For TCA6424ARGJR, if we want to make sure the default state of a port is low before any software configure the port, we put a pull down resistor to do this correct?
What is the recommended pull down resistor to insure this?
Also, if the /RESET pin is held low will the ports be HiZ, or in a known state? The datasheet timing diagram makes it appear this happens after reset is released....
For our application, we only use this for output, none will be used as input.
Dan
