Hi ,
Am getting the following error wen i run my program -
ti.sysbios.heaps.HeapMem: line 307: out of memory: handle=0xa016aa68, size=4286568952 ti.sysbios.family.c64p.EventCombiner: line 220: E_unpluggedEvent: Event# 119 is unplugged xdc.runtime.Error.raise: terminating execution
ROV shows
,ti.sysbios.family.c64p.Hwi,Module,N/A,hwiStackPeak,Overrun!
After going through several related threads in the forum - i did some debugging procedures and still the error exists .
* Tried increasing my heap size in Properties >Linker > Basic options > Heap size : 0xFFFF
* also changed my program.stack size in the .cfg . Still the error persist.
Below is my .cfg file
/* * Copyright 2009 by Texas Instruments Incorporated. * * All rights reserved. Property of Texas Instruments Incorporated. * Restricted rights to use, duplicate or disclose this code are * granted through contract. * */ /* THIS FILE WAS GENERATED BY ti.sysbios.genx */ /* * ======== bcp.cfg ======== * */ /* Load all required BIOS/XDC runtime packages */ var Memory = xdc.useModule('xdc.runtime.Memory'); var BIOS = xdc.useModule('ti.sysbios.BIOS'); var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem'); var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf'); var Log = xdc.useModule('xdc.runtime.Log'); var Task = xdc.useModule('ti.sysbios.knl.Task'); var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore'); var Hwi = xdc.useModule('ti.sysbios.family.c64p.Hwi'); var ECM = xdc.useModule('ti.sysbios.family.c64p.EventCombiner'); var Timestamp = xdc.useModule('xdc.runtime.Timestamp'); var TimestampProvider = xdc.useModule('ti.sysbios.family.c64p.TimestampProvider'); var Clock = xdc.useModule('ti.sysbios.knl.Clock'); //Timestamp.SupportProxy = xdc.useModule('xdc.runtime.TimestampStd'); /* Load the CSL package */ var Csl = xdc.useModule('ti.csl.Settings'); /* Load the CPPI package */ var Cppi = xdc.loadPackage('ti.drv.cppi'); /* Load the QMSS package */ var Qmss = xdc.loadPackage('ti.drv.qmss'); /* Load the PA package */ var Pa = xdc.loadPackage('ti.drv.pa'); /* Load the BCP package */ //var Bcp = xdc.loadPackage('ti.drv.bcp'); /* Load the FFTC package */ //var Fftc = xdc.loadPackage('ti.drv.fftc'); /* Load the SRIO driver package */ var Srio = xdc.loadPackage('ti.drv.srio'); var System = xdc.useModule('xdc.runtime.System'); SysStd = xdc.useModule('xdc.runtime.SysStd'); var Startup = xdc.useModule('xdc.runtime.Startup'); System.SupportProxy = SysStd; System.extendedFormats = "%f"; /* Create a default system heap using ti.bios.HeapMem. */ var heapMemParams1 = new HeapMem.Params; heapMemParams1.size = 8192 * 70; heapMemParams1.sectionName = "systemHeap"; Program.global.heap0 = HeapMem.create(heapMemParams1); Program.stack = 16384; /* This is the default memory heap. */ Memory.defaultHeapInstance = Program.global.heap0; Program.sectMap["systemHeap"] = Program.platform.stackMemory; /****** IPC - Shared Memory Settings ********/ /* IPC packages */ //Startup.firstFxns.$add('&initPlatform'); var Ipc = xdc.useModule('ti.sdo.ipc.Ipc'); var cslSettings = xdc.useModule ('ti.csl.Settings'); var cacheEnabled = true; var cacheLineSize = 128; var procName = null; var procNameList = []; var Settings = xdc.module('ti.sdo.ipc.family.Settings'); var Cache = xdc.useModule('ti.sysbios.family.c66.Cache'); var MessageQ = xdc.module('ti.sdo.ipc.MessageQ'); var Notify = xdc.module('ti.sdo.ipc.Notify'); var Ipc = xdc.useModule('ti.sdo.ipc.Ipc'); Notify.SetupProxy = xdc.module(Settings.getNotifySetupDelegate()); MessageQ.SetupTransportProxy= xdc.module(Settings.getMessageQSetupDelegate()); /* Use shared memory IPC */ Notify.SetupProxy = xdc.module('ti.sdo.ipc.family.c647x.NotifyCircSetup'); MessageQ.SetupTransportProxy = xdc.module('ti.sdo.ipc.transports.TransportShmNotifySetup'); var ListMP = xdc.useModule('ti.sdo.ipc.ListMP'); var GateMP = xdc.useModule('ti.sdo.ipc.GateMP'); var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion'); var HeapMemMP = xdc.useModule('ti.sdo.ipc.heaps.HeapMemMP'); Program.global.NOTIFYSETUP = Notify.SetupProxy.delegate$.$name; Program.global.TRANSPORTSETUP = MessageQ.SetupTransportProxy.delegate$.$name; var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc'); var memmap = Program.cpu.memoryMap; /* Configure the shared memory heap for shared memory allocations required by the * CPPI and QMSS Libraries */ SharedRegion.translate = false; /* Create a shared memory heap */ MultiProc.setConfig(null, ["CORE0"]); /* Synchronize all processors (this will be done in Ipc_start) */ Ipc.procSync = Ipc.ProcSync_ALL; /* To avoid wasting shared memory for Notify and MessageQ transports */ for (var i = 0; i < MultiProc.numProcessors; i++) { Ipc.setEntryMeta({ remoteProcId: i, setupNotify: false, setupMessageQ: false, }); } /* Create a shared memory */ SharedRegion.setEntryMeta(0, { base: 0x0C010000, len: 0x00100000, ownerProcId: 0, isValid: true, name: "sharemem", }); /* Enable BIOS Task Scheduler */ BIOS.taskEnabled = true; /* * Enable Event Groups here and registering of ISR for specific GEM INTC is done * using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs */ ECM.eventGroupHwiNum[0] = 7; ECM.eventGroupHwiNum[1] = 8; ECM.eventGroupHwiNum[2] = 9; ECM.eventGroupHwiNum[3] = 10; /* * @(#) ti.sysbios.genx; 2, 0, 0, 0,275; 4-29-2009 15:45:06; /db/vtree/library/trees/avala/avala-k25x/src/ */ BIOS.libType = BIOS.LibType_Debug; BIOS.assertsEnabled = true; BIOS.logsEnabled = true; BIOS.rtsGateType = BIOS.GateHwi; BIOS.clockEnabled = false; BIOS.customCCOpts = "-mv6600 --abi=eabi -q -mi10 -mo -pdr -pden -pds=238 -pds=880 -pds1110 --program_level_compile -g"; Program.sectMap[".text"] = "DDR3"; Program.sectMap[".const"] = "DDR3"; Program.sectMap[".qmss"] = "MSMCSRAM"; Program.sectMap[".cppi"] = "MSMCSRAM";
