Hopefully somebody can help me with Bus Powered CAN Nodes/Isolation. I want to control 3 no. 24V BLDC Motors each with their own PSU via CAN.
I am intending to run a separate Logic 24V supply along the CAN bus to power each CAN node (via regulator on each node). Bus length will be 8-10 metres long.
The microcontrollers on each node will be isolated from the motor drivers they are controlling.
My question is, will I need to use isolated CAN transceivers & DC/DC converters?
Thank you in advance for any adviceBus Powered can Nodes Model (1).pdf
