Other Parts Discussed in Thread: AMIC110
Hello Team
My customer is using DP83822 and now have a problem.
When two phy have the same adress, use “straight cable to connect the two phy. When the two phys reset time interval less than 8ms. There will be connection problem. LED0 is off. When use crossover cable will not have this issue. So could you help look about it and give some comment? thanks.
