Hi
I am trying to read registers of MPU-9150 via I2C interface from MSP430F5528. The default register in MPU9150 is 0x75 and the value in this should be 0x68. But the same is not coming when I am trying. I am sending the code snippet. Please review the same.
I have taken from your example code only but I didn't use the interrupt feature. I am doing everything inside while(1).
Please help me resolve the issue..
Arnab
/* --COPYRIGHT--,BSD_EX * Copyright (c) 2012, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ******************************************************************************* * * MSP430 CODE EXAMPLE DISCLAIMER * * MSP430 code examples are self-contained low-level programs that typically * demonstrate a single peripheral function or device feature in a highly * concise manner. For this the code may rely on the device's power-on default * register values and settings such as the clock configuration and care must * be taken when combining code from several examples to avoid potential side * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware * for an API functional library-approach to peripheral configuration. * * --/COPYRIGHT--*/ //****************************************************************************** // MSP430F552x Demo - USCI_B0 I2C Master TX single bytes to MSP430 Slave // // Description: This demo connects two MSP430's via the I2C bus. The master // transmits to the slave. This is the master code. It continuously // transmits 00h, 01h, ..., 0ffh and demonstrates how to implement an I2C // master transmitter sending a single byte using the USCI_B0 TX interrupt. // ACLK = n/a, MCLK = SMCLK = BRCLK = default DCO = ~1.045MHz // // ***to be used with "MSP430F55xx_uscib0_i2c_07.c" *** // // /|\ /|\ // MSP430F5529 10k 10k MSP430F5529 // slave | | master // ----------------- | | ----------------- // -|XIN P3.0/UCB0SDA|<-|----+->|P3.0/UCB0SDA XIN|- // | | | | | // -|XOUT | | | XOUT|- // | P3.1/UCB0SCL|<-+------>|P3.1/UCB0SCL | // | | | | // // Bhargavi Nisarga // Texas Instruments Inc. // April 2009 // Built with CCSv4 and IAR Embedded Workbench Version: 4.21 //****************************************************************************** #include <msp430.h> unsigned char TXData,i; unsigned char RXData; unsigned char VALUE; //unsigned char TXByteCtr; int TXByteCtr; int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop WDT P3SEL |= 0x03; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz UCB0BR1 = 0; //UCB0I2CSA = 0x68; // Slave Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation //UCB0IE |= UCTXIE; // Enable TX interrupt //UCB0IE |= UCRXIE; //UCB0IE |= UCNACKIE; // Holds TX data while (1) { UCB0I2CSA = 0x69;//slave address while (UCB0CTL1 & UCTXSTP); UCB0CTL1 = 0x92;// write enable TXData = 0x75; UCB0TXBUF = TXData; //slave data UCB0CTL1 = 0x82;// read enable while(UCB0CTL1 & UCTXSTT); //__no_operation(); RXData =UCB0RXBUF; UCB0CTL1 |= UCTXSTP; __no_operation(); } }
