Hi all
Would you mind if we ask DP83822IF?
Could you share recommended land pattern?
On the datasheet P107, it shows recommended land pattern for Thermal Pad only.
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Hi Matsumoto-san,
We do not have a suggested land pattern for the DP83822, but attached below is a land pattern from a similar package.
The difference is that the thermal pad area must be changed. In the below document, the thermal pad is 3.15mm square.
In the DP83822, the thermal pad is 2.9mm square. Please adjust your land pattern accordingly.
