TUSB4041I: Device ports running at much reduced speed?!
Part Number: TUSB4041I
Other Parts Discussed in Thread: TPD2E001, TPD2E1B06, TPD2E2U06
I have a strange issue with this device, I built this IC into a design that has been working fine for weeks. All 4 ports were working as normal at high speed USB 2.0, until something has either damaged or upset the data rate. All the ports are working apart from the speed, it seems to now be stuck at USB 1.1. The computer ports are fine, and the cable connecting the hub to the host PC. Before I pull the design apart does anyone know of a reason this could happen or where to look for clues like supply failure?
Many Thanks.
