Other Parts Discussed in Thread: HALCOGEN, SAFETI-HALCOGEN-CSP
I have attempted to run all the Unit Tests for our current microcontroller configuration, and we have the following issues :-
ADC 1- Fails 4 tests – appears to be associated with the G0SAMP – strange as ADC passes all tests
adcInit, adcGetEVTPin, and both adc1GetConfigValue
CRC - fails the Interrupt tests – ie with any of the interrupt tests enabled the test “hangs” I can see in the test code generated the interrupts being enabled…. But further than that I need your assistance.
ESM – incompatible structure - Fails to compile. Compile debug log available if required
FEE- Fails to compile – Compile debug log available if required
GIO – Failure on Port A - gioGetPort, gioGetConfigValue
Het 1 &2 , and PMM These fail but I have not started to look at these yet
We are using HalCoGen 4.07.00 with the HalCoGenCSP as detailed in the manifest available if required.
Please advise ASAP so that I can close this task for our certification.
