Hello Team,
One of my customer is using TPIC8101 and have few queries, can you please help on the same.
- How mux inside the TPIC8101 can be used? What is the default state selection Ch1 or Ch2?
- Want to interface 4 knock interfaces. Can we use 2 number of knock sensor with TPIC8101 by using internal mux or each knock sensor should interface with external mux?
- Does SPI data out can provide data from knock sensors? Or only analog data output from DAC is available?
- Can TPC8101 acts as SPI master? How to configure this? Planning to use CP2102 as slave SPI device
- What DSP & DSP control mentioned in block schematic, what performance and output this will provide to user?
Thanks in advance for your help and support.
Regards, Shinu Mathew.
