I have a couple of questions about the application of DS90UB925Q-Q1. Thank you in advance for helping.
(1) Can I leave the MODE_SEL pin open if we are using I2C registers to select modes?
(2) IDx pin says you must have a pullup resistor. What value would you recommend?
(3) Is there an ability to select IDx from I2C for the 925? If so, can we leave the IDx pin open?
(4) could you explain the use of the INTB pin? what sort of situation would call for an interrupt?
Thanks again
