Hi team,
I have a question about the configuration of Ethernet PHY device could you please help me with it?
You know some of the operation mode of PHY is configured through some hardware strap pins. And the state of those pins are sampled and latched during power up reset. Meanwhile those strap pins also act as other functions and are connected to CPU pins. This introduces a potential issue: the state of the strap pins may be dominant by CPU pins and wrong state is sampled by PHY which result wrong configuration of PHY. How should customer handle this potential issue?
To avoid this issue, Customer tried to manually reset PHY device by issuing a RESET_N to PHY after CPU finished initialization. However they found the PHY was configured incorrectly in MII mode, instead of intended RMII mode. I think this is due to the reason I previously said.
Customer corrected the configuration through MDIO register access, however the device cannot function properly even the configuration has bee corrected. Finally we found the problem was due to MDIO configuration was implemented after MAC initialization. The problem solved when we correct the MDIO register before MAC initialization. I cannot understand why PHY must be configured before MAC initialization?
Thank you,
John
