Other Parts Discussed in Thread: SN65MLVD202A
Hi team,
My customer is using SN65MLVD200A, and they found that in their system bus, the chip's A/B pin will connect 5V power supply with a 4.7kohm pull-up resistor.
In datasheet, the max condition is 4V for A/B pin. But since it's only a weak pull-up, could the chip work normally in such condition?
If RE/DE pin is set to make the chip disabled, could it help the chip survive in such condition?
Thank you!
