We have used the DP83867IS phy with T1024 processor from NXP. We have powered the PHY with 2.5V(VDDIO) , 1.8V(VDDA1P8) and 1V(VDDD1P0) at the same time.
But as per data sheet we found that No external supply is required for this pin. When unused, no connections should be made to this pin. So we removed the VDDA1P8 supply and powered the PHY. Does the above scenario make any problem? But we are able to list out all the PHYs in u-boot.
Share your thoughts.
Hareesh
