Dear Sirs
What is the difference of VOD Vp-p and INNER Amplitude Vp-p?
BRS
Nat
Dear Sirs
BRS
Nat
Hi Nat,
Are you referring to the DS80PCI800? The document you have pasted is for the DS80PCI800, not the DS80PCI810.
In the DS80PCI800, setting the de-emphasis value (DEM) to anything other than 0 dB will result in the inner amplitude being reduced by the amount in dB of the de-emphasized waveform. VOD Vp-p is the full peak-to-peak differential voltage swing, while the Inner Amplitude Vp-p is the peak-to-peak value of the de-emphasized waveform. A better pictorial explanation is shown below:
VTX-DIFF-PP: VOD Vp-p
VTX-DE-EMPH-PP: Inner Amplitude Vp-p
Note that this capability only is in the DS80PCI800. The DS80PCI810 does not have de-emphasis capability.
Michael
