I am using TMS570LS31x and i want to make a simple web server. I also use LWIP 1.4.1 library to do this webserver. Did anyone work before about this topic?
Regards.
Regards.
Have you installed the package that is provided at the bottom of the page in the download section?
After installation, you will find in the installation directory a pre-build application for TMS570LS3137.
The CCS project as well as Halcogen project are also provided as reference.
Can you describe a little more.I am not able to understand your exact requirements.Do you need some buttons on your webserver?
Do you need some text boxes etc.? which you want to update dynamically?
Let me know the exact requirements so that I can support you better.
Manoj
Attached please find the installer for active webserver demo.This demo supports ssh and cgi calls.
This wiki article explains this project in more detail
This installer is for RM57 and tms570lc43 launchpads. You can compare the lwip folder of your demo and this demo and make related changes to adapt to tms570ls31.You can use the CCS project as a reference and make changes to your ccs project.Let me know if this helps.
Hi Manoj,
I have a problem about web server's login page. I want to add a secure login system for my webserver. What I basically want is that - when I enter the IP of the controller in the browser, it should prompt me for a username and a password. I want to make this system as secure as possible using the lwIP. The page as given below what i want.. I searched something about authorization in lwip library. But i could not find useful things.
Do you have any idea about this topic?
Regards.
Hello MUHAMMET,
I want to add http authorization to my embedded web. Could you share how did you manage to do it?
Thank you.
