I am working on a high volume design where I am using an SN74LVC1G123 and I am trying to check the tolerance on the monostable output pulse duration. I can easily determine the tolerance in output pulse duration due to the resistors and capacitors but I cannot find enough data in the datasheet or application notes to define the tolerance due to temperature variation and manufacturing tolerances in the monostable IC. Have I missed the data somewhere or is this data that you would be able to provide?
Thank you for your help.
Kind Regards,
Simon
