Hi Sir,
Our customer wan to check the XIO2213B support Modern Standby.
But, I can't see the Modern Standby in Datasheet, Do you know XIO2213B support Modern Standby?
Hugo
Hello Hugo-
The XIO2213B supports low power states and can be used in Modern Standby systems.
Davor
Hi Davor,
Thank you very much.
As I Know, Modern Standby need support D3 Hot/Clod & L1 Substate , But we only see the D3 hot on datasheet.
May I double check with you, Does XIO2213B support this function?
XIO2213ZAY REFERENCE DESIGN PDF include Modern Standby?
Hugo
Hello -
While the TI XIO2213B supports low power states including L1 state, it does not support L1 sub-states (L1.1 and L1.2)
Davor
