Other Parts Discussed in Thread: TMS570LC4357
Hello I have a few questions around 7.8.2.2 ECC Data Correction Diagnostic Mode 7: DIAGMODE = 7
This check is capable of being run on the full 7.4.4 Syndrome Table, is there a recommended procedure? Is running this test against one value sufficient? If the contents of flash are CRCed prior to execution by a boot loader for validity, what would be the primary benefit of running this ECC test versus generating a ECC error through Section 7.6 Deliberate ECC Errors for FMC ECC Checking.
Thanks!
