We have 2 questions about TUSB9261
- Does TUSB9261 support encryption function (Fujitsu MB86C311 has that function)?
- We could only find binary file from the web(http://www.ti.com/lit/zip/sllc416).
Could you provide firmware source code?
The TUSB9261 doesn't support encryption. About the source code, TI doesn't usually provide the TUSB9261 FW source code (only in certain cases).
Could you specify what is the application you want for the TUSB9261 and the business case?
Thanks and Best Regards,
Alexis Cortes.
Application is similar to ISO Stick (http://isostick.com/).
Customer is reviewing Fujitsu solution as I mentioned.
I introduced TI solution and they asked some questions.
They will decided solution soon, and start development.
so, do you mean it is not possible to provide source code to the customer?
Wooseong - are you working wtih a TI rep who can help us ensure all proper details can be provided to consider source code?
I am working in WT Technology Korea which is distributor of TI in Korea.
I asked this question to TI Korea first, and they had me use E2E for ROM customers.
