The MPU I use is AM335X. Is there any project for SYS/BIOS with IAR? Not with CCS!
Hi Kai --
We do not support the IAR workbench at this time. You need to use CCS if you want to use SYS/BIOS.
-Karl-
It is possible if you compile the project outside the IAR and then use the .out file in the IAR to download and debug. I've found the procedure here. At this time I have this working but only if a use a single .c file. Does anyone knows what I need to do in the makefile to join other .c files?
Thank you
