Hi team,
Our customer have problem about SN65HVDA100-Q1.
Please answer the question below.
1.Is there a problem with LIN IC and CPU only by connecting TX / RX / EN?
2.I want to know how the CPU detects mode,is there a way to do it?
3.Is there a fail-safe to avoid communication failure?
(Is there any restoration method other than turning off the power?)
4.In which case can the LIN IC not be able to communicatez?
5.What will happen if the LIN signal enters within the standard time of tmode_change when EN enters Low or High?
(When EN is changed within max 5 us)
6.Does inconvenience or trouble occur when the EN terminal is always operated at high?
Best Regard,
Kenji
