LMH1981 - VSOUT Jitter evaluation data
Guru 19775 points
Other Parts Discussed in Thread: LMH1981
Hello Team,
Do you have any evaluation data of VSOUT jitter evaluation data ?
- VSOUT jitter
- VSOUT periodical jitter
Kawai
  • Hi Kawai-san,
    We do not have VSOUT jitter data since that is not a parameter we specify in the datasheet.
    I will check with the IC designer on whether the observed VSOUT jitter is within the expected variation, and why this happens.  I believe the LMH1981 was not designed to have low jitter on
    VSOUT path (only HSOUT path was designed for low jitter).
    Does the customer have a max VSOUT jitter tolerance that is driven by their system requirements?
    Alan
  • Hello Alan-san,
    Thank you very much for your support. I am asking for system jitter requirement. Do you have any update from the designer ?
    Kawai
