I have a problem with the configuration of my RM48L952PGE project. When I try to change the setting of internal PULL resistors for "GIO.PortB.bit3" I get error messages. See attached picture:
I found out, that this seems to be due to a misplaced "}" in a configuration file. When you remove it, the problem seems to be solved.
The erroneous brace is in file "drivers/RM48L950PGE/GIO570v000.xml" line 480.
