Hi team,
Could you please kindly help to confirm which parameter should i refer to for the working voltage and working current range of the pin Dout+/Dout- on the datasheet, following are the parameter customer want to know and the parameter we can found on datasheet, could you please kindly help to confirm if the parameter shows on the attached picture is the parameter that customer are asking? But i still not sure with which parameter should I refer for the working type voltage and min&max output current, could you please also kindly help to give some explanation about these value? Thank you very much for your kindly support.
Working voltage |
Working Current |
Min |
type |
Max |
Min |
type |
Max |
FPD-link Dou0- |
FPD-link Dout1+ |
FPD-link Dou0+ |
FPD-link Dout1- |
Best regards
Jessica
