPIPIPI, 3: IPPIPPIPPI or IPBIPBIPBI, etc. pDynEnc->videnc2DynamicParams.generateHeader = XDM_ENCODE_AU; // 0: Encode entire access unit including headers, 1: Encode only header pDynEnc->videnc2DynamicParams.captureWidth = 0; pDynEnc->videnc2DynamicParams.forceFrame = IVIDEO_NA_FRAME; // -1: IVIDEO_NA_FRAME, 3: IVIDEO_IDR_FRAME pDynEnc->videnc2DynamicParams.interFrameInterval = 1; // I to P frame distance. 1: no B frames, 2: one B frame, 3: two B frames, etc [1, 255] pDynEnc->videnc2DynamicParams.mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL; // Motion vectors accuracy. 0: integer pel., 2: quarter pel. pDynEnc->videnc2DynamicParams.sampleAspectRatioHeight = 1; pDynEnc->videnc2DynamicParams.sampleAspectRatioWidth = 1; pDynEnc->videnc2DynamicParams.ignoreOutbufSizeFlag = XDAS_FALSE; // Non configurable pDynEnc->videnc2DynamicParams.putDataFxn = NULL; pDynEnc->videnc2DynamicParams.putDataHandle = 0; pDynEnc->videnc2DynamicParams.getDataFxn = NULL; pDynEnc->videnc2DynamicParams.getDataHandle = 0; pDynEnc->videnc2DynamicParams.getBufferFxn = NULL; pDynEnc->videnc2DynamicParams.getBufferHandle = 0; pDynEnc->videnc2DynamicParams.lateAcquireArg = 0; memcpy(&pDynEnc->rateControlParams, &pStaticEnc->rateControlParams, sizeof(pStaticEnc->rateControlParams)); memcpy(&pDynEnc->loopFilterParams, &pStaticEnc->loopFilterParams, sizeof(pStaticEnc->loopFilterParams)); memcpy(&pDynEnc->intraCodingParams, &pStaticEnc->intraCodingParams, sizeof(pStaticEnc->intraCodingParams)); memcpy(&pDynEnc->interCodingParams, &pStaticEnc->interCodingParams, sizeof(pStaticEnc->interCodingParams)); memcpy(&pDynEnc->ctbCodingParams, &pStaticEnc->ctbCodingParams, sizeof(pStaticEnc->ctbCodingParams)); memcpy(&pDynEnc->sliceCodingParams, &pStaticEnc->sliceCodingParams, sizeof(pStaticEnc->sliceCodingParams)); pDynEnc->enableTransQuantBypass = pStaticEnc->enableTransQuantBypass; pDynEnc->enableTransformSkip = pStaticEnc->enableTransformSkip; pDynEnc->enableROI = 0;
