Hi All,
We found some TI SN74HCT273 needed Din hold time(th) is more than 600ns, if the Din level be switched in less than 600ns after clk rising edge, we can see switched Din status be latched.
Datasheet only defined minimum value which is 0ns. Could you please check the distribution of Din hold time? How long time we need hold the Din signal after clk rising edge to make sure it can be latched?
