In theXIO2001 data sheet, I can find the "AC peak common mode input voltage", which is 140mV max. In the comment for this voltage, you can see that you need VRX-CM-DC to calculate this voltage.
But I can not find any limiting values for VRX-CM-DC. I this correct?
When I drive the REFCLK pins with a LVDS clock source, the XIO2001 is not able to generate the 33MHz PCI-Clock:
Do you have any idea why?
Regards, Niels
