How to create RTSC configuration file ??
How to check the memory that has taken by any code??
How to place a simple c code in particular memory sections??
Thanks & Regards,
Gopal
Thanks & Regards,
Gopal
Gopal,
those are very open-ended questions. Are you planning to use SYS/BIOS (TI-RTOS)? You can start here: http://processors.wiki.ti.com/index.php/Category:SYSBIOS and here: http://processors.wiki.ti.com/index.php/TI-RTOS_Workshop.
Hi sasha,
Thank you for your reply. Yes i'm planning to use RTOS.
Actually i'm working on LTE uplink implementation on DSP.
I have a PUCCH transmitter (floating point C Code)which is running in CCS less than 1ms according to standards.
I have to implement this in real time on the DSP. I know we have to use RTOS concepts. I got some examples in sys/bios projects but i'm not getting clarity how to run my code in real time.
The question iswhich example i need to take and in which portion i need to include my code.
Can i have any procedure for implementing in real time.
Thanks & Regards,
Gopal
Are you asking how to run your code on the actual hardware? Which board do you have? There are many boards supported by CCS. If yours is supported, you can select it when creating a project and then use your board when running the code. Which version of CCS are you using?
