Hi
We obtained the following waveform of VCC (14pin) when powered up.
When powered up, OE is pulled down to GND.
Should we avoid this state of VCC for normal operation?
Should the OE be tied to VCC when powered up/down?
BestRegards
Hi
BestRegards
Hi
Thank you for your reply.
>If you do not care, you can leave O̅E̅ enabled during startup.
Yes. Now ~OE is tied to GND, so I believe the ~OE is enabled.
I'm concerned this VCC waveform has strange step part when it is rising.
So I want to confirm if such a waveform is likely to happen and it is normal.
BestRegards
